Question about Toshiba Satellite A215-S7422 Notebook
Re post It still didn't do any thing
  • Jeff Strader
    Jeff Strader May 11, 2010
    is there a light on the power adaptor a few feet from the wall plug? if so , is it on when plugged in ? do any of the lights on the computer light up before you hit the power button?
The cotton snaps after a little while.
Operator error. how do you know the "tension is correct?"
One other thing I didn't think of in your other post is a bad needle plate. If it is well and truly stabbed to death, it can create a knife edge which will cut your cotton.
Aug 17, 2012 | Brother Sewing Machines
Lug nut post sheared off - Can the post be replaced?
yes, any tire shop can do this for you. I dont suggest trying it yourself considering you didn't know it was replaceable. its a skill level of about 4 or 5.
Aug 02, 2012 | 2000 Mercury Mystique
Why is the finepix games s2900 camera saying I should turn off the camera and put it back on again
I recently got this camera and it did the same thing to me. I found this site and did what quido777 said to do, smacked it on my leg, didn't work. But then I decided to check the memory card and took it out and put it back in, and now its working. I'm guessing it didn't detect the memory card for whatever reason. Before all of this I called tech support and they didn't know **** and wanted me to send it in. I'm glad I decided to fix it myself before going through all of that. But one thing is fore sure, after this camera, I'm never purchasing from Fujifilm again.
May 19, 2012 | Fuji FinePix Cameras
Check engine light is on code p01870
I didn't locate that one you posted, but this is the closest thing I ca e up with P1870 Transmission Component Slipping/ Transmission Mechanical Transfer Case 4x4 Switch Circuit Failure I don't know if that pertains to your vehicle since the info needed isn't posted on your question, but if you reply to this post, I will assist you more
Sep 06, 2011 | GMC Suburban Cars & Trucks
Windows 7 software jail break
There is no such thing.
If you are trying to change the background on windows 7 starter edition, there are several free tools that can do that for you, I would suggest google'ing it, because there are some slight drawbacks to this procedure, and you will want to read all of that throuroughly before installing the needed software.
If you have no operating system for a machine, may I suggest Ubuntu?
It's free, and available here: ubuntu.com.
I hope this solved your problem, if it didn't, please post back more specifically, thank you!
-Denny
Jul 14, 2011 | Computers & Internet
How to remove a distributor
You set number one piston at Top Dead Center (TDC) and made marks on the distributor in relation to its location on the engine, or at least remember the direction in which the rotor was pointing. If you didn't, then the first thing to do is set TDC and then stab the distributor. At TDC, the rotor points to the number one spark plug wire post, follow the firing order from there. While stabbing, you may have to rotate the distributor left or right a little to get the splines to mesh.
Jul 12, 2011 | 1999 Chevrolet K1500
The old driver I have is incompetable with windows 2000 new driver is required
You didn't post any detail(Model No.) of your camera, Please write specific model No. of your camera and re post or reply me the thread, To solve the issue.
Thanks for using fixya.
May 11, 2011 | Cameras
Need manual for Delta shaper cat, # 43 375
Here's a link to a 43-370 HD shaper manual (13mb), but that's the only one delta seems to have online. (See search results here.) For older machines, you may find something useful here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 28, 2009 | Delta 43 - 455 Heavy Duty 5 - Horsepower...
Toshiba Satellite A215-S7422 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
