Question about DCS RGT-305 Gas Kitchen Range
DCS rgt 305 heat wrinkles knobs - DCS RGT-305 Gas Kitchen Range
Instructions for replacing the spark module on a DCS-305
In order to replace the Spark Module on your DCS-305, do the following:
  • 1
    Unplug the range from the wall outlet prior to servicing.
  • 2
    Remove the burner knobs from the burner switches on the front of the range. To remove the knobs, pull them straight away from the range. If the knobs are difficult to remove, wrap a piece of wire or string behind each knob for extra leverage.
  • 3
    Take off the bezel plate from each knob. Depending on the model of your range, this plate may be secured with screws, or the plate slides into place.
  • 4
    Remove the two screws that secure the valve panel then pull the panel off of the range. The spark module is now accessible for inspection, repair or replacement.
  • Oct 19, 2013 | Kitchen Ranges
    Oven will not keep temp and making gas noise
    The ignitor is not working right and is going bad....
    have the repair man replace the ignitor, or DIY....
    Check out this tip about your problem...
    Oven not Working or Oven not Heating
    http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
    Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
    heatman101
    Jun 04, 2010 | DCS RGT-305 Gas Kitchen Range
    Range works, oven doesn't
    We have a very similar problem: "Ready" light comes on immediately when turning on oven/broiler but oven does not heat up.
    Mar 16, 2010 | DCS RGT-305 Gas Kitchen Range
    Just self cleaned oven and now it doesnt turn on.dont smell gas, could pilot light be out?
    happened to me on first try. The heat got so high in there it tripped an automatic sensor that shut everything down.we had sensor/ coil replaced, but repairman showed us how to re-set. unscrewed front plate (behind knobs). on left side, there is a red button you can push to re-set. can you answer my post on self clean? can't find manual for procedure>
    Nov 23, 2009 | DCS RGSC-305 Professional Stainless Steel...
    Electric igniter does not stop sparking after the burner turns on. how do we troubleshoot?
    On my DSC RGT-305 range it wasn't either the spark module or the wiring, it was one of the little rotary switches that sit behind the burner control knobs. It shorted out (verified with an ohm meter). The switch is made by State Tool & Mfg. Co. and the part number is 25300. Wayne
    Sep 28, 2009 | DCS RGS-305 Professional Gas Kitchen Range
    Oven cavity not working
    it sounds like the fir ehas blocked the burner and the injector it needs checking out a god local gas fitter should be able to fix this
    Sep 08, 2009 | DCS RGT-364GL Gas Range
    My oven won't heat up and just smells like gas but my stove burners work
    Hello, This is going to be a problem with your igniter/glow bar. Over time these get old and although you may see it glowing iit still may be bad. Your igniter should glow a brillient yellow and should ignite the gas within 15 seconds of the valve opening. If you have any other questions or concerns please feel free to comment again...Good Luck! Mike
    Aug 17, 2009 | DCS RGS-305 Professional Gas Kitchen Range
    Clicking ignitors
    Take a hair dryer and dry the spark switches located on the end of each gas valve.
    Sometimes when cleaning they get wet and do the clicking thing.
    If that does not correct the problem you will have to replace the bad switch.
    Mar 19, 2009 | DCS RGT-305 Gas Kitchen Range
    DCS RGT-305 Gas Kitchen Range Logo
    13 people viewed this question
    Top DCS Kitchen Ranges Experts
    John Tripp
    John Tripp
    Paul Carew
    Sal De
    Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
