Question about Canon iR 5075 AllInOne Printer
Canon ir5075 e061 0002 - Canon iR 5075 AllInOne Printer
Give solution for canon ir 5050 error code e808-02
See here.
http://www.copytechnet.com/forums/canon/53715-ir5075-e808-002-a.html
Jun 19, 2014 | Canon ImageRUNNER 3570 Copier/Printer
Canon ir5075 error code E00014-000
ese are all list of error code in Canon iR5075
  • n cause: the main thermistor (TH1) has poor contact or an open circuit.The thermal switch (TP1) has an open circuit.The fixing heater has an open circuit.The SSR is faulty.The DC controller PCB faulty.Mode of detection: 0000 after the main power switch is turned on,the temperature detected by the main thermistor does not reach 70?C.
Caution: The error must be be reset in service mode (COPIER>FUNCTION>CLEAR>ERR)
  • E001
Main cause: The main thermistor (TH1) has a short circuit.The sub thermistor (TH2) has detected overheating.The SSR is faulty.The DC controller PCB is faulty.Mode of detection:0001 The main thermistor or the sub thermistor has detected about 230?C or higher for 2 sec.0002 The main thermistor has detected 230?C or higher (hard circuit detection)0003 The sub thermistor has detected about 236?C or higher. Caution: The error must be be reset in service mode (COPIER>FUNCTION>CLEAR>ERR)
Dec 12, 2013 | Canon imageRUNNER 3300 All-In-One Laser...
Canon ir5075 error code e100-001
laser scanner error. needs a new laser
Sep 11, 2013 | Canon Office Equipment & Supplies
Memory full message canon ir5075
Some cases :
- mailbox is full. (delete all file on mailbox) or
- enter to service mode then clear memory (R-Con)
Mar 04, 2013 | Canon Office Equipment & Supplies
I have a canon ir5075 and I have this erro code e0000001-00101
hello,this is caused by the fuser unit,check pressure roller bearings for rust,listen for rattling sound when powered on shutter could stick,lube ends of drive or cracked upper heater roller.thanks don
Oct 29, 2009 | Canon imageRUNNER 400S Copier
Can somebody help me what this mean? Error Code: E100 0001- E100 0002 it is a canon LBP5000
Symptom
  • E061-0001 (Potential ON)
  • E061-0002 (Potential OFF)
  • E100-0001
  • E227-0004
Cause
  • The pin is broken on the Primary Fan 2 Duct. The Laser Shutter is activated by the pin on the Primary Fan Duct Assembly. The linkage is pinched not allowing the laser shutter to be fully actuated (may also indicate E227-0004). Faulty Laser Scanner Assembly.
  • Defective DC Controller PCB Assembly.
Action
  1. Check the shutter operation and the pin on the Primary Fan Duct Assembly. If the pin is broken replace the Primary Fan 2 Duct (iR6570 : FC6-3540-000 / iR5075 : FL2-5834-000) or the Primary Fan Duct Assembly (iR6570 : FM2-3074-000 / iR5075 : FM2-9694-000). If the Laser Scanner Assembly (iR6570 : FM2-3670-000 / iR5075 : FM2-9832-000) has been replaced and error codes E100-0001/ E227-0004 are intermittently indicated, proceed to the next step.
  2. Remove the Primary Fan Duct Assembly (this assembly has a pin on it that activates the laser shutter).
  3. Remove and reinstall the Laser Scanner Assembly.
  4. Install the Primary Fan Duct Assembly. This should free the linkage allowing the laser shutter to be fully actuated.
  5. Finally a DC Con clear resolved both of the intermittent issues (E100-0001/ E227-0004).
May 28, 2009 | Office Equipment & Supplies
Canon iR 5075 AllInOne Printer Logo
62 people viewed this question
old marine
old marine
