Question about Canon MultiPASS MP360 All-In-One InkJet Printer
Data error press set key canon mp 360 - Canon MultiPASS MP360 All-In-One InkJet Printer
4 Suggested Answers
  • 22 Answers
SOURCE: Canon MP390 - "Data Error Press Set Key" Message
No free suggestions go to the authorised service centre or trying to get an live chat support from canon like I do from my hp printers
Posted on Mar 05, 2009
SOURCE: canon mp 360 without the CD Rom and usb
If your model number is Canon Smartbase MP 360 then click on the link below to download the software.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=9526
The USB need not be the same one.
But without the software the printer cannot be detectetd Hence click on the link above to download the software.
Posted on Aug 08, 2009
lock123
  • 6831 Answers
SOURCE: Error E8 on Canon PIXMA MP 150 printer. It will
Hello
Here is something you can try, all credit Ben k:
(1) have your printer power down ie. off, just to make sure pull the plug out and wait 10 seconds.
(2) plug printer back in, now Hold down the Stop/Reset button don't let go.
(2a) push and hold the on/off button
----at this point both fingers are holding down the buttons.----
(3) take your finger of Stop/Reset, pause maybe a second now press stop/reset button once and then press again and hold.
--- both fingers at this point are hold down both buttons----
(4) take your finger off on/off and now finally take your finger off stop reset.
---wait for the printer to go into its service mode ie. wait maybe 30 secs a min whatever till the printer carage has moved back into ints original spot.
---after this has occoured you should be able to press Stop/reset to cycle though the options
each time you press Stop/Reset Alarm and on/off should alternate lighting up. Hope this helps.
0 time Green Power off
1 time Orange Service pattern print (auto teste)
2 times Green EEPROM print (dados da EEPROM)
3 times Orange EEPROM reset (EEPROM reset)
4 times Green Waste ink counter reset (Absorvente reset)
Hope this helps good luck
Posted on Dec 08, 2009
Error 5B00
Canon PIXMA MP180 All-In-One InkJet Printer
Error 5B00
Jul 04, 2012 | Canon PIXMA MP180 All-In-One InkJet...
What is the meaning of the error code p08 error 5200 showing in the canon pixma 250 inkjet all in one?
Hello
This error is wasted ink full reset the printer press reset button and hold then press on relase and press twice reset button is now in maintenance mode to reset wasted pad ink press 4 times the reset button then turn the printer button on/off
Hope it helps, good luck
Dec 22, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
ERROR CHECK PRINTER 5B00, DE LA IMPRESORA PIXMA MP/130
To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
OR
Reset for mp130
turn on the printer press menu
press scan, copy, scan to enter service mode
use> to get to nvram
set ABS-M level to 0
Set ABS-P level to 0
Press stop to exit..........Done
i hope this help
Dec 05, 2010 | Canon PIXMA MP130 All-In-One InkJet...
E27 mp 190
Manual Reset Waste Ink Counter Pad Canon MPC190,
1. Enter SERVICE MODE By pressing Menu, Copy, Scan, Copy, Copy
2. Select TEST MODE.
3. Select 8 PRINTER TEST in TEST MODE.
4. Select 3. [EEPROM CLEAR].
5. Select 0. [INK COUNT].
6. Press the [Set] key.
7. Press the [Stop/Reset] key (returning to the state of 3), and then press the [ON/OFF] key.
Jul 30, 2009 | Canon Office Equipment & Supplies
How do I change the Ink on ImageCLASS MP 360 Have been given printer and do not have instructions with it.
With the mp 360 you just have to lift the scanner unit with power on and the carriage will move to the center allowing you to install new inks. unless there is an error code...
Jun 24, 2009 | Canon MultiPASS MP360 All-In-One InkJet...
Feb 01, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
When i scan the images are black and white not color
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Selecting a Response to Commands from the Operation Panel
You can specify a response resulting from pressing the <Color Start> or <Black Start> button on the machine. Setting the response with MP Navigator allows you to scan documents easily.
Important:
With network connection, only MP Navigator can be launched. Configure the settings accordingly.
With USB connection, with Windows XP, the program selection dialog box will be displayed the first time you press the <Color Start> or <Black Start> button on the machine, as shown below. Select 'MP Navigator', select the 'Always use this program for this action' checkbox, and then click 'OK'. By specifying this setting, selecting any scan mode launches MP Navigator, and the selected action will be performed.
1. Click the Windows 'Start' button, then click 'Control Panel' (Non-Windows XP: click the 'Start' button, then click 'Settings' -> 'Control Panel').
2. In the resulting window, click 'Printers and Other Hardware', then click (or double-click) 'Scanners and Cameras'.
3. Right-click the scanner icon for the machine, then click 'Properties'.
4. On the 'Events' tab, in 'Actions', specify the setting to launch MP Navigator. Specify 'MP Navigator Ver2.1' for 'Select an event' and for all events. (Windows 98/Windows 2000: Select an event in 'Scanner events' and specify 'MP Navigator Ver2.1' for 'Send to this application'.) If the settings are already configured to launch MP Navigator, click 'Cancel' to exit.
Important:
If MP Navigator is not set as the program to launch, you will need to select an application to launch each time you press the <Color Start>/<Black Start> button.
5. Click 'OK'. Windows 2000 only: Restart your computer.
Setting actions for the <Color Start> and <Black Start> buttons with MP Navigator
MP Navigator enables you to specify the response resulting from pressing the <Color Start> or <Black Start> button on the machine. You can specify the response individually for each event.
1. On the Windows desktop, double-click 'MP Navigator 2.1'. Alternatively, click '(All) Programs' from the <Start> button on the Windows taskbar, point to 'Canon Utilities', then 'MP Navigator 2.1'. Then click 'MP Navigator 2.1'.
MP Navigator opens
2. Click 'Preferences', and specify settings in the Color Button and Black Button tabs to determine the response resulting from pressing the <Color Start> or <Black Start> button on the machine.
3. Select 'Event', and configure the settings in 'Actions'.
4. Click 'OK'. The operation will be performed according to the scan mode settings when you press the <Color Start> or <Black Start> button on the machine
Color Button/Black Button Tabs
The Color Button and Black Button tabs allow you to configure the following settings. Click 'Color Button' or 'Black Button' to open the corresponding tab. Setting items are identical in both tabs.
The following scan modes are available from the operation panel on the machine:
Save to PC Save the captured image data on your computer. Save as PDF file Save the captured image data as PDF files on your computer. Attach to E-mail Attach the captured image data to e-mail. Open with application Open the captured image data with the selected application
Action:
The setting items vary by event.
I hope it helps!!!
Nov 27, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Setting the Canon MP25DV clock and calendar
press clock/calendar once to set date
1) press equal numbers will flash then use number keys to current time then the X to set am and pm. press = again to set time
2)press clock/calendar until date flashes. use number keys to current date. Press = to set
Nov 02, 2008 | Canon MP-25DV Calculator
Canon printer PIXMA MP 150
I think this may work.
Reset Waste Ink
1) Enter SERVICE MODE.
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [Set] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Jun 29, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon MultiPASS MP360 All-In-One InkJet Printer Logo
42 people viewed this question
old marine
old marine
