Question about Jacuzzi Bath Nova H530 917 Black Soaking Bath
"Jacuzzi j-400 series" hot tub- F1 code flashes on control panel
Pump does not come on, lights do not work, F1 flashing on control panel. Owners manual suggests cleaning filters(did it twice), drained and refilled, no difference.Took panel cover off and checked line voltage in....good...breakers are good. Forcing water into outlet at bottom of spa floor via garden hose shows a flow in 'site' window-tube inside control panel(good flow).
  • Anonymous Mar 15, 2014
    I've been trying to find a manual that explains the basic functions of the control panel for the tub, because the jets in the top/ back were spraying water all over the bathroom. I turned the surrounding disc all the way counterclockwise and it's better-- not quite Niagara falls-- but it seems to me I should be able to shut those two off when I don't want the tub quite so full, and just use half the jets.
    There are three buttons on the side panel, the center is on/off and the other two seem to add a blast of air to either set of jets, but neither of those is any kind of cutoff.
    When I go to Jacuzzi's website and try to download the owner's manual I just get redirected back to the general FAQ page or else I get an error message.
  • 27 Answers
Your circulation pump isn't working you should see the flow awitch closing if you have the visible model and hear the pump running.. If its the smaller circulation pump model it needs replacing
Posted on Jul 20, 2009
    Scholar:
  • 80 Answers
There are two things you can check, there is a tranformer that plugs into the main circuit board(usually a four wire plug). Unplug and check pins for good connection and then reconnect There are usually one or two fuses inside the control box mounted on or near the circuit board. Turn off power to spa and pull fuses and check continunity. This is a good start.
Posted on Aug 19, 2009
Jacuzzi j355 hot tub FL1 code flashing on control panel
sounds like the recirculation pump isnt working FL1 means no Flow pump 1
Aug 24, 2014 | Jacuzzi Pool & Spa
What red light flashing codes
the motor has probably seized from rusted bearings. check pump for problems. possible failure of capacitor for motor.
Jun 22, 2013 | Jacuzzi Home
My hot tub top control is flashing SPA6,and hot tub is not heating up.
Here is a link for you to resource that error code.
click that link and scroll through them until you find your error code.
Rod
US Parts Center
Aug 19, 2012 | Jacuzzi Pool & Spa
Motor will not come on. flashing OH on tub display dial. Dream maker Model #8003 x 400 series 86L Just purchased used spa and have no manual or directions. thanks
OH stands for Over Heat situation.
If the motor is not working at all, you are getting the OH code because of that. The OH happens when there is not enough circulation in the hot tub which causes the water near the heater to overheat the sensor located in that area. It sounds like either the pump has failed, the wiring has shorted to the motor, or the control board is not telling the pump to come on.
Its probably a bad motor since the heater is obviously activating, which it wouldnt if the pumps motor was getting no power. Replace motor and all should be well again.
Apr 14, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
My Balboa 500Z-Series Hot tub has been working fine for 6 months. Then today, without warning the lights started flashing and I could not turn them off from the light button. Additionally a code...
Hello!
I have a question about my Balboy 500Z. When the water is heated the motor pump is still running that means the pump runs all the time without interrupt even the water has it's temperature. Now my question: is it possible to turn of the pump? thank you for your quick answer! Greetings Beat from Switzerland
Jan 02, 2011 | Balboa Instruments Duplex Digital Panel 2...
Can't unlock jacuzzi hot tub control panel
control panel not working, cannot control or work control buttons, stays in econ mode all the time. Nothing else works.
Nov 27, 2010 | Jacuzzi Pool & Spa
Jacuzzi hot tub model J-300 series with an FL-1 code. I have shut off power at box and restarted a couple of times and the circulation pump reset. Now the reset won't happen. Both pumps still operate and I...
A flashing “FL1” display means the flow switch is
malfunctioning open, the filter cartridge is excessively
dirty or an “air lock” condition has occurred at the
circulation pump intake.
Jan 06, 2010 | Jacuzzi Signa 6 Whirlpool JAC-B540...
Jacuzzi whirlpool hot tub, flashes Fl-1 has new filters,
Sounds like a bad heating element. This is located in a stainless steel tube under or around the main control box behind the cover around the tub. It is not hard to replace but should be done by a pro. The part is avaliable online.
Sep 24, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
WHAT IS THE MODE BUTTON FOR?
EC stands for Economy. Change the mode until you reach ST and then it will stop flashing and function as normal.
Economy mode only allows the heater to function when the hot tub is on its filtration cycle.
Regards,
Ian.
http://hottub.synthasite.com
Jan 04, 2009 | Jacuzzi Balboa R574 System for 1 2 Speed...
Jacuzzi Bath Nova H530 917 Black Soaking Bath  Logo
2,100 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
