Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Tv turning off after viewing for 5-10 minute
I turn the tv on and it takes about 5 seconds before it will come on ,but i can hear the station its on. after the picture comes on, it will remain on for about 5-10 minutes and then cut off and the power light will blink and the tv will not come back on for a few hours and the screen will jump in between its different picture sizes.
  • 16 Answers
SOURCE: TV will not power up
LoL!!! I don't know why but all RCA's have Flyback Transformer problems! I have one to here is the part number 259296 if you look around you can buy it for about 15.00 if you know how to solder you can do it your self and save big time! Hey I'm doing it! I don't see paying $500.00 to fix it you could buy a new one. And they are just ripping people off because the parts aren't really that high to fix the flashing light problem. And the part is never on back order so your getting screwed they are probably wanting you to finally say just throw it away. And than they'll fix it for $15.00 and sell it for $600.00 Anyways for the people that are having the same problem go here to buy the Flyback Transformer for the D52W20 http://www.electronix.com/catalog/advanced_search_result.php?ELECTRONIX_CATALOG_SESSID=c5d90cbb7ae2d4c1449ea48542eef46a&keywords=259296&x=4&y=14
Also here is another website if you have access to junk TV's and want to know what other RCA Flyback Transformer will work. The price on this site is higher for there's though
http://www.partstore.com/Part/Thomson/RCA/D52W20/Thomson/RCA/259296/New.aspx
Posted on Dec 10, 2007
  • 579 Answers
SOURCE: power light
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price (less than $200) and install it in the old lamp yourself. really easy.
Posted on Jan 03, 2008
ladywinn
  • 5138 Answers
SOURCE: RCA D52W20 52" TV SHUTS DOWN AFTER A FEW MINUTES
you have a bad capacitor around flybackor neer by transformer.
Posted on Jan 17, 2008
SOURCE: Screen is Black Power Light Blinks Three Times
bad power sorse bring the tech in unless u know how to chage outthat part
Posted on Mar 15, 2008
  • 319 Answers
SOURCE: My RCA D52W20 will not stay on
Clicking sound is power relay engaging. If all systems are not functioning properly, unit will shut down to prevent further damage and/or fire hazard
Posted on Apr 23, 2008
Change from 24 hrs to 12 hrs
Instructions
    • 1
      Press the "Power" button to turn the machine on. The device takes approximately 5 to 10 seconds to fully load.
    • 2 Press the "Time" button and hold it down for 8 seconds to begin the setting process for the time. Use the arrows on the left side of the device to select the proper hour and minutes. Use the "Up" button to increase the numbers and use the "Down" button to decrease them.
    • 3 Use the arrows to select the time zone that you are currently in. The device automatically adjusts for daylight savings time. Press the "History" button on the right side of the device to view information regarding past weather history.
Read more : http://www.ehow.com/how_7571640_sharp-wireless-weather-station-instructions.html
Nov 02, 2014 | Sharp Weather Station Atomic Clock
Samsung LN-S4051D slow to turn on.
You are likely to have a module bad....part number BN94-00864A and if you take it out (unpluggs) you should inspect it for capacitors that may be domed or pooched up at the top. If so they should be replaced first before getting the module as the capacitors are about $1.00 each. Do a search for Samsung parts online if you need the module and call them toll free
Mar 16, 2008 | Samsung LN-S4051D 40 in. LCD Television
How do you use PS3 and DVD player with the Toshiba 32Dtu2 LCD TV?
The PS3 can be hooked up to the tv using either a HDMI cable or the old RCA (Yellow, Red, White) cables. If you are having problems viewing a picture or hearing sound, here is some trouble shooting you might want to try.
Connect the PS3 using both the HDMI and RCA cables. select the HDMI input on your tv. turn on the PS3. If you cant see a picture, press and hold the power button until you hear 2 beeps (this will take about 15 seconds). This resets the PS3 to the old RCA cables. Select the RCA input on your tv. Hopefully you can see the image and hear the PS3 now. Go to the settings on the PS3 and change the display settings to output video through the HDMI. Remember, your tv can only go as high as 1080i resolution, so you wont see anything if you select the 1080p resolution.
If this didn't work, you might have a bad signal though the HDMI cable. Unplug the tv and PS3 for atleast 30 minutes, and then connect the PS3 to the tv before you turn either one on.
If this doesn't help, then you might have a HDMI cable that isn't recognized by either your PS3 or your tv. Try replacing your HDMI cable.
Hope this helps!
Sep 19, 2011 | Toshiba 26HF84 26" TV
Ps turns on but no picture or sound on tv i've tried a different cable and its just the same. the tv appears to pick up some sort of connection but not what it should. The ps turns on and all the lights...
I will take a shot at your problem and assume you are using a HDMI cable. First you need to turn the PS3 on by the switch on the PS3. Then press and hold the On/Off button on the PS3, keeping it pressed until you here a clear beep and then a couple of seconds after you should hear a second beep. Once you hear the second beep take your finger off the button. Now as long as you are on the correct HDMI channel the rest should be on the screen for you to complete.
Please Note - If you have it working on a particular TV, then decide to unplug the PS3 and put it on another TV, there is a very good chance it will be blank again. This is normal because each TV has different setting, pixels, size, etc, and the HDMI has to be set to each individual TV. Once you get use to the settings. It takes no more than 1 minute to do.
Cheers, and hopefully this will solve your problem.
Feb 09, 2010 | Sony Playstation 3 (PS3) Console
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Startup Problem with my 42pf7321d/37 Phillips plasma TV
I need to know how long do you have the tv?In the other word,approx. how many hours you have put into it?
Secondly,did you wall mounted the tv or setting it close the the area which there is not much room for the back of your tv to breath?
solutiondoct
Nov 06, 2008 | Televison & Video
TC-32LX85 only stay on 5 minutes.
Just found a solution to this problem (conveniently hidden on unlucky page 13 of the user manual). This means that your TV is in store mode... it refreshes every so often and changes to the different inputs to show store viewers the quality of different inputs.
First, go to Menu - Setup - Advanced Setup and make sure that the "Auto power on" is set to "No." Turn the TV off and unplug it. Plug it back in. Press and HOLD the power button on the TV (not the remote). Hold for 2-3 seconds or so... you'll hear a few clicks. Release the button, then press it. The first thing that pops up should be, "Select viewing environment." Make sure you select "Home." Continue with setup from there.
Voila!
-Zach-
Aug 22, 2008 | Televison & Video
POWER DOES NOT STAY ON...PLZ HELP
Hello carriegomez,
It sounds like you shutdown circuit is being activated. This is due to excess current being drawn. This usually happens in the High Voltage section of the TV or one of the deflection stages. Due to the nature of this problem I would suggest that you take it to a local TV repair shop or have a TV repair person come out and take a look at the issue. The HV section is dangerous and should be dealt with by a qualified TV repair technician.
Thank you,
I hope this helps
Shuttle83
Jul 09, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi vs-50609 wont stay powered on
Hello nicolastran,
I gave this advice to someone with this same problem so here it is again:
It sounds like your shutdown circuit is being activated. This is due to excess current being drawn. This usually happens in the High Voltage section of the TV or one of the deflection stages. Due to the nature of this problem I would suggest that you take it to a local TV repair shop or have a TV repair person come out and take a look at the issue. The HV section is dangerous and should be dealt with by a qualified TV repair technician.
Thank you,
I hope this helps
Shuttle83
Jun 24, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Screen tuns black after 15 seconds and comes back after about 15 minuts
The solder joints on the vertical output IC have cracked. This is a very common problem on those sets.
Nov 14, 2006 | Panasonic CT-27G34 27" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
69 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
