Question about Dishwashers
Diplomat askoll m95 pump - Dishwashers
How do I switch AM/FM on Walkman SRF M95?
The small grey "rocker" wheel, which is used for tuning, is also used to switch between AM and FM. Simply press the wheel in the middle and it will switch bands.
Jul 04, 2011 | Sony SRF-M95 AM/FM Radio
Fault code f-05 . wont pump water out
I think this one is fitted with an Askol pump, and they tend to fail fairly quick. These pumps a a reasonable price. and easy to fit
Feb 11, 2010 | Hotpoint Ultima WF860 Front Load Washer
Du401 doesn't drain water
there is a little pump at the bottom of the machine,called the askoll pump".this is what pumps out water before and after a cycle.the pump needs replacing.
Nov 01, 2009 | Dishwashers
Won't wash, won't drain
before a dishwasher washes,it must pump out all the residual water from the previous wash it sounds to me like the askoll pump needs to be replaced.
Oct 24, 2009 | Dishwashers
DOES NOT DRAIN SO WONT SPIN HELP
you need to replace the "askoll"pump.this is the small pump at the bottom of the machine that drains the water before the spin cycle.
Oct 09, 2009 | Hotpoint Aquarius WD63 Front Load...
Air filter
The Techlusion will fit your bike for a fuel management system. I would definitely get one with aftermarket pipes and especially if your going to get an aftermarket air kit. Techlusion Fuel Management Kit Techlusion (Dobeck Performance) Fuel Injection TFI Control Box for Suzuki Boulevard M95 Cobra FI2000 Fuel Management (Plug & Play) 1020-0081 - Cobra FI2000 Tripot Fuel Processor - 1600 Marauder & Mean Streak Thunder Air Kits (Maurader 1600) http://www.phatperformanceparts.com/...A&Show=Reviews http://www.motorcycle-journal.com/fo...uzuki-m95.html
Nov 10, 2008 | 2005 Suzuki Boulevard M95
Indesit draining problem
Yes, it ought to be fixed on. Best plan is to take the motor off the back of the pump body, then do a web search on "Askoll Pump". Compare the one with the pictures on the other. Askoll pump motors are fitted to most UK machines these days, are easy to buy and fit, and a good deal cheaper than replacing the entire pump. If the motor doesn't look like an Askoll, a complete Indesit replacement Pump is a little under £30 on the net, so all is still not lost. A.
Mar 10, 2007 | Indesit W 123 Front Load Washer
Dishwashers Logo
41 people viewed this question
Top Dishwashers Experts
Owen Barnes
