Question about Conair GMT182CS
I have removed the parts and I have no idea about the trimmer leg spring place.
How to put the trimmer leg spring back in place. I don't know where to put it. In fact I don't know it's place.
3 Suggested Answers
SOURCE: fell apart..help please!!!
The larger white pieice that has holes in it should be connected between both the spring and the smaller razor, The bottom of the larger white peice has to be able to fit in the peice of medal that moves in a circular motion inside the top part.
First, Try to make the hooks of the spring go in pretty securly inside the small holes. The flat side of the white peice has to be connected to the flat side of the smaller razor. They should kinda snap together on the top hole. I had to gently place the parts together and push the larger white peice in the medal by placeing the larger razor peice right on top and pressing down really hard. You might hear some snapping but the peices should all connect together and the large medal peice should connect to the black groves and press hard. Hold in place while putting the screws back in.
Posted on Jul 09, 2008
perc500
SOURCE: pUTTING BACK THE TRIMMER
just need manual does anyone have it for this model GMT171
Posted on Nov 26, 2012
Putting a wahl 9307 back together
You will notice there is a little hook that the spring thing fits into on the device. You want the smaller part of the spring facing upwards and it should tuck in smoothly.
This is the smaller part of the spring facing upwards:
Then it gets tucked in as such:
Take note from the above photo that the square edges on the plastic piece go at the top of the blade piece and the rounded edges are at the bottom.
Then the bottom blade piece rests on top with the curvature facing upwards: putting-wahl-9307-back-together-g0fa4lo4hxabacpjggd4qk4j-2-5.jpg
The rest should be straightforward!
Jul 10, 2014 | Wahl 9307
The starter cord jammed on recoiling, after attempting got release it the recoil spring rewound, now the cord and spring are interlocked. I'm looking to strip the recoil mechanism but I believe I
Its an easy opperation to undertake if you know how. Take note of where everything goes during the stripping down of the recoil assembly. Use eye protection when trying to recoil the rewind spring, they have a tendency to jump back out at you while coiling them back in. easiest way is to start by putting the hooked end into the plastic housing and work your way inwards coiling it back in. Then place the starter cord roller in on top, adding the one or two black sliders, the washer and the spring clip to hold it all in place.
Feb 16, 2013 | Stihl Trimmer Oe Rewind Starter Spring 36...
Fs44 whipper snipper recoil spring unwound, cord jammed and when tried to release recoil spring released
http://rapidlibrary.com/source.php?file=ulztcbvqczi89on&url=http%3A%2F%2Fwebweevil.co.uk%2FPublic%2FInfo%2FStihl%2520FS36%252C%2520FS40%252C%2520FS44%2520parts%2520list.pdf&sec=a0a080fc8669d51a
The link is for the breakdown manual and parts list
Parts for a 9307a
There is a small edge stick out at the base of the hollow mouth of trimmer. Put the spring in such a way that both the legs sticks out facing downwards. Once spring is installed, then slide the plastic holder (with rails) of the top blade on the spring and keep holding until you put together the bottom piece and tight it. Easy
Feb 10, 2013 | Wahl 9307
Schematic diagram to repair a STIHL FS 45 trimmer
hello, need a operators,parts manual for a stihl,echo chainsaw,hedge trimmer,line trimmer,edger,pole saws,concrete saw, as far as i know thay don't post any of these on line for the consumer,if i had a dealer number than i would be able to provide you with one,these manuals are available through the dealer only,hope this helps.``
Jan 11, 2012 | Garden
I took apart the handle for my Toro Trimmer Model number 51972 and a spring fell out and I'm not sure where/how it goes back into the handle. I took it apart because the trimer runs but the spool does not...
Hello, Hopefully the exploded parts list can help you out... I've done the reassemble of a trimmer handle once and explaining it can get dicey. The only suggestion that helped me was to have scotch tape handy to act as a third hand when holding small items between two other parts. You don't actually wrap the item, just place it on a small piece of tape - when the item is in position the tape removes easily. Your diagram link is the top one. Good Luck!
http://www.poulan.com/node7925.aspx
Aug 01, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
How do you add trimmer line to Troy Bilt TB539E Weed Eater?
This model trimmer uses .095" diameter line, your local home improvement store will carry replacement line and it will also carry a replacement spool with the line already spooled on it.
This trimmer is a "bump advance" trimmer meaning you bump the head on the ground while it is spinning to advance line out.
What to do to replace the line is place the trimmer on a stable flat surface (like a workbench), raise up the head if the trimmer and unscrew the cap and CAREFULLY remove the spool...you do not want to lose the spring! Take a look at the spool, it will show the direction to spool the line, spool the line then replace the spool by first putting the spring back on the shaft, then put the end of the line through the hole(s) on the side of the outer head, press the spool in place and screw the cap back on.
Of course you can eliminate about 90% of the headaches by buying a pre-spooled head at your local home improvement store...then you follow the directions above and can skip the spooling part. Cheers!
Sep 07, 2009 | Garden
Took off trim around lightbulb
Place the circle of the springs on the two small post that are in the center piece of the trim that heads into the hood, make sure that the two legs of the springs are to the outside of the post. The small legs should lay against outside the center piece. The larger legs should be angled downward. Look in the hood and you should see a piece of metal with a central vertical opening on each side. Take the trim piece with the springs attached and lift the wings of the springs so that they enter the slits. The important part is that the small legs of the springs must be placed against the outside surtace of the hood. As you push the trim piece in the hood the wings of the spring will be forced down through the slits by the pressure of the small legs of the spring against the exterior of the surface of the hood. This pressure will keep the trim piece in place. It may help to remove the filters so that you can see inside of the hood. Make sure that the small legs of the spring are against the outside surface of the hood or there will not be any resistance to create pressure by the springs.
Mar 16, 2009 | Dacor EHD3618SS Kitchen Hood
TRIMMER STAYS IN OPEN POSITION
I had this problem, and it was due to the breakage of a plastic part.  If you slide the trimmer open you can see a piece of spring wire beyond the end of the word 'trimmer'.  The broken piece should locate the end of this spring; if it fails then the spring no longer forces the trimmer blade fully shut.  As the trimmer was opened and closed I could see that the spring did not stay symmetrically placed.  I could also see one end of the spring inside the mechanism, rubbing on the surface under the slider - but not the other.
To help with the instructions, let me identify some parts: "A" is the sliding part that your thumb pushes to open the trimmer; it carries the word 'trimmer'.  "B" is the hinged part that carries the trimmer blade itself and the word 'washable'.  "C" is the flexible piece of black plastic that connects A to B and on which the central section of the spring pushes.
To fix, first remove the sliding section A: slide the trimmer open and push a thin screwdriver down one edge of the slider.  Prise the lugs that hold A in place, away from their slots. Disconnect the connector C from the blade part B (gently push the lugs outwards, one at a time). Turn over the slider A and you should be able to see that one or both lugs that are intended to keep the ends of the spring in place, have broken.  (They are on a silver moulding fixed to the underside of slider A).  I fixed both ends in place with some two-part epoxy - be careful not to get glue on the other parts!  Allow to dry completely and reassemble.
Aug 20, 2008 | Braun 9595CC Electric Shaver
Braun 7526 shaver switch
Managed to fix it - actually was a 7680. Only do this if you:
1. have a small screwdriver set
2. are handy putting little delicate plastic pieces and springs together again
3. are prepared to face the possibility that you might break the shaver entirely
4. you are out of warranty so you don't care if you invalidate it
THE PROBLEM is caused by a small flat metal assembly that acts as a spring to hold the blue button in place. That is held by 4 small glue posts. The glue breaks down, the flat spring falls out of place and the blue button is no long in the right place.
TO OPEN UP THE SHAVER
a. gently remove the plastic cover around the electrical socket underneath, using a small flathead screwdriver to pry it open
b. the two metallic sides of the shaver can be pulled away starting at the bottom of the shaver
c. uncrew the four screws on the underside of the shaver
d. remove cutter block, battery/lcd block (make sure you don't lose the grommet around the lcd display
e. pull the spring and little plastic latch off the underside of the switch, make sure you remember how to put it back (took me almost 20 mins to figure out how to get that back afterwards)
f. slide the switch all the way up and pull it off the slide - you might need a little gentle force and a flathead screwdriver to coax it off - be careful you don't break anything here
g. remove the trimmer from the rest of the switch
h. put the blue piece back in place (mine had fallen out), then glue the flat metal spring back in place. I smeared brush-on crazy glue on the flat surfaces to hold it in place, I would imagine a four drops of reasonably strong glue on each of the glue posts would work best. Wait for the glue to dry and achieve strength.
i. slide the trimmer back into place, then the plastic latch and spring - this is the tricky part. Make sure the switch can slide on/off in all positions properly.
j. put the display/battery & cutter block back in place. put the back of the shaver on, hold the shaver together with your fingers and test the switch works in all positions without jamming. If so put the four screws back, followed by the metallic sides followed by the plastic cover of the electrical socket.
GOOD LUCK!!
Nov 28, 2007 | Braun Syncro 7526 Electric Shaver
Conair GMT182CS Logo
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
