Question about Bowflex Treadmill Series 7
Thumping noise bowflex series 7 treadmill - Bowflex Treadmill Series 7
blueextc3221
  • 15935 Answers
SOURCE: Err LS on Bowflex Treadmill
The machine needs to be re-callibrated. L5 error.
Your speed sensor must have been damaged either during shipping or use. You'll need a new one. If under warranty - give Bowflex a call. They will ship you out a new sensor and guide you through installing it via the phone... re-calibrating the machine... and getting it operational again. It will take about 2 hours.
The instruction book doesn't mention calibration. be sure to not callibrate in metrics, however (there's no way to easily tell the difference - you have to ask) or you'll be strolling like a walk in the park at 5 "mph".
Thanks for using FixY - a FixYa rating is appreciated!!
Posted on Feb 21, 2009
  • 12 Answers
SOURCE: rhythmic thumping noise with increased speed
The problem is the rear roller has a bad bearing and needs to be replaced
Posted on Mar 16, 2009
  • 12 Answers
SOURCE: bowflex series 3 stops after 10 min
To much electrical draw on motor control board
Lubricate, lubricate, lubricate
SOURCE: bowflex treadmill series 7 saying safe out
I had the same problem, however the treadmill remained in 'safe out' status even when the Safety pull pin was correctly inserted.
The cause of my fault was that one of the kids decided to insert a wrist watch into the round hole located on the control panel's lower cover. In doing so this unplugged the cable conector for the magnetic switch which operates the 'safe out' function, from the main circuit board. The repair was quick and easy, i turned the power off, removed the bottom cover from the control panel and simply plugged the magnetic switch back into the main circuit board and all was back to normal.
Posted on Dec 21, 2009
ercupa190
  • 12223 Answers
SOURCE: incline motor is not working
Dear Sir:
1) If everything is working , now the only thing you can do:
2) check the Motor Lift the Voltage DC ( direct current) is diffferent from the Motor Drive that work with 115 VAC( Voltage alternating current). See the Voltage in the plate of the Motor if 48Vdc or whatever voltage is indicated.
3) Check the breaker and reset , and clean with solution with 50% oxigened water and 50& ethilic alcohol (100%).
4) If all is clean, turn on the motor Lift, and See if there are voltage and the terminal Motor( Check with VOM-Voltimeter in the range DC,) .
Check again the voltage indicate in the plate of Motor, if the Motor is NOT Working, the Motor is Bad( Some brushes wear, and winding overheating) replace or repair.
Conctac me, if you need some additional Help.
sincerely.
Have a great time, blessing.
E.CUADRA
Posted on Sep 05, 2011
Errors for Bowflex series 7
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jul 27, 2016 | Bowflex Treadmill Series 7
Bowflex series 7 treadmill Calibration fail. Next indicated action?
It looks like the main circuit board is damaged and needs to be replaced unless there are separate modules in it.
Jan 22, 2013 | Bowflex Series 7 Treadmill Folding Pro...
Bowflex Series 7 Treadmill motor problem
1) test the power cord for open, break
2) see if there some animal, bid the some wires internal, and get touch with the chassins provoking the short in the machine.
3) replace the blown fuse inside, see the block
4) test the main switch for open or defective.
5) unplugg the machine and see if there c.breaker or fuse are tripp? if does the problem is the c.breaker from your home
6) do NOT use extension cord, and buy some detector spikes, glitch,transient.
God bless you
Jun 26, 2012 | Bowflex Series 7 Treadmill Msrp 199999
My Bowman treadmill 7 series stopped working. It just shows 2 words: safe out. Please help.
Make sure the magnetic safety key ('safety pull' or 'emergency stop magnet') is in place. SAFE OUT indicates that the safety key is not in position or is otherwise not working properly.
For more information consult the following manuals:
http://download.dfxi.com/supportdocs/OM/Bowflex/BFX_TM3-5-7_OM_RevD_web.pdf
http://www.pdfstock.com/bowflex-3-5-7-series-treadmills-assembly-manual-pdf.html
May 05, 2011 | Bowflex Treadmill Series 7
Won't fit through door - taking it apart
remove the 3 screws in the arm trim cover and the harness unplugs there and the other wires are screwed to the frame right there. Philips head screws.
Mar 20, 2009 | Bowflex Treadmill Series 7
Rhythmic thumping noise with increased speed
Mar 11, 2009 | Bowflex Treadmill Series 7
Bowflex series 3 stops after 10 min
Jan 26, 2009 | Bowflex Treadmill Series 7
Bowflex Treadmill Series 7 Logo
26 people viewed this question
Top Bowflex Exercise & Fitness Experts
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
