Question about All-Pro Heating & Cooling
JD AC-165 space heater motor
I have a JD AC-165 with a bad motor. Motor # is 5KCP84DFK161 Serial # WWFK. Can you tell me where I might find one.
tbugger
  • 232 Answers
SOURCE: The heater shuts off tripping the reset- motor/fan ***'y is froze
097134-02 try Reddy Parts
Posted on Dec 23, 2008
  • 126 Answers
SOURCE: The blower motor went bad.
toyotomiusa.com/
they have a dealer locator
Tom Hawkins
Posted on Jan 16, 2009
SOURCE: 2006 H3 Hummer AC/Heater Fan Motor
I brought my 2006 H3 in to the dealer for the same thing. My blower stopped working all together but it started as an intermittent problem. He said he had to replaced a diode or resistor either behind the switch on the dash that controls the fan or on the fan motor itself. Have not had a problem since but that was only about 4 months ago.
Posted on Apr 09, 2009
  • 21 Answers
SOURCE: My AC quit in my 2007 Nissan Versa. The fuses are
You have to remove the dash to get to the blower motor on this vehicle if memory serves me right. It's a substantial job. Take it to dealer should still be under warranty.
Posted on Jun 17, 2009
  • 534 Answers
SOURCE: ac blower motor
Check fuse supplying fan is not blown,
Check blower control switch is operating OK,
Check relay controlling fan is operating OK,
Check variable speed resistor pack is not faulty (the resistor pack is usually located in the blower ducting, in the blower airflow),
Check blower motor ground connection is not missing.
Posted on Aug 13, 2009
Why is my heater blower motor not running?
If you got the motor to run, then whatever feeds that motor electricity is the culprit. Check the switch.
Aug 06, 2015 | 1991 Buick Roadmaster
1992 323 mazda want blow heat out
REPLACE THERMOSTAT.IF ALREADY DONE.CHECK HEATER BLOWER MOTOR SEE IF POWER GOING TO HEATER BLOWER MOTOR.IF YES BLOWER MOTOR BAD.IF NO POWER GOING TO BLOWER MOTOR CHECK AC AND HEATER CONTROL FUSE AND CHECK BLOWER MOTOR FUSE AND RELAY IF ALL IS GOOD CHECK SEE IF POWER GOING TO AC AND HEATER CONTROL SWITCH IF YES THE AC AND HEATER CONTROL SWITCH COULD BE BAD.
Nov 10, 2011 | 1991 Mazda 323
Type your problem for a solution..HEAT NOT BLOWING FUSE OK.
REMOVE HEATER BLOWER MOTOR AND HOT WIRE IT.IF HEATER BLOWER MOTOR WORKS WHEN HOT WIRED EITHER BLOWER RELAY BAD OR AC AND HEATER CONTROL SWITCH NOT WORKING.IF BLOWER DONT WORK WHEN HOT WIRED BLOWER MOTOR IS BAD.
Oct 25, 2011 | 1997 Nissan Quest
Heater and air stopped working on my 2000 Ford Focus zx3
CHECK BLOWER MOTOR FUSE AND RELAY.SEE IF POWER GOING TO BLOWER MOTOR YOU HAVE FAULTY BLOWER MOTOR.IF BLOWER MOTOR FUSE AND RELAY OKAY.IF NO POWER GOING TO BLOWER MOTOR BUT POWER AT AC AND HEATER CONTROL SWITCH. BLOWER MOTOR HAS POOR GROUND OR AC AND HEATER CONTROL SWITCH IS BAD.
Jun 12, 2011 | 2000 Ford Focus
My 2000 Buick Century Custom heater/ac fan stopped working. I can feel a little heat coming through the vents so I think the heater coil and water circulation are okay. But, its cold these days, and I...
it does sound like the heater motor fuse is blown -- but if you check it and it is good ( not blown ) then it could be the heater motor itself or even the heater switch/relay. check all the wires going to the heater motor. -- try and give the motor body a little love tap,, ( this sometimes works ) and tells ya that the motor has a bad conection or the brushes are bad.
c...
Jan 01, 2011 | 2000 Buick Century
Bearings are bad in the heater motor.Need price on parts
I need make model and serial number off unit. Heater motor can you specify a little better as to which motor it is? is it hooked to 4in round steel pipe or the main blower motor that circulates air through the structure
Dec 30, 2010 | Heating & Cooling
THE AC WONT BLOW OR THE HEATER
CHECK BLOWER MOTOR FUSE AND RELAY.IF BOTH GOOD.REMOVE BLOWER MOTOR HOTWIRE IT.IF DONT WORK REPLACE BLOWER MOTOR.IF BLOWER MOTOR WORKS.HEATER AND AC CONTROL SWITCH IS BAD.
Apr 30, 2010 | 2005 Chevrolet TrailBlazer
Nissan Pathfinder Heater/AC goes off/on intermittenly
Most probably a motor going bad but it could also be the switch, the blower resistor or a bad connection. The easiest way I can tell you to isolate the problem is check for voltage a the blower motor when it is on but doesn't blow. If you have voltage all the way to the blower, then that is your problem. Hope this helps.
Dec 15, 2008 | 2005 Nissan Pathfinder
Heat Starter motor constantly running when ac is on
By saying the heater starter motor I guess your taking about the combustion blower( the small motor that vents to chimney) If it runs during the A/C cycle then the main circuit board is bad.
Aug 19, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
295 people viewed this question
Top All-Pro Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Mack Baxter
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
