My screen won't turn on when i start up computer. i have pluged the original grafics card in and pluged the rgb wire in but theres just no signal comein from pc??? any sujestions on how to instal it or something?
  • 643 Answers
I will recommend below checking:
1. monitor
2. bypass graphic card, try built in display
3. reset cmos
Posted on May 18, 2009
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 75 Answers
Sometimes the fault is not always from the graphic card ... it could come from the processor or the memory .... please check them too and also check the signal cable especially the pins on the signal plug
What is a RGB signal
RGB means Red,Green,Blue it is an old system for supplying video signal to a screen..
Feb 01, 2016 | Televison & Video
HP vp17 screen is turned blue How to get back the colours?
I recommend you check the signal cable plug (from the monitor) is fully inserted into the PC.
Jun 10, 2014 | Computers & Internet
2002 300m no start
If you are not using the original/factory key it won't start. There is a chip in the original. Hope it helps
Sep 29, 2012 | 1999 Chrysler 300M
Unpluged VGA cable now no display.
This is why it is never a good idea to SCREW in those little crown nuts from your cable to your VGA port. All connections on any PC should remain firmly connected, but unscrewed to prevent damage due to pulling, twisting or removing. All it takes to damage that VGA port is a single push to the wall from the front of your PC. If your VGA pins aren't touching on the board, and if there are no shorts, you can fix your problem by adding a Video card. Otherwise, you will need to de-solder and remove your on-board port completely and try again with the VGA card.
Mar 09, 2010 | ASUS P4S800-MX Motherboard
My flat panel moitor displays RGB no signal. I
If the other monitor has no signal as well, this proved the video card is faulty and needs to be replaced.
Dec 03, 2009 | Gateway Computers & Internet
GA-8IHXP won't boot... VER 3.0
The next thing I would check is a close inspection of all the bad capacitors on the board. If you need an idea of what they look like check here.
May 23, 2009 | Gigabyte GA-8IHXP Motherboard
PROBLEM WITH MY SCREEN
This may be the problem with the lower version of direct X software. user directX 10 ver and also upated activeX version. The problem mostly soved
Mar 04, 2009 | LG Flatron L1919S LCD Monitor
Just beeping
Have you done something on your computer before that happen? Maybe change your display resolution? or video card?
Oct 24, 2008 | Gateway GT5654 Desktop PC
Pc to tv
Try changing the resolution on you computer. That TV may not handle the current resolution setting. You may also have to do something on your computer to turn on the rgb output.
Feb 22, 2008 | LG 42LC2D 42 in. LCD HDTV
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
