Question about Sharp Refrigerators
My sharp freezer model SJ-229S-SL , UPPER IS WELL BUT BOTTOM NO COLD
WHEN OPEN UPPER DOOR, I CAN FEEL SOME COLD AIR BLOW OUT FROM THE HOLD BESIDE THE BLUE COVER.
    Sergeant:
    Champion:
  • Sharp Expert
  • 243 Answers
Checked Damper in Ref its working or not. You can checked open Ref door press Door Switch and hold your hand near chiller tray Duct
Posted on Mar 03, 2015
HVACRH20
  • 237 Answers
SOURCE: fridg not cold
Ahhhh, the classic symptom of a frozen coil/air return duct. You'll have to pull the back panel off the freezer wall to view the coils. The are likely a block of ice causing the air channels on the sides to be frozen, thus blocking air flow. You may need a defrost t-stat or a defrost timer. If the defrost cycle isn't working then you will get a freeze up eventually. The only other reason is if the freezer door was left open slightly overnight letting in moist air. Let us know what you find.
Posted on Dec 27, 2006
mikedurland
  • 481 Answers
SOURCE: freezer working fine, but no cold air to fridge
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control unit
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Posted on Jun 29, 2008
  • 31 Answers
SOURCE: kenmore bottom mount fridge. The
Look in the back of the freezer, there will probably be a metal panel with a plastic vent on top.
Look through the vents in the metal panel, and you should see the shiny metal fins of the evaporator. If the fins or the vents are plugged with frost, that is your problem. The freezer will stay cold because a small amount of cold air will be forced through the frost but that will not be enough to make it up to the refrigerator portion. You can defrost the unit by removing the metal panel and allowing the frost to melt. Careful use of a hairdryer can speed up this process. This will likely be a temporary fix. The root cause of excessive frost can be caused by a bad door seal or a defective defrost circuit.
First check that the door seal is good by closing the door on a dollar bill at several points around the door, both on the freezer and refidgerator door. If you can pull the bill out with no resistance, the door is not making a good seal. Inspect the seal and make sure there isn't anything stopping the door from closing such as food, or a shelf not pushed in all the way.
If the door seal is good, the defrost system is likely defective. The defrost system has three main parts, the defrost heater, thermostat, and timer. If either one of the parts fails, the freezer will plug up with frost every few weeks. If you can troubleshoot this by manually starting the defrost cycle. Let me know if you would like this procedure.
Posted on Jan 07, 2009
SOURCE: GE GSS22 refrig wont get cold, freezer does.
Hi, it's possible you have a defrost problem, to know if you have a defrost problem, you should unplug/disconnect refrigerator, remove your produce, leave doors open, for faster defrost, clean and leave unplug/disconnected for about hour, be cautious you will get excessive water from defrosting. let freezer defrost completely, then plug/connect refrigerator, let it work/run for an hour, if it's o/k, put back your produce, if it work good/ o/k for 3 to 4 days and start doing the same thing, you got a defrost problem, defrost problems are caused when excessive ice build up on your evaporator, two things could cause a defrost problem. (1) excessive moisture/ hot air entering refrigerator, hot days,hot foods, regular opening, to close heat source, range/ oven. in cases like that, cleaning of refrigerator will normally solve that problem. (2) faulty defrost heaters, defrost thermostat , located in back of freezer side, you will have to remove shelves and back panel, to get access to it,also check your defrost timer and speed of fan, but first disconnect refrigerator, clean and try , before changing any parts. it could just be excessive moisture. always remember to disconnect your refrigerator before attempting any repairs, let me know what happened, then i could tell you exactly what's problem. good luck
Posted on Aug 19, 2009
heatman101
  • 43501 Answers
SOURCE: roper fridge
Check out these tips...they can help you figure out whats going wrong...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Aug 12, 2010
Hye..recently i just notice my sharp plasmacluster model sj-pt491m-bk the chiller is not working. Not cold as normal. The above freezer working normally. Plz advise
Open Freezer Door Press Door Switch and checked Freezer Fan is working or not.
If fan is working then problem in Ref compartment. If not working then replaced Fan.
In Ref Compartment checked all duct clod air is coming or not.
If not coming then Damper is defective.
Dec 25, 2015 | Sharp Refrigerators
Why is my refrigerator not cold?
Hello Is the freezer cold? If the freezer is cold but the refrigerator is not you could have a problem with the evaporator fan motor which blows the cold air into the refrigerator. By opening the freezer you can assure if the fan is working or not by listening and feeling for air blowing around. If the fan were working you would next check the damper door located in the rear of the refrigerator side which is a small door that opens and closes letting cold air into the unit and then closeing when the unit is cold enough. If the door is not opening you would check the door itself for any ice build ups on the door as well. In order to check the evaporator fan motor you would go into the freezer at the rear wall of the freezer you would remove the screws holding the panel in place. When you removed this panel if you seen any ice build up this is termed as a defrost issue and all ice would have to be defrosted useing a hair dryer. If you do have this defrost issue message me back and I will instruct how to diagnose and test to solve which part is causing your unit to have a defrost issue. I await your reply.
Thank you
Rick
Nov 28, 2011 | Refrigerators
I have the refrig where the freezer is on the bottom, the bottom is working fine but the top is not getting cool.
a common problem with bottom mount freezers is the door gets left open,open the freezer door and look at the ceiling,is there ice on it and is there also frozen water droplets on the packages,if so the door was left open,you can shut the fridge down or unplug it,remove the food from the freezer,get a hair dryer and blow the hot air onto the back inside wall of the freezer mostly blow it into the open slots in the back wall,it will melt the ice that's in the air ducts,you'll see water dripping down,when it stops you can start the fridge and stick your hand in the top middle of the fridge section to feel if cold air is blowing in,all that it does is there's a fan in the freezer,all it does is blow the cold air from the freezer into the fridge section,if the door was open the warm air gets in and mixes with the cold air and it freezes up the air ducts and blocking them.if this isn't the problem open the freezer door,you should hear the fan blowing,if not you could have a bad fan motor,also put your hand on the back inside wall of the freezer,if there's like frost or snow on the back wall you have a defrost problem,a bad defrost heater,defrost thermostat or timer or board depending what the model is,but most of the time the problem is behind the freezer inside wall,or depending on your model there could be a damper in the fridge section,if it's stuck closed then the cold air won't blow into the fridge section.so first open the freezer door,listen for the fan,if it's blowing,check for frozen water droplets and ice up on the ceiling near the light and on the food packages,if you see this the door was left open,if the fan isn't blowing most likely it could be bad,then check the back inside wall for frost or snow on it,if there's frost on the back wall you have a defrost problem,most likely it will be a bad defrost thermostat or heater,you'll need to check them with a maeter,hope this helps,next time send the model number so i can look up your machine.
Sep 04, 2011 | Maytag Refrigerators
I have a sharp fridge SJ-P49N-SL. A recent power outtage in the area lasted 8 hours. When the power came back on, the fridge seemed to be ok. But, after 5-6 hours of operation, the freezer is not cold...
Checked Freezer Fan is working. Also checked defrost Fuse in freezer.
To checked freezer fan is working or not open freezer door press Door Switch and checked Cold air is coming from duct or not.
Aug 10, 2011 | Sharp Refrigerators
Fridge is warm, was collecting water inside. Freezer is working fine. Increased temp but not responding. It is a bottom freezer model
send the model number off of the fridge,if the freezer is working fine then no air is being blown up to the fridge section,all it does is blow cold air from the freezer to the fridge section so either the door was left open and this is very common with a bottom mount freezer or the evap fan isn't blowing or on some models there's a damper inside the fridge section,the damper door opens and closes to let cold air in,when it reaches temp. the door closes,sometimes the door gets stuck in the closed position or the open position and the fridge freezes or gets warm depending on where the door is.first thing open the freezer door,do you hear the fan blowing,if not you could have a bad evap. fan motor,next look at the ceiling and on the packages,do you see frozen water droplets,if so the door was left open and the air ducts are froze up from the warm air getting in from the door being open and mixing with the cold air freezes up the air ducts,also stick your hand onto the back inside wall of the freezer,if there's like snow or frost on the inside back wall of the freezer you could have a defrost problem,bad defrost thermostat,heater,timer or board depending on the model or last a bad damper,when you open the fridge door there are air ducts usually up top and in the middle you should feel cold air blowing in,this is your problem the air isn't making it into the fridge section.if the door was left open,unplug the fridge,remove the food from the freezer and with a hair dryer heat up the back inside wall of the freezer and blow the hot air into the air vent holes in the back wall to melt out the air ducts,keep heating it up until you don't see any more water dripping,you can see the water dripping through the vent holes.so let me know what you find,send the model number and we can go from there.look up near the ceiling in the fridge section on the right hand wall and you should see a tag with the model and serial numbers,send the full model number so i can see what you have in your machine.
Jun 12, 2011 | Maytag Refrigerators
I have an Amana side by side refrigerator. Last night I noticed water running from underneath and the ice cream in the freezer melting. I found dog hair clogging a vent and cleaned it. This morning the...
usually when the bottomof the freezer is cold and the top isn't it's the evap fan motor isn't working and all the cold air sits at the bottom.when you open the freezer door you should hear the fan running inside the freezer,also tried to look up your model but it didn't come up.open the fridge door,look up on the right and hear the cieling and you'll see a tag with the model and serial numbers,i just need the model number and i can help you better
Jan 30, 2011 | Amana ARSE66MB Side by Side Refrigerator
Have the bootom freezer. what is happening is the freezer works and the top part quits cooling and the fan quits working. we took everythinhg out and transfered to the outside frig. we unplugged the...
if you can hear the fan still blowing but no cold air coming up to fridge section a common problem with bottom mount freezers is the door gets left open and the air ducts freeze up and the air can't blow up to the top.turn the control off in the freezer.remove the top shelf and the door,check to see if there are any screws one on each side of the slide arms,if there are remove them and lift the door up and out,with a hair dryer melt out the ice by blowing the hot air up each side of the back wall,also if the back inside wall of the freezer is covered with ice or like snow then you have a defrost problem but if there's no ice on back wall do what i said and blow the air up the sides of the back wall through the vents until no more water is seen dripping through the vent holes,then turn the freezer back on and check to see if you feel cold air blowing in through the vents in the fridge section,if you feel cold air then you're all set,if not keep blowing the hot air up the sides until it's melted out.let me know what you find,you'll know if the door was left open,ice will be on the ceiling near the light switch and sometimes on the top of the freezer door.
However if fan has quit totally then it will have to be replaced since it is responsible for cooling the upper part of the fridge
Dec 28, 2010 | Amana ABB1927DE Bottom Freezer...
No air blowing into fridge, although we can hear blower. Freezer is working
Oct 25, 2010 | Amana ABB1927DE Bottom Freezer...
Freezer works, but the coolers not cold enough?
The fan in the freezer blows the air through the vent and it returns to the freezer through another vent at the bottom. Make sure both are clear and open.
Jan 10, 2010 | Refrigerators
Bottom of freezer/fridge only getting cold.
Thre is a fan inside the freezer which circulates the cold air around both the fridge and the freezer compartments.
You should be able to feel cold air blowing around the inside, particularly at the top of the freezer.
If the defrost thermostat fails open, the internal fan (depending on freezer) will stop and this can be the cause of the freezer being warm at the top and no ice.
You say the bottom of the freezer is blowing cold, but are you sure its blowing, as it can feel like a cold blow. Of course the fan could have failed or may be the defrost heater itself.
Have a look at this site for some useful trouble shooting
And a good site for troubleshooting and general info
Refrigeration Help Section, Fridges, refrigerators, not cold enough, frost free problems and how to test, noisy fan motors, clicking on and off compressors, door gaskets
Nige
Sep 26, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
114 people viewed this question
Top Sharp Refrigerators Experts
Vernon Taylor
Ilia Bichin
Are you a Sharp Refrigerator Expert? Answer questions, earn points and help others
