Question about Weather King 10AJA2501AH Air Conditioner
I have a Nordyne model GQ3RD-042K tHE CIRCULATING Fan is connected to the heat side 80 amps. I want to change to the A/C side 40 amps How do I do this. I have a wireing digram for this unit but do not under stand how to accomplish this.Can Anyone Help me.
  • mike bare May 11, 2010
    the fan is connected to this side so that it will come on any time that the heat is on is still only pulls about 3 amps in cooling mode if you have a digital stat it brings in the fan automatically the fan may be controlled by stack type switch that has a built in delay why the change needed? thanks
3 Suggested Answers
  • 10 Answers
SOURCE: electric heat strip installation and wiring
Need to make sure your wire size to the inside unit is large enough to handle the amperage, that you have a two stage heat thermostat.
Posted on Jan 04, 2008
relaga58
  • 158 Answers
SOURCE: Cir Fan on 80amp. A/C on 40amp. If 80amp is discon A/c has no fan
swap breakers
Posted on May 21, 2009
Need electrical schematic for Intertherm P3RA-024K
Hi Val
check this out maybe it helps.
http://www.manualslib.com/manual/507003/Nordyne-P3ra-030k.html?page=9#manual
Dec 03, 2015 | Intertherm P3RA-042K Air Conditioner
I have a Nordyne E2EB 020HA Electric furnace. There is barely any heat coming out of the registers. Fan is blowing constantly. When I heat the room up with electric heaters, and the thermostat hits desired...
The easiest way to check is with a clamp on amp meter. 5kw heater is approximately 20 amps. 10kw is 40, 15 kw is approximately 60. Measure the amps on 1 line (main power) wire entering machine. It could be a sequencer it could only be running on single stage it could be the element, the amount of heat, the fan speed, many things. But, checking the amps is a sure, easy way to tell if all of your heat is working. Keep us posted, we can advise.
Sep 04, 2017 | Heating & Cooling
What size wire and how does it hook to thr unit rpkb-036jaz
Look at rating plate on side of unit for Volts, Amps, Watts.
Volts x amps = watts.
If unit is 240Volts, then you need double-pole 240Volt breaker
If unit is 8500 watts at max power, then 8500 watts divided by 240Volts = 35 amps.
What size breaker for 35 amps?
When electricians figure load rating for breakers, they use the 80% rule.
40 amp breaker x 80% = 32 amp safe maximum load for 40 amp breaker. Use 8 gauge wire with 40 amp breaker.
50 amp breaker x 80% = 40 amp safe maximum for 50 amp breaker. I use 6 gauge wire with 50 amp breaker.
60 amp breaker x 80% = 48 amp safe maximum for 60 amp breaker. Again, use 6 gauge wire with 60 amp breaker.
How to connect wires to unit.
First of all, all outdoor HVAC units require power cut off located next to unit.
This lets the mechanic, or service tech turn power off to work on unit, even if the mechanic does not have access to main breaker box.
Next, open unit to see where wires connect.
If unit has wires, then connect both hot wires from 240 breaker to the wires inside unit. Connect bare ground wire to green ground screw.
If unit has terminals. The terminals will be labeled L1 L2. Connect each hot wire from 240Volt breaker to either one of the screw terminals. Then bare ground goes to green ground screw.
Copy following links for basic illustrations connecting wires to terminals, and to breakers, and selecting wire size.
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
Jul 21, 2012 | Rheem R-410A Complete Split System Heat...
Evaporator coil needs to be replace again. Installed w new manufactured home; 09/2005. Replaced 05/30/08. Needs to be replaced again 09/17/09. All due to leaks. Freon was added. Currently has small leak;...
the manufacture is only required to supply the part free of charge thru its warranty period. the installing company probably would only give a 1year labor warranty and honor the pparts thru the manufacture for 5 years but unless you paid additinal for an extended labor warranty i dont think you are going to have much luck. Make sure you change your air filters every 30 days a dirty filter is one of the biggest causes of evap coils prematurely leaking. Sorry wish i could be more help.
Sep 17, 2009 | Intertherm P3RA-042K Air Conditioner
Need wiring diagram to wire a Gibson GB5BM-T42K-B to a NORDYNE JT5BD-042K
you just need to follow the diagram that came with your new unit but its probably the exact same considering nordyne makes gibson andall thier parts are universal
Sep 10, 2009 | Heating & Cooling
I have a nordyne elec furnace just put in a new heat sequencer
You need to check the low voltage side to see if the t-stat is calling for heat. If it is, it is either the sequencer or a fuse to the heating elements (older model). But most likely the squencer. If you have a meter, you can check to see what side of the sequencer is burnt. Could also be a relay depending on the model number. If you get me the model number, I can send you a copy of the wiring diagram for the unit. This is the brand that I deal with.
Mar 02, 2009 | Better Living SPP High Efficiency...
Bad sequencer or fan relay?
does ANYTHING come on when set to heat?
Feb 28, 2009 | Heating & Cooling
Weather King 10AJA2501AH Air Conditioner Logo
293 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
