Question about Invacare Pronto M51 Power Wheelchair
Wiring diagram for pronto 51 speed control switch
Need a wiring diagram to show me what color wire goes on what terminal on the speed control switch.
2 Suggested Answers
wcdoc1953
  • 280 Answers
SOURCE: I NEED A WIRING SCENATIC FOR AN INVACARE PRONTO m6
I assume you need a wiring schematic for an M61. The circuit board schematics are proprietary and not available. The component schematics and interconnects for switches and wiring harnesses are available, as are the parts diagrams and drawings. Please clarify your specific need and issue.
Posted on Oct 24, 2010
De 407 maytag dryer how do i find a wiring diagram
the Maytag dryers would have the diagram either INSIDE the control panel, OR on the back of the control panel. Neither are color coded as there never was a color coded diagram ever printed. The diagrams do list the color of wires and show where they start and terminate. That is all a service tech would require to troubleshoot. If the diagram has been removed, you could try an online search.
Jul 03, 2014 | Frigidaire GLER341A Electric Dryer
Fan motor is slowing down and not keeping the desired temperature
The circuit diagram for the standard control model shows the blower has a two-speed motor, connected directly to the power line in "Cool" mode, or connected to the temperature control in "Cook" mode. When the blower slows down during cooking, switch it temporarily to "Cool" mode. If it goes to normal speed, the problem is with the mode switch contacts or the wiring terminals between the fan mode switch and the temperature control board, or the control board itself.
If the speed does not change, check the wiring terminals at the speed switch common terminal (I assume your problem occurs in both low and high speeds). If you find tarnished, loose, or burned terminals, clean, repair or replace as needed. (In extreme cases, a loose terminal will cause the wire to overheat, damaging the insulation, oxidizing the terminal and causing a high-resistance condition that will reduce the voltage available to the motor.) If the connections are all good, the motor bearings are probably getting sticky at high temperatures. Let the oven get hot enough for the blower to slow down, then shut it off and check the blower bearings while wearing oven mitts.
May 12, 2014 | Southbend SLGS-22SC Gas Double Oven
Fan switch for fan light combo
Unfortunately, there is no standard color coding for ceiling fan wiring. You note in your video that the replacement switch has an L(ine) terminal and there should be 1, 2, and 3 terminals as well for controlling fan speed. Check the switch you are replacing for similar marking. If you are in luck, you can replace by L and numbers rather than colors. I checked my entire file of fan installation information and nothing more explicit is provided
May 24, 2013 | Photography
Wrong window switch installed.
I don't think even a wiring diagram will show the terminal locations. You may have to sort it out from a wiring diagram for the windows for your car. Each window will have it's own color code for up and down. What a nightmare! You could be at it for awhile till you get it right. The lengths and hi-jinks some people will do on their cars! I would find a like car at a junkyard, snip the connector off with just enough wire to show the color (or longer if you just wanna splice it into your wiring), bring it home and match your wiring from it. Probably only a factory service manual would actually show the terminal locations. Good luck, Odel, and you didn't even say what kind of car you had, though it made no difference to me.
Sep 14, 2012 | Cars & Trucks
How to wire my intermatic GM40 to a two speed pool motor
Copy following link for illustration showing GM40 controlling 2-speed pool pump.
http://waterheatertimer.org/How-to-wire-GM40-timer.html#pool
Same wiring applies for 120Volt or 240Volt.
Voltage, Wire colors and wiring illustration appear on pump name plate.
Be sure to set dip switches before applying voltage to timer.
Do not test wires by sparking against terminals. Use a tester.
Jul 14, 2012 | Intermatic Hardware & Accessories
How i can do the instalation
1) Need more information.
Heres some help to get you started, then you add a comment and fill in details so I can give accurate answer.
2) You posted under Paragon 7008-00 timer.
3) People post under Paragon when they have Tork, so I need exact model number and what voltage you have and what Load you are trying to wire.
4) Also what terminals appear on timer, since any timer can be in a box that is marked 7008.
Then add what color wires you have coming from breaker box, what size breaker, and if same breaker is going to supply voltage to timer and to Load, and what color wires are going to Load.
5) Open following link to identify timer for sure, and see manual and wiring diagrams.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#7000
6) Typical wiring diagram for 7008 showing one set of NO NC terminals:
http://waterheatertimer.org/images/Paragon-7008-00-timer-wiring-350.jpg
7) 7008 timer has 120Volt clock motor. So power to terminals A and B has to be 120V.
But timer can still control 120V or 240V loads.
8) According to manual, 7008 timer has 2 NO (normally open) terminals that are OFF when timer is OFF
Timer also has 2 NC (normally closed) terminals that are ON when timer is OFF
9) Both sets of terminals reverse when timer turns ON.
10) NO and NC terminals are frequently used for continuous-operation 2-speed motors, for example.
You do not want power to both speeds at same time, or motor will burn out. So low speed is connected to NO terminal, and high speed is connected to NC terminal. This way the motors windings are kept separate, and either low speed is ON or high speed is ON.
11) Another example of NO NC terminals could be store lighting. When store closes, the timer turns off exit signs and store-room lights inside store, and at same moment timer turns on burglar alarm and outdoor lights. In this example the timer controlled 4 different circuits: exit signs, store-room, alarm, and outdoor lights. With 2-NO and 2-NC terminals, that is possible.
Apr 15, 2011 | Paragon Indoor Electromechanical Timer...
I would like to use the 1301 switch but my house circuit has 2 black wires and 1 red wire which terminals do I connect the wires to on the switch?
I don't know the copper-brand 1301 switch
Internet photos of the 1301 show that it has two screw terminals, and a green ground screw
Switch with 2 screws is a single-pole switch. (plug green ground screw)
Sounds like you are replacing 3-way switch with 3 screws. (plus green ground screw)
3-way switches control hallway lights, with switch at each end of hallway.
I think you need to buy a 3-way switch.
How to wire 3-way switch:
Bare ground always goes to green screw
The key is the dark-colored screw.
Old switch has dark-colored screw >> mark this wire.
Attach this wire to dark-colored screw on new switch.
Other two wires go to either screw.
Nov 19, 2010 | Cooper Wiring Devices "COOPER WIRING"...
Low/High Switch wiring for Hayward Superpump
I do not read anywhere that you have a 230V DPDT switch which you will need in order to select the high or low speed. You will have 6 terminalas on the switch. Line connections usually go to the middle set. Put put sides of one pole to the common terminal and put one of the other posts to the hi and the other to the low terminal. I prefer to use am on-off-on switch so the switch in the middle turns off the pump. Flip it one way for hi and the other for low. If you post your stock number from the two-speed motor I could give you a more accurate diagram if you need it. Generally, 1 is common, 2 hi and 3/4 low.
Apr 26, 2010 | Pool & Spa
Invacare Pronto M51 Power Wheelchair Logo
23 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
gnshome
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
