Question about Shimano Dura Ace Pd 7810 Spd Sl Pedals
How to remove pd 7810 pedals
How to remove Shimano dura ace Pd pedals
  • 18 Answers
SOURCE: Shimano Dura Ace Brake lever chatter
A few suggestions:
Lube/replace your cables and housings. If your housings are getting rusty on the inside, it will prevent the tension in the spring of the calipers from returning the brake levers to "home" position. Also, dura-ace levers have an internal return spring that is prone to breaking or coming off its peg (this can't be repaired without disassembling the lever).
Make sure your calipers are clean and move freely, and have sufficient spring tension to return to "home" position.
Be careful not to get lubricant on the braking surfaces, obviously.
As an experiment, remove the wheel and pinch the calipers together with your hands. Then, check to see how loose the brake lever is.
Posted on Jul 01, 2009
johnegan84
  • 73 Answers
SOURCE: require assembly schematic for shimano dura ace
log onto Shimano.com, it is probably the limit screws (the two screws that limit travel) or you have a faulty ratchet in the lever, try the shimano website anyway they have great tutorial and manual support
Posted on Mar 27, 2010
dunnbiker
  • 8546 Answers
SOURCE: looks like the dura ace rear is pressing too hard
Sounds like the B-screw adjustment.
http://parktool.com/repair/readhowto.asp?id=64
Posted on Jun 21, 2010
Coachphil
  • 347 Answers
SOURCE: dura ace brifters very sticky
You can squirt them with a spray lubricant (bicycle lubricant) to free them up if it is just a dirt issue, you need to pull the brake lever to expose the internal gearing mechanism, don't take anything apart.
If your shifter part is sticky, this usually clears things up. If it does not make trace through the derailleur cable and make sure it's not the cable hanging up instead of your shifter. Replace the cable and housing as necessary.
If its the brake lever, smae check of the cable system but also check the brake itself. The lever will feel sticky when there is a snag in the cable or if the brake is no longer returning with the same spring tension.
After that you can have them rebuilt or replaced. Depends on which model you have 8, 9, 10 (7800, 7900) as too the exact recommendation.
Posted on Dec 30, 2010
Coachphil
  • 347 Answers
SOURCE: Hi, Would like to get my hands on a shimano dura
EBAY - that is the only place where you can purchase an 8spd Shimano group these days. That group is over 12 years old so finding one at a shop or on-line retailer is very unlikely to happen.
All the pieces are frequently available on EBAY, you may have to buy each piece separately, but it can be done. Did it myself just last year.
Posted on Apr 15, 2011
Removing spd pd-5700
with the tool on you should be pedalling forwards to remove them.
Jun 18, 2013 | Shimano 2013 105 PD-5700 SPD SL Pedal
Require assembly schematic for shimano dura ace shifter . left shifter lever failed, will not activate the front derailler, disassembled, found nothing broken, require advice regarding proper reassembly...
Nov 14, 2009 | Shimano Dura Ace Front Derailleur Fd 7800
A few suggestions:
Mar 26, 2009 | Shimano 2008 Dura-Ace BR7800 Rear Road...
Shimano Dura Ace Pd 7810 Spd Sl Pedals Logo
27 people viewed this question
Top Shimano Cycling Experts
Michial Gueffroy
John Egan
John Egan
Eric Hidle
Level 1 Expert
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
