Question about JVC Car Audio & Video
Kd-s39 brown wire connection
I know the brown wire on this harness is for a cell phone terminal, I just don't have anything to connect it to. I wonder if I need it, since I don't know what a cell phone terminal is and must not have one.
  • 143 Answers
SOURCE: Wiring compressor
The two terminal cap is only for the new fan motor. Connect the compressor wire back where you found it, on the 3 terminal cap. It's the terminal marked, "herm". The "common" terminal on the 3 terminal cap must still be connected to one side of the 220 power at the contactor. One side of the 220 goes to the common on the compressor. The other side of the 220 goes to the run winding on the compressor AND the common terminal on the 3 terminal capacitor.
Posted on Jul 22, 2008
SOURCE: Install JVC Car stereo
no power
Posted on Jul 27, 2008
SOURCE: JVC Wire Harness
i need to match up color wire to my 1998 honda accord
Posted on Oct 22, 2008
SOURCE: How to replace the Terminal Cover on top of the Extension Wand
I saw this in another FixYa post
it tells midway down how to get access to the wand fuse (which has the two-prong terminals)
Comment posted on Feb 09, 20082bubbles ok here we go.. fine a small file that will fit the holes at the bottom of the wand and break the file so that the flat end fit into the wand. please make sure the wand is not plug in to anything. now put it into the hole and try to clean it out gently not too hard or you will damage the contacts. after that grab a needle nose pilers and very gently press the contacts. not a lot or it won't fit back into the power-mate. ok now for the top of the wand. if you look at the wand where the button is to extent the wand. on each side you will see a small clip. with a small flat head screw driver push into the clip at the point closer to the wand tube. it will pop out. make sure to check the clip to see how to put it back in. after both clips are out you will notice a that the clips left a gap. the back part of the wand or cover will now slip off. push it toward the gap. then up. after removing the cover. you will see a ribbon strip which is attached to the prongs or fuse .you can remove the fuse and then clean the contacts. please be careful. once this is done you then put it all together and try it out. the fuse is a part that you can buy at sears if you have to. let me know if this helps you out. if it seems like too much just take it to sears and ask them to replace the wand fuse for you instead of replacing the whole wand. hope this helps .
Posted on Jan 08, 2009
jackiaria
  • 350 Answers
SOURCE: Need a new wiring harness for my Dual XDMR7710
Look in your local phone book yellow pages under stereos for a local (not big name) stereo installation store (there will be one) and go there.....you will thank me!
jack
Posted on Feb 22, 2009
I have a jvc kd-s39 head unit but I lost the units harness,I wana DYI. So I wud like to know wat power goes pins n speakers pins
A new harness is available online at nearly every retailer. Amazon, ebay, metraonline, eyc. Connecting wires to the pins without any accidental shorts is difficult at best. Spend $10 and get a new harness.
Sep 08, 2016 | JVC Car Audio & Video
What is the brown wire on JVC KD sr60 wire harness
That's the "mute" wire. If you ground that wire, it will shut off the audio output for the head unit. It's typically used in combination with add-on Bluetooth units or hands-free phone kits. In a typical installation, you wouldn't connect it to anything, and you'll want to make sure it's insulated.
Aug 04, 2015 | JVC Car Audio & Video
JVC KD-S39
The wire is for the purpose of controlling the brightness of the display. The wire probably goes to a 12 volt positive lead, but it may also go to a remote knob of some type. In that case if you hook it up to the lead it could cause damage to your unit. I would simply leave it disconnected and if you can read the stereo display okay then keep it that way. If you can't read the display then you might want to connect it to a FUSED 12 volt positive lead.
Sep 22, 2017 | Car Audio & Video
Connecting battaries for a Rascal Autogo
When you put the second battery in the case paying attention to polarity position, the longer wire will go to the top connector. If you have a voltmeter you can identify which wire has 12 volts on it. It should be the brown wire but verify anyway. This wire has to be connected to the NEGATIVE terminal of the second battery in order to get 24 volts to the scooter. The remaining wire connects to the positive terminal of the battery.
May 04, 2017 | Cars & Trucks
Aeg competence e-4100-m, pnc940316609, s-n 31280933 Problem: I have just succesfully changed torpedo shaped component cable tied in to the wiring loom. It had 2 white and 2 blue wires coming. BUT... I...
If there are no other connection ports, and you only disconnected the three, it is possible that (if this is an aftermarket wiring harness) the third was put in for similar units with an additional option of some sort, and is not needed for your model. However, I highly suggest referring back to the place of purchase, as well as the manufacturer to find out for sure before plugging the unit in and using it.
Please let me know if you need further assistance,
carsandcomps,
Guru, Premium Expert, Phone Support (Chat) @ Fixya.com
Jun 19, 2011 | AEG B2100-4 Electric Single Oven
1998 buick park ave. rear window defroster not working. fuse is good, has anyone replaced the black box located next to rear window where element plugs into along with the antenna. element on window is not...
Rear Defogger Inoperative, But Heated Mirrors Operate Correctly
1. Connect scan tool. Turn ignition switch to RUN position. Turn rear defogger on. Using scan tool, display BCM
outputs. If rear defogger is being requested on, go to next step. If rear defogger is not being requested on, go to
step 10).
2. Ensure ignition switch is in RUN position. Remove rear defogger relay from rear junction block, located on center
right rear of passenger compartment, under rear seat. Connect test light between ground and defogger relay
harness connector terminal F3 (Brown wire). If test light illuminates, go to next step. If test light does not
illuminate, go to step 11).
3. Connect test light between ground and defogger relay harness connector terminal A2 (Red wire). If test light
illuminates, go to next step. If test light does not illuminate, go to step 12).
4. Connect test light between defogger relay harness connector terminals A2 (Red wire) and B3 (Purple wire). If test
light illuminates, go to step 13). If light does not illuminate, go to next step.
5. Disconnect rear defogger positive and negative feed bus connectors. Connect a jumper wire between defogger
relay harness connector terminals F3 (Brown wire) and A4 (White wire). Connect test light between ground and
positive feed bus connector terminal "A" (Black wire). If test light illuminates, go to next step. If test light does not
illuminate, go to step 8).
6. Connect test light between positive feed bus connector terminal "A" (Black wire) and negative feed bus connector
terminal "B" (Black wire). If test light illuminates, go to next step. If test light does not illuminate, go to step 9).
7. Repair open in Black wire between rear defogger and ground. Recheck system operation.
8. Repair open in Purple wire between rear junction block and heated backlight antenna module. Recheck system
operation.
9. Check for proper terminal contact at rear defogger connectors. Repair as necessary. Recheck system operation.
10. Check for proper terminal contact at BCM. If terminal contact is okay, replace BCM. Recheck system operation.
11. Repair open in Brown wire between rear junction block and instrument panel junction block. Recheck system
operation.
12. Repair open in Red wire between rear junction block and underhood junction block (located in right front corner of
engine compartment, between battery and strut tower). Recheck system operation.
13. Connect test light between defogger relay harness connector terminals F3 (Brown wire) and A4 (White wire). If
test light illuminates, go to next step. If test light does not illuminate, go to step 16).
14. Reinstall defogger relay. Disconnect BCM 32-pin Pink connector C2. BCM is located behind right side of instrument
panel, near rear of glove box. Using DVOM, check voltage between ground and BCM harness connector C2
terminal A3 (White wire). If any voltage is present, go to next step. If no voltage is present, go to step 17).
15. Repair open or short to ground in White wire between rear junction block and BCM. Recheck system operation.
16. Check for poor connection at defogger relay terminals. If connections are okay, replace defogger relay. Recheck
system operation.
17. Check for proper terminal contact at BCM. If terminal contact is okay, replace BCM. Recheck system operation.
Feb 25, 2010 | 1998 Buick Park Avenue
I need to know how the alternator is wired to the vehicle in a 1986 pontiac Fiero. mostly the small plug not the main red power. Were do the two small gray wires connect
Per the shop manual those wires are brown and red. So pull back the black wire cover and check the color of those wires. On the V-6 the small red wire connect to terminal 2 , small brown wire connect to terminal 1. On the I-4 the small red wire connect to terminal S , small brown wire connect to terminal L
Sep 13, 2009 | 1986 Pontiac Fiero
How to
Please follow the following instructions 1)Use a wiring harness equipped with an adapter plug for faster connection and installation.Disconnect the car battery while installing electronic equipment.
2) Make a note of the wire colors and connect the power supply wires to the DEH-45DH as follows:
Orange wire to the constant 12Volt
Yellow wire to the switched 12Volt
Black: ground wire
3) Connect these wires to control display functions on the DEH-45DH:
Attach the gray wire to the wire marked control panel illumination.
The brown wire connects to the dimmer.
4) Make the front speakers connections following this color scheme:
Left front positive (+) tan wire
Left front negative(-) Gray
The light green wire connects to the positive (+) terminal of the right front speaker.
Connect the dark green wire to the negative (-) terminal of the right front speaker.
5) Make these rear speaker connections:
Brown wire to the left rear positive (+) terminal
Yellow wire to the left rear negative (-) terminal
The dark blue wire attaches to the right rear positive (+) terminal
The light blue wire connects to the right rear negative (-) terminal
Hope this helps
Thanks
Smith.
Sep 09, 2009 | Car Audio & Video
Color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Here's the wire colors for your KD-AR560:
Black = Ground (to vehicle chassis)
Yellow = Constant 12V (power)
Red = Accessory (to vehicle accessory terminal)
Blue/White = Remote turn-on lead (to remote amp)
Orange/White = Illumination (to vehicle light control switch)
Brown = Cell Phone terminal
White = Left Front Speaker positive (+)
White/Black = Left Front Speaker negative (-)
Gray = Right Front Speaker positive (+)
Gray/Black = Right Front Speaker negative (-)
Green = Left Rear Speaker positive (+)
Green/Black = Left Rear Speaker negative (-)
Violet = Right Rear Speaker positive (+)
Violet/Black = Right Rear Speaker negative (-)
Hope this helps.
Apr 24, 2009 | JVC Arsenal KD-AR560 CD Player
Car Audio & Video Logo
18 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
