Question about Toshiba Satellite A215-S7422 Notebook
The compyter has no power at all.
I went to plug the computer in and it had no lights or anything on. It worked fine a week ago. Can someone help?
  • j_wd1982 May 18, 2009
    thank you so much it worked.
  • 749 Answers
Remove the battery and reinsert it.
make sure the laptop is plugged into the wall when you try to start it..check power cable to make sure the light on the ac adaptor is getting power...
Post again if that doesnt reset it.
Regards..
Posted on May 18, 2009
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 75 Answers
Please replace your battery and try it again ....... and if it does not work, return it to the shop where you bought it ....... i believe you can have this solved
The head of my scanner (Canoscan lide 200) don't want to move and so don't want to download anything. The scanner is connected by usb to the computer. I haven't drop it or anything and it was working fine...
Power down the scanner and unplug the USB from your computer. Plug the USB back in and turn power back on. Occasionally USB connections lose their minds and quit working.
Good luck.
Semper Fi,
Z
Feb 01, 2018 | Canon CanoScan LiDE200 Flatbed Scanner
My LCD's not working!!! but my PC works fine!!
The problem you have is caused by a shorted power supply board. This is a easy repair if you can solder. We have a step by step repair guide posted on our web site at: www.ccl-la.com This should get you back going again. if you have any questions just let us know.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Feb 19, 2010 | LG L196WTQ Monitor
Cant acees files on maxtor basics
try to use it via usb to SATA converter then u will see if it really work or not , if not try to use the same usb to SATA converter on another computer if doesn't work then ur harddisk controller is broken and u need to give it to its company to recover ur data
Jun 06, 2009 | Maxtor Hard Drive
Panasonic TH-42PX75U won't turn on
Your powerboard is damaged, and need to be replaced.
Sometimes it appear the TV is working again with no problem but it is only a matter of time for the board to get completely damaged.
May 30, 2009 | Panasonic TH-42PX75U 42 in. Plasma...
Monitor will not turn on- was working fine a week ago!
Replace it as they are so inexpensive.
Fleabay has a lot of choice.
Feb 27, 2017 | Acer AL1703 17" LCD Monitor
Our Wii has no power no light no nothing
Okay, I had this problem also, it made me freak out, considering it was only 1 week old! what I did, and it worked, is
1. unplug every wire connected to the system (wires to/from wall, to sensor bar, and to/from TV)
2. unplug every other thing connected to it (i.e. memory cards, older controlers, etc...)
3. let it stand off in the dark for a couple of minutes (I reccomend 5 minutes or so)
4. plug the wires back in
5. turn it on
6. put anything else back in (i.e. the memory card)
If that doesn't work, or if this keeps happening, I reccomend bringing it back to the place you bought it (Walmart, Best Buy, Circuit City, etc)
, b/c they can give you a new one, or your money back. However, the warrenty could expire, or not even exist if you bought it online, or if you've had it too long.
I hope I helped you!
-Tori Toothpaste
Jun 04, 2008 | Nintendo Wii Console
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen went gray or stopped working, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Mar 20, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Asus laptop wont turn on
Not saying you are stupid but are you sure the batter is charged plug it in and try again if that does not work if when you power in on and the power lite lights up there might be on one of the F keys at the top of the keyboard it might say,CLD,LED or something like that try the clor that is push the button like FN or the key that is the same color as that and push the one that has the FN or the colored on and then hit the, CLD,LED and see if that works if not you might have to take it to someone.
Feb 17, 2008 | ASUS A6U Notebook
Toshiba Satellite A215-S7422 Notebook Logo
101 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
