Question about Canon imageCLASS MF6590 Copier
How to print envelopes
I am trying to figure out how I print the address onto a envelope from my printer. I cannot seem to figure it out.
  • 390 Answers
SOURCE: MP460 printer--problem w/ envelopes
You seem to have clogged nozzles/printhead. Take out cartridges, do a thorough clean down where cartridges sit, the printhead, even the roller as well. Run your printers own cleaning maintenance before you do it manually with cleaning solution. Problem should be gone when you reinsert cartridges. Don't froget to reset ink levels and cartridges. good luck!!!
Posted on Aug 31, 2007
  • 39 Answers
SOURCE: CANNOT PRINT ENVELOPES
you can only print paper not envelope
Posted on Feb 09, 2008
  • 79 Answers
SOURCE: Envelope prints the wrong way
This may be a very inconvenient solution but if your desperate then try it. The label you are trying to print : Take a snapshot of it using the print screen button on your keyboard and then paste it into paint. Cut out everything except the label then use the page setup feature in paint to make sure its in the right spot. Dont forget to choose envelope in the page setup and in the printer settings.
Posted on May 02, 2008
efs_perpends
  • 1996 Answers
SOURCE: Cannot print envelope on MX310
Note:
  • Be sure to set the printer driver setting properly. If you do not, the address will be printed in the wrong direction.
  • It may be required to change the paper size option to 'Envelope' in File Page Setup menu.
    Note:
Printer Driver Settings:
1Select Envelope in Media Type.
  1. Select the size for envelopes.
    * In Windows, select DL Env. or Comm. Env. #10 in Page Size.
  2. * In Macintosh, select DL Envelope or #10 Envelope in Paper Size.
  3. Select Landscape in Orientation.
Posted on Apr 10, 2009
SOURCE: Printing DL envelope on Canon Pixma iP4600
its not the problem of your way of operation, its the limitation of of the printer.
Posted on Jul 10, 2009
How to print envelopes on canon mf6590
The way I do it to create in Word 2007 envelops. While a letter is still displayed look for Create button and select Create envelops. You select the dimensions of the envelop and the way it is fed. You will need to try a few times to be sure it comes out correctly.
Dec 27, 2013 | Canon imageCLASS MF6590 Copier
Printer will not print the address onto the envelopes, it just keeps flowing them through
the envelope size is not selected in the printer properties. check the settings in the print properties and select the paper type as envelope and size of the envelope.
Oct 01, 2010 | Pitney Bowes AddressRight DA300 Printer
Can't print DL envelopes on a Pixma iP4600
Hi ...
If you like to print DL envolopes, check the below 3 points and I am sure you will be able to print from your printer.
Prepare the printer:
  1. Open the Rear Tray and pull out the Paper Support. Put your finger in the rounded indent of the Paper Support and pull it out until it stops. (See <1> in Figure 1 below.)
  2. Open the Paper Output Tray. Put your finger in the rounded indent beside the Paper Output Tray and open it gently. (See <2> in Figure 1 below.)
  3. Open the Output Tray Extension. Open up and set the Output Tray Extension completely by pressing down the hollow on its front side. (See <3> in Figure 1 below.)
  4. Adjust the position of the Paper Thickness Lever. Set it to the right when printing on envelopes or T-shirt transfers, and left when printing on any other type of paper. (See <4> in Figure 1 below.)
    * Figure 1
  5. Load the envelope.
    1. Load the envelope against the right side of the Rear Tray. (See <1> in Figure 3 below.)
    2. Load the envelope with the address side facing UP and the rear flaps DOWN on the left. (See Figure 2 below or, <b> in Figure 3 below.)
      * Figure 2
    3. Pinch the Paper Guide and slide it against the left side of the envelope. (See <2> in Figure 3 below.)
      * Figure 3
      Note: Reset the Paper Thickness Lever to the left when you finish printing. (See <3> in Figure 3 below.)
Preparing Envelopes to Load:
  1. Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
  2. Remove any curling by holding the edges diagonally and bending them gently.
  3. If the edges of the envelope are inflated or are curling, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
  4. Ensure that no curl or puff exceeds 1/8 in. (3 mm).
Paper Type
Precaution
Envelope*
DL / #10
Set paper with the flap closed.
Unsuitable Envelopes:
  • Envelopes with an embossed or treated surface
  • Envelopes with a double flap or pressure seals
  1. Select Envelope in Media Type.
  2. Select the size for envelopes.
Note:
Don't forget to vote if this helps ... Cheers :)
Jul 27, 2009 | Canon PIXMA MX310 All-In-One Printer
How do I print addresses on #10 envelopes?
    1. Click Tools on the menu bar in Microsoft Word, and then do one of the following:
    2. Word 2000: Click Envelopes and Labels .
    • Word XP: Click Letters and Mailings , and then click Envelopes and Labels .
    1. Type the Delivery and Return address information.
    2. Click Options .
    1. On the Envelope Options tab, set the following options:
    2. Envelope size : set to match the loaded envelopes.
    • S. only: if you want to, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
    • Return address: for Size 10 envelopes only, set the Return Address position to .8 inch in the From left section.
    • Click the Printing Options tab and verify that the following settings are selected:
      • Select the Feed Method option that shows the envelope on the far right side with the short edge first. For example, in the graphic below, the fourth image shows the envelope in the correct position.
      • Select Face down .
      • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is to the right, select or clear Clockwise rotation .
      • Click OK , and then click Print .
  • Jul 22, 2009 | HP Officejet 5610 All-In-One InkJet...
    How to type an address onto a std bussiness envelope
    Insert the envelope vertically. In your word processing program you should have an option for printing envelopes; usually in the TOOLS menu. Your program will figure out how to center the text.
    Jun 22, 2009 | Epson Stylus C120 InkJet Printer
    Print name and address onto envelope
    Start by selecting the information, i.e,, highlight, then "CTRL+C" When you open the envelope window click into the address box, and use "CTRL+V".
    In Word you simply select the information you wish to print, then click on the "Tools" tab, select "Letters and Mailings", and follow it to "Envelopes and Labels". When you open the last tab the information (address) will already be there.
    Jun 19, 2009 | HP LaserJet M1522n MultiFunction Printer
    Envelopes won't print
    where do i insert envelope to print address?
    Apr 26, 2009 | HP Officejet 5610 All-In-One InkJet...
    Printer keeps printing the same address on envelope
    You need to restart the printer some times happens if the buffer gets full.
    Dec 15, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
    Addressing Envelopes
    i need an instuction manual for BROTHER DCP 115C all in one anyone got one spare
    Oct 30, 2007 | HP LaserJet 5200tn Printer
    Canon imageCLASS MF6590 Copier Logo
    13 people viewed this question
    old marine
    old marine
