Question about Philips Televison & Video
What size are the 4 TV stand mounting screws for my 42 inch Philips LCD TV, Model # 42PFL3603D/27?
  • 15 Answers
SOURCE: tv stand screws
Check the kitchen drawer next to the fridge for the screws !!
When you get new screws, use lengths 1/2".. any longer and you might hit something inside.
Don't know why this is posted under IS-LCDTV26.. I would pull a screw from my 26" and measure it, but it's most likely different than your 42"
Posted on Sep 06, 2008
Highdefjeff
  • 124 Answers
SOURCE: need help with TV calibration for philips
Try these, Contrast: 53 Brightness: 56 Color: 45 Tint: 2 Sharpness: 2
Color temperature: Off
Dynamic contrast: Off
Digital Natural Motion: Off
DNR: Off
Color enhancement: Off
Active control: Off
Posted on Mar 03, 2009
SOURCE: Lost screws for for my 32" polaroid LCD TV stand
M5 X 18MM
Posted on Aug 19, 2009
budmrtn
  • 11361 Answers
SOURCE: screw size to bolt panasonic 32 inch lcd into
Metric M5 or M6, they should come with the mounting kit.
Posted on Dec 23, 2009
budmrtn
  • 11361 Answers
SOURCE: LG 42" wall mount screw size
Metric M5 or M6, when you buy wall mounting bracket, it will came with a bag of screws for attaching the TV to the bracket. All my wall mounting brackets for my TV come with screw.
http://s807.photobucket.com/home/budm/allalbums
Posted on Jul 01, 2010
Testimonial: "Thank you! We'll head to Lowe's tomorrow to pick up the appropriate size screws. We just moved into a new home and they left the wall mount up for us, but did not leave any of the extra screws that went with the mount. Thanks again! "
Why type/size screw fits in the tv base stand?
Depends on the make and model of the stand. Best to ask where it is sold or serviced. Or take another one out and have it matched up.
Nov 08, 2014 | Philips 42PFL3603D/F7 42-Inch 1920 x 1080p...
What size bolt screws into the back of the TV to mount a wall mount
42" will more likely to use Metric M6 screws (canbe M5 but not likely), the length of the screws will depend on the thickness of the mounting plates. When you buy wall mounting kit, it will come with mounting screws. You can get Metric screw from HD or Lowe's for about 50 cents each.
I get my wall mounts from Costco and they come with a bag of Metric screws fro mounting.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Aug 06, 2011 | Philips 42PFL3603D/27 42 in. LCD TV
I downloaded lastest firmware v1.15 for my Philips 42PFL3603D/27 LCD TV. Unzipped it and put it on an empty 8GB jump drive then plugged it into the TV. I unhooked everything to the TV, turned it off,...
when you unzip the file you may need to put it into a file called "upgrades". Try an empty USB stick (size should not matter) and put the autorun file into the upgrades file.
Feb 11, 2011 | Philips 42PFL3603D/27 42 in. LCD TV
Screen goes black tv stays on. Turn off and on and TV's fine.
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Mar 20, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
42PFL3603D/27 TV was dropped or hit and broke the tv screen upper righ corner. Tv works, has spiderweb look on screen
can't be fixed becase the entire panel is broken. it is cheaper to replace, because wit labor, parts, ect it would be to expensive
Jan 22, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
What is the remote control code for philips 42pfl3603d lcd tv
Hi - I had the same question and found it here:
www.universalremote.com/resources/pdfs/UR2-CBL-CV04.pdf
Some TV brands have multiple codes associated to it. You must try each one individually until one of them does the job.
This worked for me beautifully on a brand spanking new Philips 42'' LCD.
Jan 02, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
Televison & Video Logo
622 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
