Question about Quantaray QTB-9500A TTL Flash
Instructions - Quantaray QTB-9500A TTL Flash
Where can i get a replacement battery for a Ohsen wr30m Watch?
In order to help people set the ohsen sport watches easlier in the right way, our company (www.360sportwatches.com) write the ohsen watch manual instruction in English for all the ohsen watch users, hope this page is useful for you to set your ohsen watch, this ohsen watch manual operation is suitable for almost all the Ohsen digital electornic watch, also it is suitable for the ohsen analogue quartz digital electronic sport watches, for details ohsen watches models, please have a look at the following content!
Ohsen watch manuales instruction description:
A Key = Light
B Key = Mode
C Key = Start
D Key = Reset
In normal time to show, press the button to enter B mode, click Settings when choosing D Key respectively, minutes and seconds, C key to adjust.
Hours, minutes, seconds, month, day, week;
12/24 hour clock selection
* Daily Alarm Clock
Daily alarm only " Hours" and " Minutes" to choose
The whole point timekeeping
* Running Seconds
From 0.04 seconds start running time;
The Longest 23 hours 59 minutes 59 seconds
* EL black light
Any mode, press the A light EL backlight for 3 seconds
* Use 3V batteries
Running Second Mode:
Press B button click into the race second mode, press the C key to start timing, the timing of the state, press the D key to pause time;
At the time of state, then C key, stop the clock, press the D key to this state would be zero time.
Press B button to return to normal time mode;
Alarm setting mode:
Regular time mode, press the B button 2 times into the alarm set;
Press C key to the "alarm" whole point of time" to set " open" and "off";
Press D key to adjust the hours, minutes;
Press C button to adjust the number of selected;
Press B tutton to return to normal time statues.
At the same time in any state, this button will issue a Bi Bi sound;
Time, date setting mode:
In normal working mode, press the B button 3 times to see the second in the flashing, then press the C key, " seconds" will be zero;
Press D key to select each "Hour" " Minute" " Day" " Week" set;
Press C key, you can adjust the number;
Press B button to return to normal time status;
12/24 hours;
Under normal travel time; Press B button 3 times to enter time setting mode, then second in the flashing, second place in the transferred into " H" when the table show has been converted to 24 hours system; when the position becomes"O" on the afternoon of adjustments; seconds into "R" for morning; "P" for PM.
Apr 01, 2015 | Watches
THE WORD INSTRUCT WHAT IS THE SUFFIX!?!
instruction, instructively, instructor, instructing, instructional, instructed are some
Oct 17, 2013 | Computers & Internet
Missing knex 6 foot ferris wheel instructions. can you please send them to me?
Here are the instructions from Instructables.com You can join the site for free and download a PDF version of the instructions from there, or just view them step by step.
http://www.instructables.com/id/Knex-6-foot-ferris-wheel-Full-Instructions/
May 08, 2011 | Toys
Help Please ASAP. NEED Assembly Instructions
lbehrman
Here is the instructions on their site.
http://www.woodcrestmfg.com/instructions/instructions.htm
Hope this helps
Issken
http://www.fixya.com/users/issken
May 08, 2010 | Baby Gear
Microprocessor instruction set
An instruction set is a list of all the instructions, and all their variations, that a processor (or in the case of a virtual machine, an interpreter) can execute.
Instructions include:
  • Arithmetic such as add and subtract
  • Logic instructions such as and, or, and not
  • Data instructions such as move, input, output, load, and store
  • Control flow instructions such as goto, if ... goto, call, and return.
An instruction set, or instruction set architecture (ISA), is the part of the computer architecture related to programming, including the native data types, instructions, registers, addressing modes, memory architecture, interrupt and exception handling, and external I/O. An ISA includes a specification of the set of opcodes (machine language), the native commands implemented by a particular CPU design.
May 26, 2009 | Computers & Internet
Breadmaker TR520: Page 5 instructions, #4 says "Before first use, operate Bread maker on FAST BAKE to burn off mfg oils. Follow instructions outlined in the OPERATIONG INSTRUCTIONS section of this...
I ignored the instructions which told me to follow instructions which were left out of the booklet. I just washed the breadpan and paddle with hot water and dish detergent, dried them, and made bread. Everything A-OK.
Sep 12, 2008 | Breadman TR500 Bread Maker
Programming problem
Program flow control structures obey ceratin rules. They start with a keyword and end with another keyword
For
Instructions
EndFor
If .....Then
Instructions
Endif
If .....Then
Instructions
Else
Instructions
Endif
If..... Then
instructions
ElseIf......Then
instructions
Else
instructions
Endif
Loop
Instructions
Endloop
While
Instructions
EndWhile
Each ot these structures is called a block. If one of the keys words is missing, the program generates a syntax error.
Hope it helps.
Feb 25, 2008 | Texas Instruments TI-89 Calculator
Quantaray QTB-9500A TTL Flash Logo
79 people viewed this question
Top Quantaray Cameras Experts
Steve
Doberman
Are you a Quantaray Camera Expert? Answer questions, earn points and help others
