Question about Spectralink (PTB400)
Bad PT on Spectralink 3000
We had a power spike Friday and th system went down. I got everything to work well now except for half of my base stations won't 'listen verify' and I have a bad listed in my PT slot.
A/C unit went down with no warning. Any clues???
Check power connection to the wall, check fuse box to make sure the fuse switch that handles th A/C unit hasn't been tripped, check all GFI outlets. If all else fails call your HVAC/Air conditioner repair company.
Sep 07, 2014 | Heating & Cooling
The LCD display no longer works on my Tripp Lite Omni 1000 LCD. Also, half of the power outlets on the back of the unit no longer work.
Be aware.
My Tripp LIte Omni 1000 LCD almost caught on fire.
I had been experiencing a spike in my power bill to the tune of 1000 Watts an hour for everything running - 24x7. I started the survey of all my equipment; TV 162 Watts; Fridge 228, etc. but none of these devices are on all day and night. I finally mapped out all the outlets and lights and was about to begin the survey. Other than the flickering lights, one big clue was that my TL's lcd was displaying a spike in voltage DOWN to 95 or so, the relay would click, etc.
I decided to begin my survey and use my second TL to help me see which circuit was faulty. When I looked at the LCD, it was blank. I pushed the ON button and all the devices plugged in went OFF and then I saw smoke coming out of the back. I quickly unplugged everything and then watched my meter. When this UPS was plugged in, there was about 1000W used per hour; I monitored it for 10 hours; 400W were used (total).
So... not only was it a fire hazard, but it sucked up 900W or so an hour.
Nov 28, 2010 | Tripp Lite (OMNI1000LCD) UPS System
Deregister a ds6322-4 without the base
for the Vtech cordless phones model DS6322-4 models
In the handset press
*331734# and the menu button, yur handset will be deregistered.
Enjoy unlocking :-)
May 06, 2010 | Vtech Lands Phones
Spectralink PTB400 internal error
Correcting Spectralink Errors Below are instructions on performing a “soft test” which will correct any internal error 8 and 4444-444C messages on your Spectralink phone. To aid you in educating your staff you may view the following Word document showing the step-by-step instructions. Please feel free to print and post this document where the Spectralink phones are kept on your floor. Soft Test Instructions
  1. Power off the phone.
  2. Press and HOLD the volume key (VOL) and the power key at the same time (the phone will chirp and display the serial number.)
  3. Now…release ONLY the power key (phone will vibrate and make a long tone.)
  4. Now release the volume key (the display will have a lot of black boxes and ZZZZ’s – you will also see the bottom of the display showing “msg”, “bat”, etc.)
  5. Count to three and then power off the phone.
This “soft test” is to correct only certain internal error messages. When the phone is experiencing a correctable error the display will read “internal error 8” or “internal error 4444-444C”. For all other internal errors the phone will need to be taken to Teleservices, NE-165 to be replaced.
As per : http://depts.washington.edu/uwmcdir/spectralink.html
Mar 16, 2010 | Spectralink (PTB400)
The caller id on my vtech cordless phone stopped coming in clearly, why?
Try unplugging your base station (where the power and the telephone cable plugs into) leaving it unplugged, get your telephone set and take out the battery.
Put the battery back in your phone and power up your phone.
When the phone is back up and running, plug everything back into the base station... and test your caller id.
The telephone's base station sometimes needs a reboot. There are power spikes on the telephone line every-so-often and can do funny things to your telephone set.
I hope this helps.
May 02, 2009 | Lands Phones
Lamp light blinks 3 times shuts down
The CLS problem. Im thinking that at least you made a visual inspection of the power suply and the capacitors around it. Then if everything normal in the area then the microdisplay (inside the ligth engine) can be damaged. (when the tv is working normally the microdisplay sends a pulse to turn on ballast and lamp finally.
The sweetkyman: when the fan is bad th tv shuts down imm. (if you unplug the fan when the tv is working normal the computer detects the overcurrent system works and shuts down the set) when a fan is all dirty and tons of dust on it the tv tends to work but after some hours the tv shuts down.
Dec 20, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
System pin reset
try using all zeros usually 5 zeros
Dec 01, 2008 | Siemens Gigaset 2420 Phone
Avaya IP 400 Digital Station
You might have to DTE the Unit. If you dont know what that is, call a pro.....
Jun 05, 2008 | Computers & Internet
JVC TH M505 Subwoofer not working
i need to find the wire that connects from the subwoofer it has like little spikes inside the medal part and the spikes broke off
Jan 12, 2008 | JVC TH-M505 System
Spectralink (PTB400) Logo
Top Spectralink Computers & Internet Experts
David Payne
David Payne
Are you a Spectralink Computer and Internet Expert? Answer questions, earn points and help others
