Question about Kenmore 62062 Electric Dryer
Locate door switch
Checking or replacing door switch help! like a diagram or location assistance
  • 5,911 Answers
Re: locate door switch
If you open the operator console, there should be a wiring diagram located inside for technical assistance.  Make sure you unplug the dryer before servicing. get to the door switch.  You will need to perform the following steps:
1.  Remove the operator console.  It is either removed by inserting a putty knife under the each front corner of the console and pushing in to release a retaining clip.  Or, there will be a screw on each side holding it down.
2. Once the console is removed. The top panel must be removed.  If there are three 1/4 inch screws under the console holding it in place, you will need to remove them first before the top will come off.  The top panel will then slide towards you and then lift up.  Some top panels will simply slide forward and come off without removing any screws.  Double check to be sure.
3.  Located along the front of the dryer under the top panel will be a series of wires.  One set will go to a lamp socket and the other set of wires goes to the door switch.  NOTE: Some dryers have a lamp socket in the rear of the unit away from the door opening.  The door switch will have a connector plug.  Take a small screwdriver and gently lift up on each side of the plug and it will pull apart.
4.  On the side of the plug still attached to the door, connect a multimeter across the pins of the plug and take resistance readings while opening and closing the door.  You should see a change in resistance from open to short.  If the resistance does not vary, the switch is bad.  Another method you can try is to jumper the wires on the section of plug that is not connected to the door to see if the unit will operate with the switch by-passed.
Make sure you unplug the dryer before servicing and only energize it if you wish to attempt the by-pass method of testing.  I do not recommend bypassing the door switch as a fix, either.  The dryer will not shut off when you open the door, which means you would have to rotate the timer or unplug the dryer to stop it.
Please post any responses back to this thread instead of making separate postings.   It makes it easier to assist you.
Let me know if you need further assistance.
Posted on Oct 18, 2007
0 characters
3 Points
Admiral dryer diagram
see the diagram attached. God bless you0820a8a7-650e-434c-9d8f-b3496e966b0a.jpgb78ebf48-e554-415b-82cd-0004e93afadd.gif
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
Read more:
Sep 30, 2013 | Dryers
CTD85 tumble dryer: power is getting through to the machine but absolutely nothing happens
If there is power then the door switch is probably broken. first make sure that there is power to the machine. The door switch is tested with power off, accessing switch contacts and reading Ohms with a multimeter. When door is closed the switch must have continuity, reading zero or few Ohms. With door open the switch contacts read infinity (circuit open).
If the door switch is OK, test power cord, main switch, wiring harness, motor and timer.
Here diagrams. Click on the pictures to enlarge:
This is a link to all the spare parts available for your Hotpoint ctd85a tumble dryer.
See also : Tumble dryer Video tutorial help.
Sep 18, 2011 | Hotpoint Dryers
Locating heating element kenmore 80 series and a safety switch
If you are looking to purchase replacement parts, you can purchase on line at any of the following websites:
Use your model number for your search criteria. Prices vary between these sites, so shop and compare. The first three sites listed also have helpful exploded view diagrams to assist in parts location/identification.
If you are trying to determine WHERE these parts are located on your dryer, please post back with a complete model number (located on a nameplate around the door opening) so I can determine how your dryer is configured.
If you have questions, please let me know. I hope this helps you.
Jan 14, 2010 | Kenmore 63942 Dryer
Machine does not turn on
Hi, UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
Please let me know if this help or if I can assist you further.
Jul 03, 2009 | Kenmore 73952 Gas Dryer
Dryer wont react when hit start button
HI, Sounds like Normal 0 , UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
a fuse. Try this,
May 30, 2009 | Whirlpool LER4634J Electric Dryer
Hi if this a whirlpool model, try this.
Normal 0 Hi, UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
May 21, 2009 | Dryers
Not working, theres power but nothings working? belt maybe, where is the belt located? If not what els could it be? and where would that be located?
There should be a trouble door in the back so you can see the belt. If the motor is not running, I would check the door switch first. The site has parts and help.
May 05, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer won't start
It sounds like you have a blown thermal fuse. has a replacement kit available. Just type in your model number and the kit can be located under the "Heater" heading as item number 5 (part #LA-1053). The kit contains the hi-limit thermostat and thermal fuse. Replace both components at the same time. NOTE: Only one of the thermal fuses will be used, however. One is for a GAS dryer, while the other is for an ELECTRIC dryer. They are marked accordingly.
To access, you will need to remove the dryer front panel. This is accomplished by inserting a putty knife into the seam where the dryer top and front meet (about 2 inches in from each end) and pushing in to depress the release tabs. Disconnect the door switch wires and the front panel comes off and can be set aside (make sure you label the wires). With the front panel removed, the dryer top panel lifts up. The heating element will be located in the center-rear of the dryer behind the dryer drum.
If you require further assistance, please let me know. I hope this information is helpful to you.
NOTE: The website also includes helpful illustrations for component location and wiring diagrams. The correct wiring diagram depends on your dryer serial number. If you have questions about this let me know (send me the serial number).
Jun 17, 2008 | Dryers
No heat in Maytag Electric Dryer
There should be a wiring diagram inside the operating console. Locate the thermal fuse and/or thermal cut-out and ensure they check good. They both should read close to a short if good. They are mounted adjacent to the heating element. If you have trouble locating the diagram and/or need further assistance isolating the problem, please post back with the dryer model number (located on the back of the console) and I will locate some diagrams to see if I can assist you further.
May 28, 2008 | Dryers
Kenmore 62062 Electric Dryer Logo
113 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
