Question about JVC Car Audio & Video
Can't find sub levels on the menu
I can't find the sub level on the select menu to activate the subwoofer.
  • hoyzee1 May 11, 2010
    What brand is it?
    Problem Solver:
  • 6 Answers
On some jvc models they don't specify if it has subwoofer level controls. On the one that i had i had to hold down the audio button for like 3 sec then it switched me to bass treble and subwoofer make sure that you have your rca jacks plugged into the subwoofer outlet also
Posted on May 20, 2009
How do i connect a subwoofer to my stero technics su-800mk2 amplifier
You would connect any non-specific subwoofer according to its needs:
passive = to an amplifier channel;
active (self-powered) = per its manual and the capabilities of the source.
Given the lack of a specific subwoofer facility on the SU-800, you need a sub that can be driven by full-range speaker level output. Its manual would describe the procedure. Keeping in mind that most active subs are pretty much the same speaker-level-connection-wise (if they allow it), you could find just about any manual and wit would get you running.
http://archiwumallegro.pl/technics_sua800_mk2_wysoki_model_krakow-998303435.html
Jul 06, 2011 | Audio Players & Recorders
I have the Subwoofer plugged into the output and have it turned ON but it's still not working!
It only drives a self-powerd sub.
The manual...
http://www.retrevo.com/support/JVC-RX-8010VBKC-Receivers-manual/id/315dj079/t/2/
Page 17:
Setting the Subwoofer Information
Register whether you have connected a subwoofer or not.
Before you start, remember....
• There is a time limit in doing the following steps. If the setting is canceled before you finish, start from step 1 again.
On the front panel ONLY:
1. Press SETTING repeatedly until "SUBWOOFER" appears on the display.
The display changes to show the current setting.
2. Press CONTROL UP / DOWN to select "YES" or "NO."
• Each time you press the button, the display alternates between "YES" and "NO."
YES: Select this when a subwoofer is connected.
NO: Select this when no subwoofer is used.
Note:
You cannot use SUBWOOFER OUT ON/OFF on the front panel (see page 14) and adjust the subwoofer output level (see below) when "SUBWOOFER" is set to "NO."
Then continue with setting its relative level and other things.
Feb 06, 2011 | JVC RX-8010V Receiver
I'm not sure how to hook up a powered sub woofer to my rx4109 reciever
It doesn't have a specific low-frequency or subwoofer output.
Depending on your unnamed subwoofer we may be able to work something out. Any sub should be able to work with a full-range Line Level feed.
If you use a Line Level input you won't have volume control of the sub through the receiver.
That would be available at either Tape Out or Aux Out. Just run an RCA pair (or combined to one male out if that's what the sub amp requires).
Whichever one you use, you won't be able to activate that function for listening as it would remove the input to the sub amp.
If your sub accepts speaker level High Level inputs you could drive it with speaker outputs and yoi WOULD have some volume control, assuming the sub had a way to match its initial volume to your other speakers.
Of course, the manual for your sub might explain some of this, too.
Jan 10, 2011 | Sherwood RX-4109
When I hook up the speakers in the back to the left and right side for the in and out, do I connect the front or rear speakers. do the speakers connect to the subwoofer first then to my receiver or the...
I was trying to find an owner's manual or picture of the rear panel of the sub, but had no luck. The subwoofer is a powered type - or "active" speaker. This means it has a built in amplifier. These active subs usually provide for one or both "low level" and "high level" inputs. Low level signals are usually carried by shielded coaxial cables and have RCA type plugs on the end. The low level is also called "line level". This is an un-amplified signal that might be heard on cheap earphones - but that's about it. It is similar to the output of a tape deck, DVD or phonograph. These signals require an amplifier to be heard. If you have a sub woofer output on your receiver or amplifier, you could run a patch cable between the low level input on the subwoofer and the subwoofer output of the amp or receiver. You receiver or amp may call this output "low frequency effects" or similar. The front and rear speakers would then connect directly to the receiver or amp's corresponding connections.
If you lack low level outputs on the amp or subwoofer, you'll need to run speaker wires from the amplifier or receiver's front left and right speaker output terminals to the subwoofer's high level input terminals. High level signals are speaker connections or amplified signals. These are typically connections that accept bare wire connections. The front speakers would then connect to the subwoofer's front left and right speaker output terminals. The rear speakers connect to the amplifier.
I hope this helps - and good luck!
Nov 24, 2010 | Cerwin Vega AVS-632 System
Which is the best way to hook up a Subwoofer?
Last two questions first - YES, use an RCA splitter to share sub line level out between two subs and use one at the subwoofer end to share that line with both inputs on the sub.
Either attachment scheme you describe would work.
Not being a big fan of conversion/deconversion for no real purpose, I would avoid stepping the high-level input down to line level for use by the sub's internal amp, run RCA to the sub(s) and keep them physically and electrically independent of anything else unless cable routing is facilitated somehow by daisy-chaining other speakers from the sub(s).
Jan 17, 2010 | KLH PSW8100-8 Subwoofer
No Subwoofer output and it is selected.I have tried every thing to get output. I am using Sony Blue ray into hdmi input on the amp and the KLH ASW10-120 is plugged into the normal sub out connector and I...
Make sure that the level is set high enough to be audible either by the volume control on the sub and/or the sub/lfe level on the setup menu. Then make sure that you also have surround sound output selected in the blu ray player setup menu.
Jan 02, 2010 | Sony STR-DG810
Too much bass...low end
Hi, have you tried adjusting the "subwoofer level", and or the "subwoofer cut" controls? Every sub I have ever seen has at least the level control on the back. The "cut or crossover" control determines the frequency at which the sub will start to respond. Additionally, you may need to access the appropriate menu on you reciever and adjust the "low frequency effects" (LFE) output level (assuming you have connected your sub to the reciever's sub output jack.
Hope this helps.
Jun 16, 2009 | Wharfedale SW150 Subwoofer
Want to connect my RCA sub to my yamaha htr-5940 reciever
Subwoofer needs to be enabled through menu on Yamaha. LINE OUT might be turned off or Subwoofer volume set to low or off... (-db level) kinda thing...speaker wires are usually always live etc...
Feb 03, 2009 | Yamaha HTR-5940 Receiver
Connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • Nov 22, 2008 | Audio Players & Recorders
    Subwoofer-no output
    ther should be a diagram in the left hand corner of display of speakers hooked up, make sure sub is shown right under the left right (and possibly) center speaker icons. under adjust, there is a subwoofer volume level. Under settings there is sub (yes, and no for on and off) there is a sub crossover frequency, and i believe there is also a "LFE" att, which is another subwoofer level.
    May 23, 2008 | JVC RX-8020V Receiver
    Car Audio & Video Logo
    69 people viewed this question
    Top JVC Car Audio & Video Experts
    Radames Pagan
    Radames Pagan
    xxxxxx xxx
    Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
