Question about Hotpoint RGB528PEAWW Gas Kitchen Range
Replacing Igniter on Hotpoint RGB528PEAWW Gas Kitchen Range
Hello all.. I have read info on replacing the igniter in a gas stove, but Im not sure of how it applies to the one I have. The burners at the top of the stove work fine. Neither my over nor the broiler heats up at all. The burner light comes on but the gas doesnt light. Now this seems to be a bad igniter from what I have read here. But my problem is I dont think my oven has a seperate igniter for the oven and broiler. Do you generally have 2 seperate igniters or does some ovens only have 1? Also would the replacement instructions that are posted on this site be the same for replacing an igniter in all ovens? Im new at all of this so I hope I am making sense??
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 63 Answers
You should have a broil glow coil at tol and one on bottom. to access the bottom, open the door and look to the back on the oven floor. ther should be a srew one on each side remove and lift bottom up. you should be looking at the glow coil. i would also remove the pan drawer for access.it would be abnormal for bth the broil and bake to fail at the same time. if this is the case i would confirm power is leaving control to the selected glow bar. they shoul pull about 3.2 amps. then i would focus on the valve. which is opened by the amp draw of the bar. one wire on the valve is common and the other feeds from the control through the valve to the glow bar
Posted on May 19, 2009
Hotpoint gas range rgb745 electric igniter not working
Make sure igniter is getting power before you replace it. Also check the switch that feeds the igniter.
For parts go to attached. Search Over 2 1 Million Appliance Parts
Oct 07, 2015 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint stove igniter
Here is the new igniter to order for that unit.
There is also a video on that parts page to show you how to make the repair.
Feb 19, 2013 | Hotpoint RGB528 Gas Kitchen Range
Igniter is working oven wont lite
You need to make sure the gas lines are intact and not clogged. If there is a strong smell of gas make sure you shut off the gas on the range and you should also make sure you shut off the feed directly to the stove.
Jul 04, 2012 | Hotpoint RGB532 Gas Kitchen Range
Ignite pilot light on hotpoint gas range
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 25, 2010 | Hotpoint RGB745 Gas Kitchen Range
Gas oven, broiler and stove top work, but bake does not
heatman101
Nov 07, 2010 | Hotpoint RGB745 Gas Kitchen Range
I have a problem with my Hotpoint Range; the range top works, the broiler works, but the oven does not! The oven igniter seems to take a couple of minutes to ignite the gas. It comes out quickly but then...
heatman101
Oct 07, 2010 | Hotpoint RGB745 Gas Kitchen Range
Oven igniter glows red, but no gas fire.
The oven igniter is glowing so that tells me the circuit is sound, the oven control is working, and the oven safety valve is ok. That means only one thing. Weak igniter. The igniter must draw 3.2 amps in order to open the safety bi-metal inside the valve. Bumping or tapping on the stove will make the oven light off. Solution replace the igniter. I have repair photos HERE
Feb 03, 2010 | Hotpoint RGB535 Gas Kitchen Range
The dial on my maytag gas stove shorted out
sounds as if one of your spark switches ( mounted on the gas valve itself) has shorted out, repalce the switch assembly, comeswith all foure sp[ark switches, easy enoough for you to do
Nov 30, 2008 | Maytag MGR5765QDS Stainless Steel Gas...
Hotpoint RGB528PEAWW Gas Kitchen Range Logo
653 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
