Connecting wireless headphones to a 42" lg lcd tv
Is there a way of connecting headphones to the tv
My last tv had a phone jack but I don't see one on this one
may be I am missing something simple or may be I need different type of headphones
I would be great-full for any advise
  • 1 more comment
  • Anonymous Jan 25, 2008
    I also have a LD LCD tv with no place to hookmup earphone.
    hooking a jack onto te back dodnt work.
  • Anonymous Feb 17, 2008
    The Vizio sales rep told me I could connect wireless headphones to the GV42L, so of course I bought a wireless headset. However, I don't see a jack for the headset. Could someone resolve this problem?
  • shopper2020 Dec 12, 2008
    no headphone jack on 46 lcd sharp tv how to connect headphones?
  • 5 Answers
SOURCE: Sony Bravia 40
go to your remote contol ( menu )
then you go to the option set up.
then you go to headphones and you can set the volume louder.
You will see that it works fine.
Greetings from Holland Gesinus
Posted on Aug 15, 2010
SOURCE: Connecting laptop audio to tv
i had the same issue with a thinkpad T61 which i was connecting using VGA and a audio jack going straqight from the headphone socket to the back of tv.
I had picture but no sound and i found that once connected the issue could be solved by rotating the projection setting on the laptop(Fn+F7). Basically switched back to laptop only display, then back to laptop and projector display again and teh sound just kicked in.
i think it's related to the projector setting on the laptop rather than an issue with the tv.
Posted on Nov 01, 2007
  • 42 Answers
SOURCE: How do I connect my Laptop computer to my LCD TV?
Every laptop has at least a VGA (computer video connection) and s-video cable port. A VGA cable is preferred if you want to be able to read text on your LCD TV. Check to make sure that your LCD TV has a VGA connector. It's a port that accepts a 15-pin connection so it's pretty easy to spot if it's there. It's just like a computer monitor cable if that helps. Should be able to find it at any local retail store that carries computers. VGA or RGB cable.
Posted on Apr 12, 2008
Agent Jon
  • 100 Answers
SOURCE: I can't get my wireless headphones to worl wiht my LG 42PG
Salutations Derek23,
Unfortunately that is correct, most newer televisions do not come with "Audio Out" or headphone jacks. Its almost assumed that you would be connecting the television to a receiver or audio source of some type that would have these types of connections.
Sorry to break the bad news.
Go Ahead. Use Us.
Posted on Jun 24, 2008
  • 5568 Answers
SOURCE: LG 42'' TV has no sound but great picture. How do I get the sound?
You shouldn't need anything plugged into the accessory jacks to get local sound from your set. Go through the main setup menu and check audio settings; they may be set to turn off the internal speakers to send the sound to a home theatre that you apparently don't have. Most sets have that as a selection and supply L-R audio for an external system and mute the internal speakers.
FYI: The three connectors you mention are coded as follows:
Red - right channel audio White - left channel audio Yellow - composite video (contains synchronization signals and video)
These may be input connectors (for external VCR/DVD decks) so check your owner's guide to verify.
Posted on Nov 23, 2008
Headphone jack in tv has stopped working when putting speakers or headphones in is making a loud clicking sound. Is there anyway to connect speakers or headphones to the tv without using this jack? Have...
What type of TV, IE: Make and Model. If you have a SCART socket, then you can probably use the audio output connections on the SCART cable to connect to your stereo.
One thing to check is that your TV isn't muted! I know it sounds silly, but lots of people have inadvertently muted their TV's and not realized it.
Nov 14, 2017 | Electronics - Others
I have a set of T 912 wireless headphones. I am unable to set them up on the TV. I am using the white and red cables from the base station to the TV audio red and white. Do you have any instructions on...
The audio jacks on the TV are most likely inputs, not outputs. They're meant to take the audio signal from something like a DVD player, along with the video input on another jack, so you can play it through the TV. There isn't an audio signal coming out from those jacks, and if you connect your headphone transmitter to them all you'll get is silence. Almost all sets now have at least one set of AV inputs, but most don't give you outputs. The manufacturers figure the TV is just a display device, and not a signal source.
Unfortunately, there isn't any easy way to connect your wireless headphones if the TV doesn't have audio output jacks or a headphone connector. If you're comfortable with soldering and willing to do some modification to your TV, it's possible to add a headphone jack. Most people don't want to start tinkering with their sets, though.
If you're using your TV on a cable system without a converter box and the cable hooks right to the set, you're out of luck unless you're willing to add a headphone jack as I mentioned before. But if you have a cable converter box, or you're using a satellite receiver or other set-top box, you can use your headphones with those. These devices typically have direct audio and video outputs available on the rear panel, and you can use that audio output to feed the headphone transmitter.
What most people do these days is use a home theater receiver along with the TV. All sources (the cable box, DVD player, video game console, audio CD player, etc.) connect to the receiver, and the receiver's audio and video outputs go to the corresponding input jacks on the TV. This way, the TV is just the end of the line. The receiver also would provide an output for the wireless headphone transmitter. This system offers some advantages. You'll be able to connect the proper speakers to enjoy surround sound when not using headphones. And you'll be able to use your wireless headphones with the tuner and audio sources like music CDs when not watching TV.
Aug 14, 2011 | Audio Players & Recorders
#1. Where can I get a free copy of the Manual for RCAWHP150C Wireless Headphones; #2. How can I us with TV that has not headphone connection?
for Q1 try this one
for Q2 this one should do the trick
Mini StereoJack to Left and Right RCA Plugs
hope that helps...
Aug 07, 2011 | RCA WHP150C Consumer Headphones
How can I get headphones to work with my Symphonic WF203 TV?
This set doesn't have a headphone jack, nor does it have RCA audio output jacks. Without one or the other, you're out of luck connecting headphones to this TV.
I remember a product some years ago that allowed adding headphones using a small microphone placed in front of the speaker. This was hooked to a little amplifier that ran the headphones so the volume could be independently controlled. It was marketed as a way to let "hearing-impaired" family members listen to TV shows without needing to make it uncomfortably loud for others. I haven't looked, but something similar might still be available. It's cumbersome, though, and needs power, plus maybe being costly if you find one.
It's possible to add a headphone jack, but you need to know how to do electronic soldering. Find a spot on the case where you can make a hole and mount a headphone jack, then wire it to the speakers. If you want the headphones to cut off the speakers when plugged in, you need a switching jack, and the speaker wires need to be cut and connected to the correct terminals. The switch built into the jack then disconnects the speakers when the headphone plug is in. If you don't need to turn off the speakers it's a little easier. You just need to wire from the jack to the speaker terminals. I've added jacks on quite a few sets. If you don't feel up to it and don't know anyone who is, you can see if a TV shop (if there are any left in your area!) would do it. (The shop I used to work for charged about $20, including the jack, but that was over 10 years ago now.)
Good luck, and thanks for using Fixya!
Jun 12, 2011 | Symphonic WF20D4 TV
I have an lg 32ld350. I plugged in headphones into it as to not annoy anyone with the tv and when i was done i unplugged them and now i have no sound unless i use headphones. Even with them unplugged it...
Turn off ur tv.Tries take the head phone steal jack plug it in and unplug it out do this like three or four times.Tries the tv menu audio resetting again.The audio should return.Don't used ur tv head phone again the input jack socket it have problems,just lower ur tv volume for not to annoy anyone.Or used the tv head phone jack socket again will damage it for good, and will never get sound out throught ur tv speaker again.
Apr 16, 2011 | LG 42PX5D 42 in. Plasma HDTV
What type of audio connection is needed to connect headphones to the Sony Bravia, model KDL-40S5100
The problem wiht this TV is that it does not have headphone output jack (spec:
You will have to use:
1) AUDIO line out jacks (RCA RED and WHITE JACKS) of the TV connected to small headphone amplifier to drive your headphone.
2) you will have to trun off the TV built-in speakers using on screen audio set up.
3) Set the TV audio line out to be VARIABLE instead of FIXED level if you want to use the remote control to control the level of the audio output feeding the headphone amplifier.
As you can see, it is real simple setup.
Example of headphone amp;
Same one at AMAZON:
Notes: you will need RCA plugs to mini-stereo phone jack adapter since this unit does not have RCA INPUT JACKS.
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors:
Learn about bad caps:
Capacitors kit: he can make you a set of caps.
Or, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jan 12, 2011 | Sony Televison & Video
Sylvania TV Headphone Jack Problem (Specifically for a Model TVK199, but I suspect the answer might be fairly generic): The headphone jack on this TV is totally messed up. I'd like to replace it with...
If the audio jack [headphone] has two black bands then it is probably stereo. The first reason you tv phone jack is messed up is because you have an internal ground problem. You may have to resolder this...hope the board is not cracked. I would not advise you to jury rig an outside connection. To do so, you may short the audio chip and that is another no audio at all. Find someone who knows something about tv repair.
Jan 07, 2010 | Televison & Video
Coby mp4 705 4GB headphone issues
Hey why don't you see if you can pry the two halves apart like an ipod, and then re solder the headphone jack. Or try wedging something around the edge of the jack to hold it where you want it. try this first. here is a link to youtube search.
Jan 09, 2009 | Coby MP-705 Digital Media Player
To connect my Logitech X540 to my Hitachi L42VP01U
the suggestion to my guess is right,audio input to the line out jack on tv for it too work you would need the head phone jack witch would go in to auido in an split to RCA Audio out (TV) Witch meaning, adapter to convert regular RCA type (red/white) connectors to a standard mini plug (Headphone type) Hope it Works
Oct 14, 2008 | Logitech X-540 Computer Speakers
Oct 12, 2007 | Protron PLTV-32 Television
Televison & Video Logo
2,845 people viewed this question
Top Televison & Video Experts
