Question about DSMiller DS Miller Inc. Equivalent of HP - COMPAQ DV5-1005AX Laptop AC Adapter (839431878168)
Pavilion dv 5 black screen won't start
Computer won't boot, bios lights flashing
    New Friend:
Just replace the battery with a new one
Posted on Dec 30, 2013
Hp pavilion dv9000 takes a long time to get past the bios screen. It won't boot of dvd either??
Check BIOS boot options and assign local hard drive as first for faster boot. This is also where you set CD\DVD as first to boot from disc. Look for F Key press on start up. It will be shown on screen. These can vary.
Many HP machines also have a boot menu option during boot. Again an F key and may vary.
Sep 22, 2012 | HP Pavilion dv9000z Notebook
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Aug 25, 2012 | Gateway MP8708 Notebook
My 320 gb WD will install xp but when i remove the disk for the reboot there is only a flashing
check that your BIOS is set to boot from that drive in the BOOT options portion of the BIOS screen, F2, F12 or DEL when the computer is first switched on should get into the BIOS.
Apr 26, 2012 | Western Digital Computers & Internet
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
May 01, 2017 | HP Pavilion dv5020us Notebook
My hp dv 7-1134 us will not turn on. When it start the boot up process the fan will suddenly stop and the dvd drive will make a noise as if its trying to start but wont. The screen stays black and wont...
ran for 2 days on AC pack only?
battery out, be clear there... it must run on ac alone .
the BIOS is next
is the screen with text?" or really is 100% black all the time.
remove the hdd if it makes abnormal noise, and check that BIOS screens work , even take out the DVD drive.
battery is already out. they short. get it out .
then push the bios keys, ESC?
this PC laptop has CCFL lamps that go dead.
so do the flash light trick first. while calling up BIOS.
http://www.pcdied.com/monitors.html#flashlighttest
Aug 27, 2017 | HP Pavilion Computers & Internet
Computer scrren goes black after login
you may need to format
have you done a virus scan
have you changed anything in bios
restart press F7 then choose to boot with harddrive
Jan 09, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Hp dv9000 will not start up. blue lights are go
you get a black screen right, nothing at all then no bios, no logo, nothing at all?
Do you get any beep codes and if so in what order?
did you try different ram?
First try to plug your laptop to an external monitor. If it works, you screen is bad, if it doesn't you probably need a new motherboard.
Dec 23, 2008 | HP Pavilion dv9000z Notebook
Hp pVILLION DV 1000
This error message may appear when the computer BIOS is set to boot from a network and cannot find a bootable operating system on the network or on any of the storage devices included in the notebook PC's boot path.
The following steps are for most HP Pavilion and Compaq Presario Notebook PCs. The boot order can be configured on the Advanced tab in the BIOS settings menu. The steps to modify the boot order may vary depending on the model of your computer. On most HP notebooks the boot order can be configured using the following steps:
  1. Turn on or restart the computer.
  2. While the display is blank, press the F10 key to enter the BIOS settings menu. NOTE: Some notebook PCs use the F2 or F6 key.
  3. Use the right and left arrow keys to select the Advanced tab.
  4. Use the up and down arrow keys to select Boot Order .
  5. Follow the on-screen instructions to change the boot order.
Reset the boot order to the default settings Use the following steps to reset the boot order to the default settings:
  3. Press the F9 key to reset the BIOS to default settings.
  4. Press the F10 to save the changes and exit the BIOS settings menu.
I think it will you to fix your problem.
If still have problem then tell me more about it.
Thanks
Iqbal
Mar 18, 2008 | HP Pavilion Elite M9060N PC Desktop
My hp pavilion dv1000 is off
Remove the battery. Turn off the Power.
Hold the power button down for 10-15 seconds.
Try to start again.
If that doesn't help, you may need a shop.
Jan 22, 2008 | HP Pavilion dv1000 Notebook
DSMiller DS Miller Inc. Equivalent of HP - COMPAQ DV5-1005AX Laptop AC Adapter (839431878168) Logo
57 people viewed this question
Top DSMiller Computers & Internet Experts
David Payne
David Payne
Are you a DSMiller Computer and Internet Expert? Answer questions, earn points and help others
