Question about Boating
Outboard motor charging systems, do they exist or do i need to periodicly charge the battery for my boat
  • Anonymous May 26, 2009
    my 1986 mercury outboad 90 hp in line 6 cyl dos`nt charge my battery is this a stater problem
  • 5,581 Answers
Look at your ID plate and get the model number of your motor. Then contact the Johnson dealer and see if your model comes with a charger, be it alternator or magneto. Many use systems similar to riding lawnmowers and they do not need charging.
Posted on May 21, 2009
We have no power but battery appears full charge cannot raise/lower motor or start motor--any thoughts
Hi Jim:
I'm confused.
Raise or lower motor sounds like a boat outboard leg.
Cars and trucks section???????????
I'm guessing that you first need to confirm that the battery is fully charged.
Just an idea, but boats often have an isolation switch that has to be turned on before power is available to the engine. Follow the positive lead from the battery.
Please reply as a comment to this post so I can try to assist.
Cheers
May 08, 2016 | Cars & Trucks
Does my 1979 johnson outboard charge the battery thru the powerpack?
Some models charged through a Magneto, but see if you can find the 1979 Year Manual. I have a 1979 engine myself in a 15Hp which is a Manual start(no battery) and I have a Sailhorse Johnson 8HP which has an electric port and is Manual start. I believe the 8HP would charge a battery as on a Sailboat the running lights needed power. The 8HP could power the lights directly.
Johnson offered options for electric start in lower HP units and options in charging systems to contain costs. You might get a better answer from someone by listing the HP of your motor. I was the original owner of the 15HP and remember the 9.9HP and others in the same Sales brochure. The Sales brochure may advertise more about the charging systems.
Jul 21, 2014 | Light Outboard Motor Boat Bass Fishing...
I have a 65hp suzuki outboard motor wont start just makes clicking noise and tilt aint working now motor was running season before
try installing a fully charged battery or charge the battery for 24 hours then jump start the boat from a car
Jun 24, 2014 | Suzuki Service Manual, 2 - 65 HP Outboards...
Hellow!! well my boat wouldent start it just didnt have enough power or juice to start so now ive got my battery on charge . It was dead of cource but i want to know why ? its a 95 40hp evinrude! This...
It has a stator, it throws an alternating current to the battery, there is not an alternator like on a car. Your battery needs to be in top shape, unless you run your boat wide open, it will not charge up completely, I used to charge the bateries in my boat every time I used it. Check the battery, the water level in the battery, and the electrolyte fluid, if it is even a hair on the week side, or one dead cell, replace it or save it for a spare. The starter can get sluggish from carbon dropping down on the brushes, it could need to be blown out. Good luck, hope this helps.
Aug 23, 2011 | Boating
Old outboard ground wire melting
1. Short in the trolling motor itself
2. TOO SMALL a ground wire. ..need at least 8 gauge wire!!!!
3. Bad/dirty/corroded battery connections
..Make sure your battery/trolling motor is not accidentally touching the metal boat.. DO NOT CONNECT ANY WIRES TO THE BOAT!!! - PERIOD!!.
Sep 11, 2017 | Minn Kota Maxxum 70 Freshwater Bow Mount...
2001 yamaha 175 hpdi wont charge above 12.4v at high rpm. only 11.8 at idle. all connections to batteries are clean and tight, both batteries are good only some what discharged at this point from the lack...
You have two components for the charging systems. Stator and Rectifier regulator. As a rule of thumb we always change both. First you need to confirm that the outboard is not charging your batteries. use a battery load tester on your batteries confirm you have no dead cells. Second with a fully charged battery, multi-meter, and a water hose connected to your outboard cooling system. third for a picture and diagram of the ignition system go to www.yamaha-motor.com. click on outboard motors,parts and service, view parts catalog. find your year make and model by following steps listed at top. search electrical 1,2,3 until you find a RECTIFIER & REGULATOR ASSY. Click on generator to find the stator. when you find it you will have a picture reference. Check for good ground at the Rect/reg. the stator creates AC voltage the rect/reg converts to DC. rect/reg conects to the battery to charge it through a solenoid on the engine. Connect your multimeter to this solenoid to get the true reading from charging system. start engine check voltage through all rpm ranges. 13.5 v thru 15 v. The other troubleshooting test and disasembly will require a Manual. also to remove the stator you'll have to remove the flywheel.Clymer Service manuals are available through your local outboard dealer. good luck
Sep 22, 2009 | Boating
1991 90hp Force. charging at 16.5 - 17 volts when
Very normal. That is what is gonna charge the battery. At idle it should run at 13 to 14 volts. Definatly a healthy sign man!
Jul 17, 2009 | Light Outboard Motor Boat Bass Fishing...
Mercury outboard over charging
Your motor is fine. It needs to put out more than 12 volts or the battery will not charge. Most alternators put out between 13 - 17 volts, so this is well within the range.
May 09, 2009 | Light Outboard Motor Boat Bass Fishing...
Charging system not working
http://www.crowleymarine.com/brp_parts/diagrams/38308.cfm
start here..Need Year?
Apr 27, 2009 | Chevrolet 1500 Cars & Trucks
Boating Logo
402 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
