Question about Samsung Washing Machines
Wa80v3 model outlet valve open always
I have samsung wa80v3 model diamond edition washing machine now while working its drain valve is always open
jsrock516
  • 5911 Answers
SOURCE: Kenmore Washing Machine Model 110.20862990
You don't open the rear panel. This is a typical symptom of a lid switch problem. The link below will explain how to access it. If you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading as item number 11 (Part number 3949238). For instructions on how to replace a lid switch, click on the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
I hope this helps you. If you have questions, please let me know.
Posted on Aug 07, 2008
SOURCE: My Samsung Washing Machine (Diamond Drum model) problem
You probably did not save the mode you want. See the information booklet provided on how to set the mode.
Posted on Oct 29, 2010
beltronic205
  • 1474 Answers
SOURCE: I have purchased SAMSUNG -
sounds like the drain pipe is too low resulting in Syphoning of water lift pipe above 24 inch floor level, this should cure...
Posted on Feb 01, 2011
  • 489 Answers
SOURCE: Sir, I would like to
It should be fine but I'm not sure how it will work with the 220v. Be sure that the power there is 110v red to white and 110v black to white. If the power is not, it probably won't work. Good luck
Posted on Jun 18, 2011
richroth
  • 9472 Answers
SOURCE: Samsung Washing Machine WA80v3 not working properly
Did the water start without you setting the cycle?
Posted on Nov 28, 2012
My wa80v3 washes then wont drain unless the outlet pipe is left level with the floor and then it drains.we have to pick the pipe up again to refill or spin.please help
check the pump impeller for obstruction stopping it from spinning.
could be a coin, bra wire bobby pin anything
if it is clear , check fro power to the pump on spin cycle
if no power check the program board for progressing the cycle
Dec 07, 2016 | Washing Machines
Got a Samsung Diamond Drum WA80V3 after I put in on quick was and start it goes 22 minutes and when at 15 it goes toe rinse but then the machine just stop doing anything. Water still inside drum. Maks n...
The drain pump is either blocked or failed. Check the filter if it's clear then you are most likely up for a new drain pump. Here is a link to the part you need and a video on how to do it. Samsung DC31 00030E DRAIN PUMP B20 3 120V 60 NEW ORIGINAL
Mar 15, 2015 | Samsung Washing Machines
Why does my Samsung washing machine wa80v3 not wash, spin or drain. ?
There are a few things that could cause this, first of all check the lid switch. That is a safety thing that makes sure the lid is closed before it allows it to start washing or spinning. Some other culprits could be a clogged filter, or a broken belt ( if your model has a belt) does the machine sound like its trying to wash? or does it just turn off and do nothing like its dead? if it seems dead its more than likely the lid switch, they are about $40 and simple to replace.
Jul 15, 2014 | Washing Machines
Samsung wa80v3 does not drain water
check the drain pump isnt blocked. there is a panel at the bottom front of the machine. remove this and unscrew the round cap and look for a jam. turn off machine first! move the propellers with you fingers. if its ok it should turn a quart of a turn then race forward some
May 17, 2014 | Washing Machines
Nov 28, 2012 | Washing Machines
Sir, I would like to ask if this samsung washing machine model Diamond Drum WA80V3 220V - 50Hz - 330W can be use in Cebu City, Philippines where the electricity power cycle running is 60Hz?
Jun 17, 2011 | Samsung Washing Machines
Water is continuously draining from my samsung washing machine . due to this unable to keep washing the clothes .why the problem come & what is the remedial measure to rectify?
Possible that the drain value is half blocked and so is not able to block the water in the tub. Remove the connection to the valve and check if this drains , if so it is confirmed. Remove, clean the dirt and reset. If the leak stays then the valve is faulty.
Also it can be due to partial voltage to the drain valve to keep it open which means that the program controller is faulty. This is confirmed when the drain stops as the connection to valve is taken off.
Jan 13, 2011 | Washing Machines
Washing Machines Logo
16 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
