Question about Dell Optiplex GX280 (99301) Motherboard
Locate the password (PSWD) and CMOS (RTC_RST) jumpers on the system board.
  • 4 Answers
These jumpers are almost always located close to the CMOS battery or close the PSU power connector. If you open the unit up and remove the drives to see the board, it'll be either green or blue and it'll say PSWD right beside it. Remove it, power on wait for the Password Clear message....done.
Posted on May 08, 2014
2 Suggested Answers
  • 67 Answers
SOURCE: locate the jumper for the cmos
Check the manufacturers website for jumper location... Alternatively, if you can get a good look at the motherboard, sometimes the jumper sequence and location is stamped on it
Posted on Mar 30, 2009
How to remove bios password
hi lata.
you can try this.
  1. Remove the computer cover.
  2. Locate the 2-pin password connector (PSWD) on the system board.
  3. Remove the 2-pin jumper plug and set the jumper plug aside.
  4. Replace the computer cover.
  5. Connect your keyboard and mouse, then connect your computer and monitor to electrical outlets and turn them on.
More items...
How to Perform a BIOS or CMOS Reset and/or Clear the NVRAM on ...
https://www.dell.com/.../how-to-perform-a-bios-or-cmos-reset-and-or-clear-the-nvram-o...
or go to this link.
How to remove bios password Google Search
Nov 06, 2017 | Computers & Internet
How do I remove administrator password on the BIOS of Optiplex 390
The CMOS contains the current BIOS settings
  1. Turn off the computer and disconnect the power cable from the electrical outlet.
  2. Remove the computer cover.
  3. Locate the 2-pin password connector (PSWD) on the system board.
  4. Remove the 2-pin jumper plug.
  5. Locate the 2-pin CMOS jumper (RTCRST) on the system board.
  6. Move the 2-pin jumper plug from the password jumper to pins into the CMOS jumper.
  7. Plug in AC power to the system and wait ten seconds for the CMOS to clear.
  8. Move the 2-pin jumper plug back to the password jumper.
  9. Replace the computer cover.
  10. Connect your computer and devices to electrical outlets, and turn them on.
Location of the RTCRST Jumper will vary by platform and form factor. For more information about the jumper locations refer to the system service manuals located at www.dell.com/support/manuals
Aug 15, 2016 | Dell OptiPlex 390 DT Desktop Computer...
Were do the jumpers go on a optiplex 330
There is the Password jumper (PSWD), and the CMOS jumper.
The CMOS battery is also termed the RTC battery.
Real Time Clock battery.
The CMOS jumper is labeled as RTCRST.
Real Time Clock ReSeT.
Jumper pin location is confusing if you go with Dell documentation.
http://support.dell.com/support/edocs/systems/op330/en/ug/mtparts.htm#wp1607303
Dell Support documentation shows the RTCRST jumper pins near the Intel chipset, and PSWD jumper pins near the outside edge of the motherboard.
I'm also looking at the Dell Optiplex 330, Technical Guidebook, Inside the Optiplex 330,
http://www.dell.com/downloads/global/products/optix/en/optix_330_techspecs.pdf
Location of RTCRST jumper pins, is near the left corner of the Intel chipset, instead of the right as shown above, and PSWD jumper pins are in the same location.
And several views of Optiplex 330 motherboard's on Ebay,
http://www.ebay.com/itm/Dell-Optiplex-330-Motherboard-Socket-775-KP561-/140870576837?pt=Motherboards&hash=item20cc8a6ac5
(Nice to have that Zoom in feature on Ebay now)
Jumper pins close to the white SATA 2 connector, are the RTCRST jumper pins.
Jumper pins at the bottom side of the Intel chipset are the PSWD jumper pins.
Jumper cap stays on PSWD jumper pins.
No jumper cap on the RTCRST jumper pins.
http://en.community.dell.com/support-forums/desktop/f/3514/p/18683374/18806360.aspx
Regards,
joecoolvette
Oct 23, 2012 | Intel Motherboard
Someone gave me a dell optiplex 240 pc they did not have the password i have tried removing the password jumper and also the battery and still it asks me for a pass word help
Make sure you remove the jumper with the power OFF (not connected)
Disabling a Forgotten Password
NOTICE: This process erases both the system and setup passwords.
1 Open the computer cover.
2 Remove the jumper plug from the PSWD jumper to disable the
password feature.
See "Jumper Settings" to locate the password jumper (labeled
"PSWD") on the system board.
3 Close the computer cover.
4 Reconnect your computer and devices to an electrical outlet, and then
turn them on.
This erases the existing password(s).
5 Enter system setup and verify that the password is disabled.
Jul 14, 2011 | Dell XPS 400 PC Desktop
Need cmos jumper location on Dell Dimension 8200 to bypass bios password
From what I can gather, you just need to locate the jumper labeled PSWD and remove it. Turn computer back on, then back off. Replace jumper pin and turn computer back on. That should do it. Removing the jumper disables password. Turning on computer resets it. Replacing jumper re-enables password capability.
Jul 17, 2010 | Dell Dimension 8200 AUD System Board...
Cannot access system -- forgot password. Cannot
Open the computer case. On the motherboard, (looking from the bottom of the motherboard), in the bottom right quadrant, to the right of the CMOS battery, you'll see two jumpers labeled CLR_CMOS and PSWD. You'll want to move the jumper for the PSWD block to pins 2-3 for 5 seconds and then replace the jumper on pins 1-2. This will clear the CMOS password.
Feb 07, 2010 | Dell Inspiron 530s Desktop Computer
Reset bios to factory settings in dell optiplex gx520
The BIOS password may be cleared from a Dell Optiplex by removing the password jumper (PSWD) from the motherboard.
Can click the link below to see how its done or follow the steps below :--
http://support.dell.com/support/systemsinfo/documentation.aspx?c=us&l=en&s=gen&~subcat=87&~cat=12
Choose the desktop model and continue.
For most Dell Optiplex desktops, the steps to reset a BIOS password and clear all CMOS settings are:
  • Locate the 3-pin CMOS password reset jumper on the system board.
  • Remove the jumper plug from pins 1 and 2.
  • Place the jumper plug on pins 2 and 3 and wait approximately 5 seconds.
  • Replace the jumper plug on pins 1 and 2.
Else can follow Optiplex User Guides.
Hope it helps !!
Thanks.
Sep 14, 2009 | Computers & Internet
How to reset passwd in admin setup in gx280. i took the batery off but that did not help.
Before you begin,
http://tomcat.yc.edu/servman/desktops/GX280_UG/before.htm#1107075
Then;
1: Locate the password (PSWD) and CMOS (RTC_RST) jumpers on the system board.
2: Remove the password jumper plug from its pins.
3: Place the password jumper plug on the RTC_RST pins and wait approximately 5 seconds.
4: Remove the jumper plug from the RTC_RST pins and place it back on the password pins.
Just remember to take your time and don't get nervous working on the computer. Please report back to the thread the results of your work.
Regards;
Hassan
Jul 08, 2009 | Dell Optiplex GX280 (99301) Motherboard
How do I reset my lost bios password for Dell Precision M70
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
The location of the password jumper on a Dell Optiplex motherboard can be found by reviewing the Optiplex User Guides.
Each Dell Inspiron has a master password which will clear the BIOS password. You can get this number by calling Dell Technical Support at (800)624-9896.
Dell Technical Support will request the Service Tag and Express Service Code from the bottom of your Inspiron.
Thank You,
Your Support Tech.
Manish Shirsikar,
Fixya.com
May 18, 2009 | Dell Precision M70 Notebook
Problem with ma ibm thickpad
loose the back of yr ibm if u cant find the cmos battery then u might need to disasemble the whole system carefully under the key board i think thats where th cmos battery will be.
Note removing cmos battery in some systems dont clear cmos password u have to do some additional work to remove yr password. for the battery prob try using a diff battery to be sure what ur prob is.
thank u
May 26, 2008 | Computers & Internet
Computers & Internet Logo
83 people viewed this question
Alun Cox
