Question about Westinghouse SB915
Cannot remove door from sb915 - Westinghouse SB915
HO 1 code dishwasher will not start
Jenny, I believe the HO 1 (or H: 01) means that the machine is set to delay starting for 1 hour. Continue pressing the "DELAY" button until the readout shows H: 00.
Mar 06, 2016 | Westinghouse SB915
Water not heating
water not heating I need some ideas to fix the problem.
Nov 18, 2012 | Westinghouse SB915
Dishwasher Westinghouse SB915 fills with water for wash cycle but does not wash.
Contact Westinghouse directly to request the wiring diagram.
May 30, 2017 | Dishwashers
Westinghouse sb915 squeals on wash cycle
Sounds like the belt is slipping on your basket.
Oct 30, 2011 | Westinghouse WWS833ES Super Capacity Top...
Hi, we haven't got a manual for our Westinghouse touch dry SB915 dishwasher and the lock has been activated. How do you unlock it?
press hold in for few seconds if not get unlocked you have to get new on and of switch due to this dishwasher switch burns out its popular with this dishwashers power switch burns out
Dec 27, 2010 | Dishwashers
Runs through entire cycle fine but water is cold
you need replaced the control board its very popular with this dishwashers cost around $220 as i have replaced mine
Apr 07, 2010 | Fisher DD603FCSS Dishwasher
Westinghouse sb915 - draining too early.
1. Is your drain point higher than the bottom of the dishwasher? (ie, does it drain into the garbage disposer or does the drain line drop down below the floor into house plumbing?) Did you just install the unit? You may have to install an "air gap" to prevent syphoning.
2. Did the dishwasher work then suddenly stop working? (asking for clarification)
Dec 13, 2009 | Westinghouse Dishwashers
Westinghouse SB915 wont heat up water
found the 2 large lugs mounted on the circuit board had been hot and had dry solder joint's removed solder cleaned with sand paper then re soldered and tested it now heats up .
Jul 26, 2009 | Westinghouse Dishwashers
We have purchased a new home and it has a Westinghouse touch dry, SB915 installed. First use, water appreared on the floor at the front. Unable to to determined where leak coming from without pulling out...
hi check the lineament of the dishwasher door if the dish washer is not level front to back and side to side it will be lop sided and the door seal may not be depressed enough and may leek from the bottom part of the door seal too ways of checking this is to run a level inside the unit side walls and a small level for side to side leveling the other is to just close the door and at the same time checking the inner chrome part of the door with the inner side walls as they should not clash nor be closer to one side than the other i hope this helps as it is hard to explain
Apr 27, 2008 | Dishwashers
Westinghouse SB915 Logo
18 people viewed this question
Top Westinghouse Dishwashers Experts
Denis FixYa...
Denis FixYa...
Tom Chichester
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
