Question about Sony Bravia KDL-46VL130 TV
Dark right side screen
Different colored stripes going up and down. Will go away, but comes back. Also, right side of picture is much darker than left.
SOURCE: My Sony BRAVIA KDL-46V3000 Television has messed
This also happened to me and may continue to get worse... If it goes away for a while after warming up, then it is the same problem... The LCD panel is probably going out, when that happens the cost to repair it is more than the tv is worth... If it is in warranty then you can have it replaced or fixed.
Posted on Nov 23, 2009
Testimonial: "You were so right. Thanks."
SOURCE: Sony KDL-46XBR4 much darker on the right side of screen
ITS THE PANEL ASSY. I JUST HAD MY REPOACED. SONY WILL HONOR A COURTSEY WARRANTY UNTIL 2012
Posted on Jan 27, 2010
tvhelp-Dave
  • 178 Answers
SOURCE: Sony KDL-46XBR4 right 2/3rds screen darker, motion blurred
Hi Ron, thanks for describe many valuable details. You suspect something wrong with the fluorescent tube, if it is true, shall be dark on top or bottom, not left or right, also the problem with the backlight the TV will shut off and the timer LED will blink 6 times.
I think there is the bad connection inside the panel or the t-con board, only think you can do is try to reconnect the wires under the aluminum foil (see the picture) or replace the panel.
Posted on May 10, 2010
electronick
  • 505 Answers
SOURCE: black line going down middle of screen and one
if the line is pixel thin, it could be a bad lcd panel. if it is a wider bar, it may be in the video circuitry. many of these sony tvs had bad panels, and sony has extended the warranty. call up sony with your model and serial # and date of purchase and try to get them to help you out, that is your best course of action. let me know if you need more troubleshooting assitance.
Posted on Jun 01, 2010
tvhelp-Dave
  • 178 Answers
SOURCE: Screen dark on right hand side at start up
Suggest return or exchange. This is a newest model, and on factory warranty, if can't return or exchange, you have to complaint it until the panel is replaced. in fact, it is 90% panel defective. right now the LCD panel quality is too bad.
Posted on Jun 17, 2010
My Vizio TV has dark spot top left corner
Hi Brandon,
I am afraid that the dark spot in the screen is not repairable. Manage as long as you can or go for a new tv.
Apr 08, 2015 | VIZIO M701d A3R 70 Inch 1080p Smart
Dark line down the middle of my flat screen tv
Most LCD and PLASMA sets use two boards (some combine them into one board) that drive the Display Panel (the entire front screen unit) so I would suspect one of yours is bad.
The other unpleasant possible cause is where the left board is connected to the Display Panel (entire front screen unit) you have a problem inside that Display Panel and that is fatal as there is no way to get INSIDE the panel---it can cause both lines and a dark picture on one side of the screen.
May 25, 2012 | Sylvania Televison & Video
Dark Blurry Ink Line
When I print darker color images I get what I call Zebra stripes across the picture on a slant about 1/2 inch apart. Changed the toner and the drums are at 45% capacity. Any suggestions. Thank you.
Sep 03, 2008 | Konica Minolta magicolor 7450 Laser...
Hitachi 60v500 tv has split screen with white vertical stripe down side
Good Day, poandflo;
After removing the power from TV remove the back of the TV (bottom only): Repair: Re-insert PDM connector on both Main Digital module and Drive PWB.
Good Luck, big IRISH. ps. remove cables one at a time and plug back in ensuring that they are seat properly.
Aug 08, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Dark Vertical Stripe on Right Edge of Screen
I experienced the same approx. 1/2" vertical stripe on a Viewsonic vx1945 and ATI Radeon x1050 video adapter on Vista Business SP1, but the stripe appeared along the left edge of the screen, instead of right edge. I then temporarily decreased the monitor resolution, and the stripe went away. I then increased the monitor resolution back to its original setting, and the stripe did not re-appear. So, that was the 'fix' in my situation, hope this helps.
Dec 11, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
A dark large stripe on the screen which won't go away
It is definitely a screen related issue. There are 5 drivers each running a section of the screen. Obviously one is out, but that doesn't mean the others are on the way. You may be able to find a replacement screen if you'd like to attempt the replacement yourself. Otherwise you always have the option of using a service center.
Jun 09, 2007 | HP Pavilion ze2000 Notebook
Sony Bravia KDL-46VL130 TV Logo
20 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
