Question about Royal Jaws Shredder
Royal Jaws Shredder shreds
Motor operates, but "jaws" do not. I opened up the gear box and could find no obvious problem with the operation of the gears. The grease inside is still - well - greasy and has not apparently frozen the gears by drying up and hardening. I suspect the gears are worn and simply do not engage properly, anymore. Any solution other than buying new shredder?
  • 8 Answers
SOURCE: Shredder motor runs but gears are not engaging and
I have the same problem and upon removing the gears I found one that is plastic and worn pretty bad. Replacement parts can be purchased at 1-800-222-2310. Part # VF1012MX-08 Gear #2
I advise purchasing the metal one.
Posted on Aug 08, 2009
  • 1218 Answers
SOURCE: I have VF800 royal shredder. the motor runs but
Contact ROYAL at 1-800-524-0799.
Posted on Jun 02, 2010
  • 1218 Answers
SOURCE: Replacement gear for Royal PX100MX shredder
For replacement parts call Royal at 1-800-524-0799; they should be able to help.
Posted on Aug 22, 2010
  • 1218 Answers
SOURCE: Shredder motor runs but won't shred paper. No
If the motor is running do the cutting shafts turn??? if not then unplug and open up the top to see if any gears are broken/stripped; give Royal a call at 1-800-524-0799 for parts and prices once you've located the problem.
  • 1218 Answers
SOURCE: Royal Jaws strip cut shredder, it does not cut all
You only have to remove about 5 screws from the bottom of the shredder to release the top then you can see what is going on inside...if you need parts call Royal at 1-800-524-0799.
Posted on Oct 14, 2010
Shredder No Longer Does
Office shredders, even the heavy-duty ones, tend to jam up over time and have to be cleaned up to restore operation. If you have removed all jammed paper bits and still get erratic operation, the shredding process may have bent or broken some internal parts. It is not economically practical to try to repair. Better to buy a replacement.
Dec 27, 2013 | Royal Jaws Shredder
Where can I get the Jaws for royal sc180mx
Contact Royal at 1-800-524-0799 for parts assistance.
Feb 16, 2011 | Royal Jaws Shredder
Drive gear has worn out and it will not engage shredder cylinders
For replacement parts contact ROYAL at 1-800-524-0799.
Jan 23, 2011 | Royal Jaws Shredder
Not shredding properly, perferrating the paper but not actually tearing/shredding it.
A bearing may be worn, or moved out of place allowing the cutting shafts to move apart a little...remove about 5 screws from the bottom and the top will come off and you can see whats going on...if you need parts call Royal at 1-800-524-0799
Sep 17, 2010 | Royal Jaws Shredder
My jaws shredder appears to get overheated every now and then and just stops running, is this normal? also, when I shred alot of paper sometime it will gets jammed and I have to go back and forth on the...
Remember this is a "consumer" shredder NOT a commercial shredder..... if you shred for 5 minutes you should give the machine 10 minutes for the motor to "cool-down"...it will not hurt if you also shred some paper with shredder oil poured onto the paper so that the oil lubricates the cutting blades...lastly; if the shredder is rated to a Max. of 10 sheets(as an example.)..you will have fewer problems if you only shred about 70 % of that number. ***Think of your car...it will go 100m.p.h.....but how long will it last if you drive it at its maximum speed all the time.????
Jul 17, 2010 | Royal Jaws Shredder
Royal Jaws strip cut shredder, it does not cut all the way through the paper. Not sure why. Is there any hope for repair, if so...please share what might need fixing. txs!
Jan 24, 2010 | Royal Jaws Shredder
Gears are not turning but fan is running No apparent jam but have difficulty manually turning gears
Shredders normally are hard to turn by hand....check to see if any gears are broken or stripped....take one gear out so the motor dosn't have to turn the cutting shafts...once you determine problem give Royal a call at 1-800-524-0799 for parts and prices.
Jan 13, 2010 | Royal Jaws Shredder
Oct 23, 2009 | Royal VF1000MX Shredder
Royal Jaws Shredder Logo
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
