Question about Sony STR-DH800
Sound is linear when connecting blu ray player to str dh800 via optical cable
otacon
  • 1944 Answers
SOURCE: No Audio
Your receiver is the Denon AVR 2105 and not the Sony STR-DG510 5.1 Channels Receiver?
Posted on Jan 20, 2008
SOURCE: sony str bd-930 connected via digital input to ps3,no sound..
on the ps3 in audio options you have to set it so that the sound is going through the optical and not the hdmi. this it was I think the problem is.
Posted on Dec 30, 2008
SOURCE: NO AUDIO/set up problems
For this Sony, you have to use separate audio cable(s). Either optical in BD or Digital Audio in DVD (single coaxial cable will do the trick) I bet the display says UNLOCK. I had the same problem, very dumb.
Good day!
Posted on Jan 20, 2009
SOURCE: no sound from Sony STR-DH500 when playing dvds with HDMI
no sound via hdmi cables, you must use optical or coaxial
Posted on Dec 18, 2009
dunnbiker
  • 8546 Answers
SOURCE: Subwoofer hum from STR-DH800
That points pretty much to a bad shield on the cable. Have you tried another one? Another thing to try is to rotate the AC power cord on the sub (if it has one). Sorry, too lazy to look it up.
Posted on Dec 29, 2009
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
No Audio
cant use both hdmi and opti outs try sum setting in blue ray but u nee dto plug all blue ray dish directto samsung hdmi then 1 master digital out form tv to sterio digital i n ok tell samsung your output also
Jan 20, 2008 | Sony STR-DG510 Receiver
Got a Kenwood vr405 surround receiver, a Sanyo plasma TV, hd cable box and an insignia blu ray player. Both the cable box and the blu ray player are connected via hdmi to the TV and the TV is connected to...
If you would like to use high definition audio decoding, connect the HDMI from the blu ray player to the receiver. If that it not an option for you due to lack of equipment such as an additional HDMI cable to go from the receiver to the television for the video portion of the signal, then connect your optical cable again. After the optical cable is connected, make sure the Dolby Digital decoding is enabled on the receiver, and that the media you are playing also has a version of 5.1 surround sound. Then, enter the setup menu of the player (which I suspect this is actually where the problem might reside in your case) and make sure that Dolby Digital and DTS are not set to "downmix." Dolby Digital should be set to output Dolby Digital and so on and so forth...hope this helped.
Jan 14, 2010 | Kenwood VR-405 Receiver
Video but no audio
This receiver does not support audio via HDMI. You need to connect BD player via spdif cable. Use optical or coax depending on what does the BD player support - receiver supports both.
Dec 24, 2009 | Sony STR-DG520 Receiver
I have my 80 gb PS3 hooked up to my STR-DH800. I
You may need to enter the setup menu on the PS3 and enable the decoding for blu-ray discs.
Dec 13, 2009 | Sony STR-DH800
No sound from Sony STR-DH500 when playing dvds with HDMI
Dec 10, 2009 | Sony STR-DH500 A/V Receiver
No sound through home theatre with blu ray connected
Make sure that your receiver says optical 1 or 2 on the front display.
Nov 21, 2009 | LG BD370 BLU RAY PLAYER
Blu ray connect to my sc-pt660
as far as hooking up your blu ray player to the sc-pt660, the only real way to utilize the surround sound (with true surround sound) is through the optical audio out. You need to connect your blu ray player through hdmi to your tv and then connect your blu ray player to your surround sound using the optical audio out/in. I, personally have the sc-pt660 hooked up through component cables so I don't waste an HDMI input on my TV. Except for cd's, there is no reason for you to use the actual dvd player part of the surround sound considering you have a blu ray player. In conclusion, hooking your blu ray player and the sc-pt660 up to get better video simply isnt possible (your blu ray player alone gives the best possible resolution, 1080p). As far as audio goes, run an optical audio cable from your blu ray player to your sc-pt660 to get true surround sound.
Mar 23, 2009 | Panasonic SC-PT660 Theater System
Running my Blu Ray DVD thru the Bose Lifestyle 18
hi there,
1-connect the blu-ray to your tv via hdmi cable and this will run picture.
2-connect the blu-ray via digital optical cable to the optical input on the bose system. then using your bose menu, (system menu)set your auxillary sound output to digital optical.
when watching dvd thru bluray player select aux on the bose and you're away.
good luck
Jan 31, 2009 | Bose Lifestyle 18 System
No Audio
What port do you have the HDMI from you BD player into on the 510. If you have it on the DVD port then fiber optic will do you no good, the DVD HDMI only supports digital coax, the Video2 HDMI only accepts fiber optic, and there is an extra fiber optic for the Sat input. If your BD player does not have digital coax out, or if you dont want to buy another cable, just move the HDMI from DVD to Video2 on the 510. I am willing to bet you have the BD player plugged into the DVD HDMI port and the fiber optic cable from you BD player to the Video2 fiber input.
Dec 18, 2007 | Sony STR-DG510 Receiver
Sony STR-DH800 Logo
16 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
