Question about Whirlpool Freezers
Icemaker leaks water
Water tube supplying ice maker freezes up
Replace water inlet valve, which was not shutting off completely.
Posted on May 19, 2009
Water freezing in tube to icemaker
Change the water control valve because it is not shutting off once the ice maker is full. The valve is sticking open slightly once power is off to water valve. What is the model number of your Kenmore Elite Model numbers for Kenmore most times look like this example=> 321.456789 Sea Breeze
Kenmore Model Numbers
Apr 01, 2013 | Kenmore 26.5 cu. ft. Side-by-Side...
The tube feeding the ice making machine is iced up? What is the solution?
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Jun 04, 2010 | Whirlpool Freezers
Not pumping water to icemaker
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Dec 08, 2009 | GE Freezers
My Frigidaire side by side is not making ice. (Model GLRS267ZAW1)It goes through the cycle but no water is getting into the icemaker. I can pour water in to the icemaker and it makes the ice and dumps it....
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Oct 03, 2009 | Freezers
Maytag Icemaker freezing up
Possibly a bad valve but more likely not enough water coming to the unit,follow the water line from the back of the unit to where it hooks to the pipes there is usually a little saddle valve there,try closing it all the way and then open it back up check the water through the door and see if the pressure doesn't improve.
 You can also remove the Ice maker clear out the fill tube and sit a cup under the end of it for a day or two if you get water in the cup and Ice in the tube you probably have a solenoid valve that isn't closing completely.
Aug 31, 2009 | Maytag Freezers
Leaking ice maker
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze diverting the water. You can take the water line off the valve and watch to see if it drips.
Aug 30, 2009 | Freezers
Ice maker seems to be dripping water onto ice in ice container
Watch it when it fills with water. The fill tube could also be stopped up with ice. The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jul 12, 2009 | Kenmore Freezers
Ice maker ice smells
Dump out the ice, let the icemaker refill the ice container, dump all that out as well and then it should be cleaned of whatever was in the line..
You may want to roll the fridge out and visually check the supply lines on the back of the fridge for contamination as well.
Jul 02, 2009 | Freezers
ROPER RT18AKXJW01 Ice Maker Malfunction
Hi, If the icemaker is leaking next to the head, all you can do is changethe icemaker. See if it is leaking between the head and the tray. You can order the icemaker off my web site www.whirlpoolpartssurplus.com. If I can assisrt you further, please let me know.
THanks
Vic
May 17, 2009 | Freezers
The icemaker in my Bauknecht KGN 7010 F/F has stopped making ice
First you need to find out if the lie is blocked. Disconnected water feed and try to run water through it into a bucket or sink. If you get water it is a valving problem. Also make sure the filter is clear.
Dec 29, 2008 | Freezers
Freezers Logo
79 people viewed this question
Top Whirlpool Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
David Jewell
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
