Question about GPX Televison & Video
Bedienungsanleitung gpx vcr-628p - GPX Televison & Video
Remote code
GPX TVR950 VCR is made by Daewoo:
The Remote Control is Daewoo RH44-0077
Jan 11, 2014 | GPX TVR950 VCR
GPX Karaoke Machine with AM/FM radio and cassette, Manufactured 1/2001 Model C1550 do not know how to hook up to TV/VCR ?
On the rear of the unit, the RCA jack on the lower left corner of the jack panel should be yellow and marked Video out. take a RCA to RCA plug into the video out on the unit, then plug the other end into Video in on the TV.
I'll attempt to send you the manual thru the link below:
http://www.gpx.com/owners_manuals/JM250S-IB.pdf
Good Luck, and don't forget to rate the answer. Let me know if this doesn't help.
M
Sep 21, 2011 | Digital Products International Karaoke...
How do i program my GPX D1816 dvd to dish network remote control? thank you.
Currently we do not have any codes listed for that brand of DVD player. I would like to suggest a method called a power scan the steps are below:
1.) Press and hold the correct VCR button (about six seconds) until all mode button backlights come on, then release.
2.) Press 222 pound (#) then record three times.
3.) With the desired equipment on, press and hold the VCR/DVD button until all mode button backlights illuminate (about 3 seconds), then release.
4.) Press and release the Power button.
5.) Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
6.) Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
To verify the code works try several different functions for that equipment.
Daniel Busa
DISH Network Customer Service
Feb 27, 2011 | GPX D1816 DVD Player
I search an instruction frm a vcr gpx 9999 y
You can find the manual for your vcr CLICK HERE You must however sign up to become a member of the site. Good luck, I hope this helps you out!
Nov 09, 2009 | GPX TVR950 VCR
Remote codes
Radio Shack has a website for all of it's universal remote codes for the remotes it sells at www.rcinfo.com. There you'll find what you're looking for.
Aug 10, 2008 | GPX D1816 DVD Player
Code for GPX model TVD1324
Hey! I was having the same problem programming my universal remote and I finally figured it out tonight!! Daewoo apparently owns GPX or something so try the Daewoo codes, it worked for my VCR!! Good Luck!!
May 17, 2008 | Televison & Video
Cassette stuck in VCR
You are almost on the right track. did you look where your finger was? what happened was you did not allow the blocking a photo sensor which mimicked the clear part of the tape and this caused the eject to take place. What was happening in your case was the arm would come fully out and the sensor would sense no tape so the VCR shut off in a trouble condition to prevent damage from ocurrin.
Oct 28, 2006 | GPX TVR950 VCR
Televison & Video Logo
Top GPX Televison & Video Experts
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
