Question about Hobart Handler 140 Mig Welder
Wire spool with not turn continuously while I am welding. It turns and stops, turns and stops. What can I do to fix the problem?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Should be adjusters where the wire feeds out to the hose... adjust those. couple of youtube videos online should help you out
Posted on Dec 28, 2013
  • 33 Answers
Depending on how many hours you have on your liner-you could have a sticky liner.
open door while pulling trigger.
does rollers move smoothly and continuous speed?
do they jerk and hop?
loosen tension on rollers-its not a grinder-you could have too much tension and its distorting wire so its not round anymore and your liner is round...
replace your tip-could be all gunked up.
Posted on May 09, 2014
    Habit-Forming:
    New Friend:
  • 56 Answers
Make sure wheels are set for diameter of wire. Make sure tension on spool of wire is not to tight. Adjust drive wheel tension per instructions in owner's manual. Make sure tip is clean and of the right diameter.
I had the trigger switch go bad once. As it deteriorated the operation became erratic. Check it's operation with a multimeter.
Posted on Mar 05, 2014
2 Suggested Answers
hondova74
  • 3 Answers
SOURCE: northern tool brand wire fed gasless welder feeds wire fan work no welding?
You need to have the ground attached to what you'll be welding on. Make sure there isn't anything on the end of your wire. Also, if your voltage is all the way down it won't do anything either. Oh, one more thing, make sure you have a contact tip on the end inside the cone. That will be the copper thing the wire goes through with a really small hole. I know some of this sounds pretty obvious but if I hadn't done these things at least once.....I wouldn't know what to look at either. I also don't know your experience level and want to cover all avenues. Hope you find it!
Posted on Jul 02, 2009
I have a Lincoln sp135+ changed liner tip and put a new spool on it and added gas.... The wire stopped feeding but drive wheel keeps turning... any he would be appreciated Thank you Bryan
indicates that the liner has a groove worn in it and the wire is jamming in that groove
replace the liner from the drive wheel to the nozzle
Jan 13, 2018 | Lincoln Welding Tools
Spool won't turn
are the rollers tightened enough, also maybe the wire is jammed in gun.
Feb 02, 2013 | Hobart Handler 125 115 Volt 30 To 125 Amp...
When welding, the wire drive motor seems to bind up after 3 or 4 revolutions on the sporcket. I took the end off of the gun and pressed the trigger and the wire fed easily for a few secs and just stopped....
Could be the drive motor is going out, or overheating. Or the spool is too tight. If you can get to the motor wiring check the AC with a clamp-on meter to see how much it's pulling. If you're lucky the label on the motor will tell you what the normal draw is.. that small a motor it should be pretty low. If you hold down the trigger even after the wire stops, does the motor start to get hot? Can you turn the spool (lightly) by hand to see if that's hung up and hanging the motor?
8^)
Jan 04, 2011 | Garden
Have a lincon 255Xt mig welder. You push the triger and it feed and try to weld and it arces then it stops right a way. Let go of the trigger and push the trigger and it feeds again. What is are problem?
Have you checked the tension on the wire roll feeder? Inside the unit where the spool is, the wire feeds off of the spool, through the feed roller, this roller has a tensioner spring on it that keeps the wire flowing steady, and also check the spring tension the keeps the spool from turning freely, keep this loose as can be, and just enoughthat it doesn't unwind on it's own.
There are so many things that it can be, but this is a start.
Good Luck.
Paul
May 07, 2010 | Lincoln X2688 2 YR EXTENDED WARRANTY FOR...
I have a lincon 3200 hd. it stoped feeding the wire when i was welding. but it feeds when i pull the triger, till i try to weld again
These welders have thermal breakers in them so if they get to hott the will automatically stop feeding the wire but the fan will remain on, try changing the breaker i think its in the door where the spool is held. good luck]
Apr 13, 2010 | Welding Tools
When i pull the trigger to weld the wire turns cherry red and starts to burn
Do you have the correct roller wheel installed? On the proper wire guage slot? Make sure the wire spool is not tightened down to much. That should give you a good start point.
Paul
Mar 29, 2010 | Welding Tools
Wire quit feeding checked motor and tested good was welding when wire quit spooling visibly all pc board compononents look good checked numerous things feeling lost on this one any guidance would be...
if motor and feeder roller is turning. check that their is the correct pressure on feeder roller for the wire thickness you are using and that it is in the right groove on those rollers.
also check the tip it may have splash buildup which is affecting the wire feed.
hope this helps
Mar 03, 2010 | Welding Tools
I have a brand new Lincoln pro mig 140. Took it out of the box and set it up yesterday. After approximately two hours of mild steel welding today the wire drive roller quit working. I've tested the...
I'm having a problem with the wire feed on my Lincoln Pro Mig 140. The wire feed speed is not consistant. It seems to be slipping even though the tension is tight. Any solutions?
Oct 18, 2009 | Lincoln Electric LINK2400-+2 CV-305 MIG...
SP-250 power supply problem
When you pull the trigger the wire should feed imediately, if it dosn't then this will give you the problem. first check the clutch on the wire spool, this is in the centre post that the spool goes on the nut/screw should allow the wire spool to turn easly without tention,
if the spool runs on adjust the cluch. Check the shaft that the rollers are atached they should be held with key-way to stop them slipping, re-adjust the WFS ensure the wire feeds fast or slow as you rotate the WFS control and ensure the wire feeds instantly, lastly make shore the rollers are correct: the right size
Feb 20, 2009 | Lincoln Welding Tools
Hobart Handler 140 Mig Welder Logo
261 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
Delage guy
Delage guy
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
