Question about Sova DSV32P112 32 in. LCD Television
How do I reduce the size of the picture on my PC monitor
The picture looks as if it is on wide screen and does not show the whole picture. I have to move picture to the left to view the whole screen. How can I solve this problem?
Try going to page on the top right corner click on that and then click on zoom and make sure the zoom is set on 100%
Posted on May 18, 2009
How do we get shows (programs) to cover the whole screen on our tv
You can access either through the TV's remote, or the cable box remote picture settings for choosing picture size (i.e., normal, wide, stretch, wide zoom, etc.).
Oct 20, 2014 | Televison & Video
Tip
Monitor buying tips you should know.
Over the years monitors have transformed from those bulky CRT monitors to square LCD screens to stylish flat wide screen LCD's and now to new stylish extremely thin LED screens. On average every PC user spends at least 5 hours a day looking at the monitor. If the picture is fuzzy and not clear enough then there is a very high possibility that the eyes get damaged.
An older CRT monitor
A wide LCD monitor
A newer ultra flat widescreen LED monitor
Monitor Sizes
There are many different sizes of CRT, square LCD, wide LCD and wide LED monitors available on the market at the moment.
If you want an older CRT screen then sizes can range between 14" to about 20", they use the 4:3 aspect ratio.
If you want an older LCD screen then sizes can range from 15" to 19", they also use the 4:3 aspect ratio.
If you want a newer wide screen LCD then sizes can range from 18.5" to about 27" and even larger. They use the 16:9 if they are full HD or 19:10 if they are not ratio.
If you want a newer wide screen LED then sizes can range from 18.5" to about 27" and even larger. They also use the 16:9 if they are full HD or 19:10 if they are not ratio.
Image quality
The sharpness of the image in a monitor greatly depends on your Graphics card as well as whatever resolution you are running at. Nevertheless the quality of the monitor plays an important role.
Here are some of the tips that you should know before buying a monitor.
1. There are three types of monitors namely CRT, LCD and LED. The monitor that looks like a TV is a CRT monitor. In CRT monitors there is a Cathode Ray Tube that shoots electrons into the screen to create the image. An LCD monitor is smaller in width and consumes less power and is healthier if you are going to be spending large amounts of time at your PC. The LED screen looks the same as an LED monitor and the difference between it and the LCD is that it has a much higher contrast ratio resulting in darker blacks and much lighter whites.
3. A CRT monitor is much heavier than LCD monitor as you can imagine by it's bulky appearance. A LCD monitor is very lightweight and so is a LED monitor.
4. The distance between two adjacent pixels in a monitor is called 'dot pitch'. This is measured in millimeters (mm). Smaller the dot pitch the clearer the picture quality. Usually there are monitors with dot pitch varying between 0.20 mm to 0.27mm. Some manufacturers use diagonal dot pitch while most of them use horizontal dotpitch. The diagonal dot pitch is always longer than the horizontal dot pitch
5. Resolution of a monitor has to be considered with care. Most of the CRT monitors have resolutions of 800×600, 1024×768 and 1280x1024. The square LCD monitors have 1280×1024 and 1600×1200 resolutions. Newer wide screen LCD monitors have resolutions of 1600x1900, 1680x1050 and the Full HD 1920x1090. When the resolution is higher the images and text will appear smaller. But you can see more text and bigger pictures in the monitor with high resolution.
6. Another thing to note is the 'Refresh rate'. This rate is usually 60Hz, 73Hz, 75Hz, 85Hz. Refresh rate of 85Hz means the picture on the monitor is refreshed 85 times within a second.
7. The brightness and contrast can range between a low 5 000:1 to a high 80 000:1 in a LCD monitor and an average of 5 000 000:1 in a LED, yes that's 5 million to 1 with a LED. This just shows how much better a LED monitor is to a LCD.
8. If you are a gamer then the thing you have to look at with LCD monitors and LED monitors is the response time. If it is 16ms then this is a very bad monitor for gaming and you will experience a ghosting effect in most games and if it is 5ms then you will have an average gaming experience. What you want to get is a 2ms response time monitor, with it you will have the best gaming experience with no ghosting what-so-ever.
on Mar 06, 2011 | Computers & Internet
My panasonic dvd player will not show the whole screen when in dvd mode
Hi
First make sure your Panasonic has 16:9 TV mode selected within its menu. Then try chainging the picture size on your TV. You didn't say what model TV you have. On my Samsung you would press the menu key then select picture, scroll down and select picture size. From hear you can select 16:9, wide zoom, zoom, 4:3. Try looking for picture size and selecting 16:9 on your TV.
Jun 03, 2014 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
THE PICTURE IS WAY TOO LARGE. THE PEOPLE ON THE SCREEN FILL UP THE WHOLE SCREEN. IT USED TO LOOK NORMAL SIZE & ON CHOPPED WE USED TO BE ABLE TO WATCH ALL 4 CHEFS COOKING. NOW ALL WE SEE IS ONE CHE
Ad? Turn off "store" or "display" mode in menu. Look for picture size or "aspect" in menu. Remote should have button for "Size" or something.
Feb 12, 2014 | Vizio Televison & Video
PICTURE TO BIG AT THE SCREEN.CAN NOT SEE THE PICTERS MARGIN AT THE SCREEN.HOW TO ADJUST(REDUCING PICTURE SIZE ON SCREEN)?
1) Power your wide-screen TV on and turn to a channel that is displayed with bars on the side. You need to leave this channel on to ensure you have properly adjusted your wide-screen TV.
2)
Find in your TVs settings where you can "stretch" the picture. Refer to your wide-screen TVs owner's manual for specific instructions. Some TVs may not refer to this adjustment as "stretch." You will be able to find all the information your looking for in the owners manual.
3) Adjust settings back to normal if you want to watch a program shown in 16:9 format. Keeping the screen "stretched" will cause programs shown in 16:9 format appear zoomed in, making the picture look really different.
Aug 14, 2010 | Televison & Video
Hi, I was recently given a Samsung Syncmasster 2333sw flat screen monitor that I hooked up to my old Dell Dimension 8200 desktop.The monitor says the optimum resolution is 1920x1080 pixels. The maximum the...
hi bob you should be able to adjust the screen size via the menu on the monitor itself, (Available in Analog mode only) Note When TV signal is input in AV mode ,select “Screen Fit “to adjust vertical position in 0-6 levels. Image Size Note Supplied for the wide models only such as 16:9 or 16:10. You can change the size of the screen displayed on your monitor. PC signals • Auto - The screen is displayed in accordance with the screen aspect ratio of the input signals.• Wide - A full screen is displayed regardless of the screen aspect ratio of the input signals. Note • Signals not available in the standard mode table are not supported.• If the wide screen which is the optimal resolution for the monitor is set on your PC, this function is not performed. AV signals • 4 : 3 - Sets the picture to 4:3 normal mode. • 16 : 9- Sets the picture to 16:9 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • 4 : 3 - Sets the picture to 4:3 normal mode. • Wide-Sets the picture to 16:10 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note • It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • When the panel is of 16:10,the screen size options include “4:3”,”wide “,”Screen fit“.hope this helps
Jun 22, 2010 | Dell Dimension 8200 PC Desktop
I have a Compaq Q2009 (new). The picture is too wide on the right side, cutting off the image about 1/4".
There are a series of buttons on the monitor. There's probably a Menu button that allows you to change the dimensions and sizes of your picture on the screen. You'll need to open the picture menu, and find the Horizontal picture options. There are normally two options - one changes the horizontal placement, and the other changes the horizontal size. You can play with these two options until you can see your whole screen.
Mar 07, 2010 | Compaq QVision 171FS (White) 17 in.CRT...
Cant get my picture to fill the whole screen
1st. Press ok/menu button.
2nd. Scroll using arrow keys on the monitor.
3rd. Find pic that looks something like this " (<->)" and widen to fit your screen.
Repeat with the height.
Apr 01, 2009 | Computers & Internet
Display appearing stretched
the original image size was probably recorded in 4:3 aspect ratio...meaning your widescreen is a 16:9 ratio size screen and is stretching it outwards to fill the whole screen. If you want the image to look normal.. ie. not short and fat people.... you need to change the picture size in the settings from widescreen 16:9 to normal 4:3 tv in the settings menu most likely...Also most remotes will/should have a button for that.
Oct 26, 2007 | ViewSonic VA1912wb 19" LCD Monitor
Acer 19167W flat screen
Depending on the application you are viewing the picture in you can shrink the application window. You could reduce the size of the viewable area but that defeats the purpose of the wide screen which is to provide a better viewing experience (to quote the marketing types). It sounds like....since the wider screen really has nothing to do with your picture size....you might want to adjust your picture size independent of screens and applications. There are a variety of free products out there that can do this...and some are really nifty...perhaps better than the software you might now be using.
Aug 02, 2007 | Acer AL1916W 19" LCD Monitor
Sova DSV32P112 32 in. LCD Television Logo
Top Sova Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
loony2ns
Level 1 Expert
Are you a Sova Televison and Video Expert? Answer questions, earn points and help others
