Question about Mitsubishi Televison & Video
I have a vs 6043 old tv. i have had a surround sound system(mitsubishi) RUNNING WITH IT. THE SURROUND SOUND AMP IS NOT WORKING AND I WOULD LIKE TO TURN THE SOUND ON THE TV, BUT CANNOT DO IT. I DO NOT HAVE THE REMOTE ORIGINAL. ANY HELP---THANKS
    Genius:
  • 1,847 Answers
You have get a remote for this, this link will help you.
http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=vs+6043+&uuid=12426581688530
Thanks
Kevin
Posted on May 18, 2009
No problem==somebody gave me mitsubishi-vs-6043 tv and i need to
When new that unit sold for around $2000 and $3000. But that is an older unit and you'd be lucky to get $500 for it now. It was manufactured in 1996 making it 13 years old.
Dec 28, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-5071 rear projection turns on, has audio but no video
That is a VZ3 chassis, similar to Mitsubishi models Ts-4545, Ts-5045, Ts-5545, Vs-4543, Vs-4544, Vs-5043, Vs-5044, Vs-5047, Vs-6043, Vs-6047 and has common failures in the vertical circuit, specifically vert Ic401 which is a La7845 which is usually caused by defective C402 100uf 50v and/or open 1.2 ohm 2 watt R510 next to FBT.
If not that check C268 off Q215 on signal board 22mf/50v and Ic200 on signal module Cxa2025s. However the vertical failure is more likely.
Bill
Sep 10, 2008 | Mitsubishi VS-5043 50" Rear Projection...
No picture
Sound like you lost Vertical Deflection.  Youshould not have a line across the screen because this could destroy the threeCRT Red, Green, and Blue (Picture tubes) if left on to long. There is a protection circuit built in to protect your CRT’s.    Check on the PCB-SIGNALboard (Tuner located on this board) transistors Q-206 Collector should be around 1 Volt Base and Emitter 0V. If the voltage atthis point is greater then 5 Volts the Vertical output IC-401 (Mounted on heat sink 7 pin inline IC) is bad, Part # LA7845.  Pin Voltages should be PIN 1= 0V, 2= 34V, 3= 32V, 4= 3V, 5= 3V, 6= 33v, 7= -6V.  Data sheet located at http://pdf1.alldatasheet.com/datasheet-pdf/view/40357/SANYO/LA7845.html
Jun 22, 2008 | Mitsubishi VS-6043 60" Rear Projection...
6043 6061 parts interchange
Well, you can use most of the parts, except that the shape of the boards are different, so you cant exchange the entire board as such.
May 20, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Mitsubishi VS-6043 - 60 inch
These are fairly simple, remove the speaker cover and then remove the screws at the bottom of the screen, then the whole thing lifts up and off, be sure to unplug the front panel controls, this plug can usaly be found just behind the cover behind the speaker grill
Feb 07, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Mitsubishi VS-8087
There are L and R audio outputs in the rear, so you can hook it up to a surround sound system; no optical outs.
The screen size is 80 inches - but I'm sure your friend told you that.
Nov 18, 2007 | Mitsubishi VS-8087 80" Rear Projection...
HOW TO RESET MY TV LOCK CODE
OPTION MENU "MENU 1370" SERVICE MENU "MENU 2357" CONVERGENCE MENU "MENU 2359"
Sep 20, 2007 | Mitsubishi VS-6043 60" Rear Projection...
Televison & Video Logo
29 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
