Question about Little Tikes Tractor with Cart
Light bulb keeps burning out in lamp post
I have replaced a light bulb in my outside lamp post within days of each other. The last one i replaced had water inside the bulb. There is a cover to the post. i don't see how water can get inside. Many times the bulb is shattered. How can I fix this problem? I appreciate any ideas. Thanks!
My replacement bulbs keep burning out within 30 days. I took a closer look and there is a small square piece of glass that sits next to the lamp housing. It looks as if the light from the lamp goes through...
Something is definitely wrong if you are consistently only getting a month out of a bulb.
Either something is overdriveing the power to the bulb (unlikely) or there is a vibration or something is intruding on the bulb itself.
Good luck and let us know what you find on this.
Jan 08, 2015 | Mitsubishi WD-57732 Projection Television
Bulb burned out in 1 month
Your lucky it lasted 1 month. The population thinks they are receiving inexpensive items from China. Instead they are cheap useless rubbish. You will find that anything from Asia costs half as much and only lasts 1 tenth of the time. DO THE MATHS PEOPLE WE ARE BEING RIPPED OFF. While Asia is getting rich.
Dec 08, 2013 | LC EPSON ELPLP68 / V13H010L68 Projector...
Origional Epson 3010 bulb burned out after 2 years. New bulb died in a month
our company supply the Original lamp ,unit price is USD200
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
I have a Model ml 44t, when the temp outside became cooler my timer would not turn on the lights, it would stop rotating at the red post.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/professional%20lighting/ml44t%20trilingual.ashx
-I think your outdoor plug is connected to GFI plug in bathroom or kitchen >>> check reset on GFI.
-Next, plug your hair dryer into same outdoor plug to see if plug has electricity >>> electrical plugs outside wear out quicker, and get loose wires.
-Move timer cord to the other plug
-I don't know if a bit of WD 40 would help or not .... couldn't hurt to spry some on the pins at this point ...UNPLUG timer because WD is very flammable...
-Tips from manual mention checking for burned out bulbs ... I've seen that mentioned other places and don't know if bulb problems shorten life of low-volt transformer inside the box.
-I worked with timers for years, and never seen replacement clocks or transformers for Malibu-type timers
-Timers located outside get damp and dirty ... these things cause small gears inside timers to oxidize and clog so they don't work after a while ... again, a bit of WD-40 might help
Tips copied from manual:
• Make sure power pack is plugged in. Is outlet working?
• Turn manual ON/OFF switch to "ON" or rotate dial so "ON" tripper passes time line indicator.
• Is lamp burned out? Use another lamp to test.
NOTE: This lighting system is designed to last many years under normal conditions. However, lamps eventually burn out and operating with one lamp out can shorten the life of the others. IT IS IMPORTANT TO REPLACE BURNED OUT LAMPS PROMPTLY.
Conditions beyond your control such as abnormally high household voltage due to poor utility voltage regulation will also affect lamp life.
The timer has 1 year warranty.
Oct 04, 2010 | Malibu ML88TL 88Watt Low Voltage Power...
Sony KDF50E2000 lcd tv has burned out it's second bulb. Replacement bulb was OSRAM brand. It only lasted 10 months, now it won't come on. Should I be looking at the ballast or did I just get a poor...
Hi,Osram lamps average around 3000-4000 hrs.Normally 1 -1 1/2 yr.I do think the lamp went out.The ballast is a possibility,when it's going bad it will make clicking noises or attempts to light the bulb.I recommend to get the Original Philips lamp for they average 6000-8000 hrs 3-4 yrs.
Mar 25, 2010 | Sony KDF-50E2000 50" HDTV
Head lamp keeps burning out. replaced head lamp at
You either have a bad ground or the bad electrical connection at the light socket is "simulating" a bad ground. This is putting a high resistance on the bulb and it's taking it's toll by burning out the bulb. I would start with a new socket, and CHECK the ground. If you still have the issue, I would run another complete ground wire and not even worry about checking the ground itself. the Stick
Dec 10, 2009 | 2006 Suzuki Grand Vitara
Light bulbs on outside lamp keep burning out prematurely.
this is a tough one to solve.... outdoors is a harsh environment and bulbs often don't last long. Several things lead to premature failure. One is the fixture is getting too hot , use lower wattage bulb. Two - do the math if the bulb is on 8 -10 hours a nite..... doesn't take many days to kill it. not sure about those average hour life ratings. try using those flourescent bulbs those last a long time and use less juice.
Nov 20, 2009 | Sylvania Electrical Supplies
My 10 amp tail light fuse blows within seconds of me installing a new one. the signal light works.
Check for a short in the wiring, particularly at the bulb sockets connection.
If you have a trailer connection socket, check this also for frayed/damaged wires.
Replace any bulbs that are damaged or suspected faulty.
If you still cant find any problem, remove all bulbs on the tail light circuit - replace fuse - check that is doesn't blow.
Install bulbs one at a time - check fuse as each bulb re-installed- if fuse blows when a particular bulb installed the faulty circuit/bulb is then identified.
Nov 08, 2009 | Isuzu Pickup Cars & Trucks
One surface light bulb on GE Profile microwave keeps burning out
I have the same problem. The left one burns out within a couple of hours use, the other one lasts a couple of months and is then gone. This pattern has repeated over 8 years. I replace them every now and then and then just go without until I get the urge again to fix it. Maybe smaller lower wattage lamps are worth trying...
Jun 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Dell mp5100 " lamp failure"
Have you tried cleaning all air in-take spaces ? On mine the lamp failure was triggered by temperatur. Afetr hoovering the projector and removing all dust the same lamp worked flawlessy.
Jan 08, 2008 | Dell 5100MP Multimedia Projector
Little Tikes Tractor with Cart Logo
144 people viewed this question
Top Little Tikes Toys Experts
Jim Goldsmith
Jim Goldsmith
Adam Fjeld
Adam Fjeld
Are you a Little Tikes Toy Expert? Answer questions, earn points and help others
