Question about Dishwashers
Miele G975 SC plus noise drying water in door
  • 14 Answers
SOURCE: Miele dishwasher drying problem
you need to remove the front of the door.there is a small pipe from the dryer fan to the top of the detergent dispenser. tis usualy gets blocked at the fan end. also the spout from the fan. this happens if you dont rinse loose food of the items you put in the dishwasher.
Posted on Aug 26, 2009
mnwarfield10
  • 452 Answers
SOURCE: Miele G646 SC Plus -
flow meter.................
Posted on Dec 21, 2009
SOURCE: hi my miele dishwasher g665 no hot water or drying
new heating element
Posted on Jan 27, 2010
  • 70 Answers
SOURCE: Water collects in door during drying cycle
The drain hose for the dryer fan is blocked. If you remove the outer door (six Screws three bottom screws down either side) you will see a hose that runs from the bottom of the fan to the top of the detergent dispenser, removed hose and clean this will resolve the problem
Posted on Jun 30, 2010
SOURCE: I have a Miele G841
I had a problem where my G842Plus dishwasher would run through the prewash and then the intake/drain light would start blinking and it wouldn't work. There would be water in the bottom of the dishwasher. After cleaning out various items to no avail, we called Miele technical support and they told us to reset the codes and then keep trying it over and over until it worked.
Here is how we reset the codes:
  • Turn dial to stop/off
  • Turn dial to Normal Plus
  • Press Start
  • Press power
  • Then press the start button for one second and let go
Posted on Jan 09, 2011
Miele dishwasher G646 SC plus water pump
I would suggest any appliance repair shop or appliance retail store should be able to order one in for you
Sep 06, 2012 | Miele Dishwashers
Hi Service, I have a Miele dishwasher model G692 SC Plus which has a problem with the drying fan filling with water during the wash cycle. We open the door at the end of the cycle and water drains out...
You have the Miele problem.
This happens every year or two. Take off the outside front panel to access the hose that runs from the bottom of the fan down to the dispenser, and lets the water drain out through it to the interior. Clean out that hose as well as you can. Replace. This is a stupid problem that Miele should have a permanent fix for. Grrrr.
In fact I just did this with mine today. The hose cleans out quickly, the problem is getting the front back on. 4 hands make it easier. It slips on when you start close to vertical, then slip in in and down. For putting the screws back in, you might have to use a micro screwdriver to re-align the little clips on the door panel. (You will see what I mean when you do it!) This costs a service call ($100, give or take) to call for service. It can be done at home with no added parts. I think it applies to all Miele dishwashers, and I have now done it several times. As I said before, this is a design fault and should not be necessary!
PS: I still have the puddle on the floor, so am trying again only 3 days later! But this has worked several times before.
Jan 16, 2011 | Miele Dishwashers
Hi, Our Miele G611SC plus is making a high pitched noise for about 1 minute when (I think) it is on the rinse cycle. When it then changes to the next cycle, the high pitched noise stops. We got the unit...
Hey Berni,
I've been having the same problem for quite sometime with my Touchtronic G 892 SC. It goes away if I open up the cabinet under the sink and wiggle the water inlet hose where it's connected to the dishwasher's "backflow" water inlet. I'm getting ready to disconnect the fitting and see if there's lime (or some other type) of buildup in the filter screen. I don't know what else it could be. I'll try to follow-up when finished with this task.
Nov 02, 2010 | Miele 18 in. G611SC Plus Slim-Line...
Water staying at the bottom of the washer.When i close the washer an press start the inlet/drain light comes on and nothing else happens.Miele G 692 SC PLUS
Your drain outlet is blocked , pull all the filters out and then check nothing is stopping the impeller from turning. You have to bucket out all the water first of course. It can be a toothpick or just some gunk,
Mar 25, 2010 | Miele 24 in. G692SC Plus SS Free-standing...
Have Miele G653 SCVi plus. We have inlet/drain flashing red light
Sounds like something is caught in th drain pump as the unit has to drain first before anything else happens. Remove the filter and the non return valve which is under the clip in the sump of the unit. In the manual it shows you this. Make sure the drain pump is free of any foreign particles like broken glass. Then start the unit again so it goes to drain without the non return valve in place. This will then throw out any foreign particles as well.
or it could be the drain pump is activated all the time which is the noise you hear as there is a flood in the base of the unit which activates the float switch and constantly activates the drain pump until the water has gone. Isolate the unit at the power switch and remove the bottom panel under the door panel. Dry up the water as best possible with a towel. You will see the float at the front. Run the unit again and check for any water leaks. You may just have over sudded the unit with too much detergent. Only use 2 teaspoons of powder. To start with while testing don't use any detergent. Good luck
Feb 22, 2010 | Miele 24 in. G653 SCVi Plus Built-In...
Miele Turbomatic G590 SC Not enough water
See page 31 of the manual for possible solution. The manual is here: http://miele.com/manuals_pdf/Residential/Dishwashers/English_manuals/Operating_Instructions/G590_us.pdf
Aug 29, 2009 | Miele 24 in. G656SCi Plus SS Built-in...
Change miele dishwasher door seal
http://www.partstap.com/ please go to this site for diagram please rate me thank you for useing fixya
Feb 25, 2009 | Miele Dishwashers
Mar 30, 2008 | Miele 24 in. G646SC Plus Free-Standing...
Miele Touchtronic G892 SC Water leak at base of door
check the rubber seal around the door to see if its torn or smashed. if it is replace it, could someone have set somthing heavy on the door while it was open that would have stressed the hinges. it is most likely one of these problems take a nail file and slid it gently between the door and the body of the dishwasher if it slides in easy where it leaks you know the seal is bad and replace it.
Dec 09, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Dishwashers Logo
42 people viewed this question
Top Dishwashers Experts
