Question about Harold Imports Chrome Timer
Quantum battery 1+ Question: Can't find my manual. How do the LED's indicate a full charge? Plugged the unit into AC: Initially the ''Off-On'' and four battery level LED's came on. Now the ''Off-On'' has gone out. What is the ''fully charged'' indication? Thank you.
    Problem Solver:
Test test test 18:08
Posted on May 26, 2009
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
Dell inspiron not charging
Dear Mathew,
You should you Dell Utility and it has the function called Dell Battery Metter, it can enable or disable charging
Nov 12, 2012 | Computers & Internet
How long do i have to charge the stanley j309 300 amp battery booster
Before the first use, the unit must be charged for 24 hours with a connection to an AC outlet (120V). Make sure that all of the switches are off. After that, stop charging when two red and one green LED Battery Status Indicators light.
If you are recharging the unit from a 12V battery, do not charge for more than 6 hours. (Check for a full charge by disconnecting the DC charging adapter and then press the Battery Power Level button.)
The manual for the Stanley J309 battery jump starter is available on the product page here: http://www.baccusglobal.com/stanley/j309.php . The direct link to the manual is http://www.baccusglobal.com/stanley/manuals/JUMPERS/J309%20MANUAL.pdf .
I hope this helps.
Dec 29, 2011 | Garden
I have an almost similar problem. When plugged in, the AC/ Battery LED indicator does not light up and I can't power up the unit. Sometimes when I take out the battery and put it back in, the unit powers...
Yes this fault is in the mother board but the fault is the switching/regulation/charging section of the pwoeer supply section.
Somehow it is not switched on auto and so the malfunction. Might have to remove and check the powerr section for errors in the regulator.
Sep 23, 2010 | Acer Aspire 4520-5582 Notebook
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
My phone only works when it's plugged into the charger
New batteries are shipped partially charged. Before you start using your device, it is recommended that you charge the battery. Some batteries perform best after several full charge/discharge cycles. You can charge the battery in two ways: • Charging the device’s battery by connecting the power adapter. • Connecting your device to a PC via the provided Mini USB cable. Note: Only the AC adapter and USB cable provided with your device should be used to charge the device. Charging is indicated by a solid amber light on the left LED indicator. As the battery is being charged while the device’s power is on, a charging icon will be shown on the title bar of the Today screen. After the battery has been fully charged, the left LED becomes green and a full battery icon appears on the Today screen’s title bar. Warning! Do not remove the battery from the device while you are charging it using the AC or car adapter. As a safety precaution, the battery stops charging when it overheats. When the low-battery warning appears, do the following: • Immediately save your current data. • Synchronize with your PC or connect the power adapter to charge the battery. • Turn off your device.
Hope this helps, let me know if I can help you with anything else.
JimmyC
Jul 14, 2009 | UTStarcom Blitz Cell Phone
I have a toshiba laptop, and in the last few weeks something weird started happening. When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries,...
Change your AC charger.
It's NOT charging "When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries, and the battery level drops by about 1% every few hours"
That's the reason why: "battery has completely died"
If you do not change it you'll continue to "still it gives me the same low battery indication and will not turn on. "
Jan 04, 2009 | Computers & Internet
Power indicatoror
From the manual:
"Attach the barrel tip of the AC Charging Adapter to the AC Charging port of the POWER TO GO® and plug the standard two-prong plug into an appropriate, functioning 120 volt AC outlet. The red Battery Status LED indicator will flash, indicating a proper connection has been made and the unit is charging. The green Battery Status LED indicators will gradually light as the charge level rises. The POWER TO GO® must be charged for approximately 11-17 hours prior to first use. All Battery Status LED indicators will be lit solid (the red indicator will stop flashing) when the unit is fully charged.
Aug 29, 2008 | Black & Decker Power To Go Cordless AC/USB...
Removing battery
If there is a CMOS battery it should be replaced but it could the AC adapter might need to be replaced.
Jul 20, 2008 | Computers & Internet
Unable to charge battery on Audiophase MP3, model KZ111
Try using the AC charger for the mp3 player, If It does the same thing, Ur MP3 is defective and u can return it with out the receitp sayin that it was a christmas gift since most eleftronics have a 1 year warranty
Feb 07, 2008 | Audio Players & Recorders
Harold Imports Chrome Timer Logo
412 people viewed this question
Top Harold Imports Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Harold Imports Hardware and Accessory Expert? Answer questions, earn points and help others
