Question about NetGear Computers & Internet
I need to know my password my NETGEAR ROUTER IS WORKING FINE my wifi is working fine
The router password is the one on the router label marked as KEY. Hope this helps.
Posted on May 03, 2014
mattozan
  • 555 Answers
SOURCE: cannot get password authorisation for netgear router
The default username and password for the Netgear DG834G router is:
username: admin
password: password
If that does not work (i.e., the default password has been changed), then the only way for you to log into the router is to restore the router back to its default factory settings. Then you will be able to use the default username and password above.
To restore the router's factory default settings, you must use the Default Reset button on the rear panel of the router.
1. Press and hold the Default Reset button until the Test LED turns on (about 10 seconds).
2. Release the Default Reset button and wait for the router to reboot.
Posted on Apr 03, 2008
  • 73 Answers
SOURCE: forgot my password on netgear wifi
If I understand your question correctly, you need the wireless key for your network.
1) If you have a computer that connects to the router wirelessly already, you can recover the wireless key by downloading this program: http://www.nirsoft.net/utils/wireless_key.html. It will show you the key the computer is using to connect to the network.
2) Log into the router and change the wireless key. You can start here to find the manual for your particular model:
http://kb.netgear.com/app/products/family/a_id/1296
Don't forget to rate this solution!
Posted on Feb 06, 2009
anandg27
  • 1272 Answers
SOURCE: iPhone keeps dropping wifi signal on Netgear DG834G router.
Hi, please perform the below steps to configure settings on the router:
1. Connect a computer to the router using any one of the 4 available ports.
2. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
3. Access the router, usually with http://192.168.0.1 or http://www.routerlogin.com.
4. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
5. Click on WAN setup from left menu. Check the box for 'Disable Dos Protection'.
6. Set the MTU size to 1400. Click apply.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jan 08, 2010
SOURCE: I can't access the internet via my Optus Netgear
I am having exactly the same problem. It occurred on Sunday 17th. I have phoned Optus who seem unable to work out what has happened. It will work wirelessly but not recognise it when set up via ethernet cable.
Posted on Jan 18, 2010
  • 825 Answers
SOURCE: belkin wireless G router incompatible with netgear modem
connect your computer to netgear modem alone and check for the ip address in the computer
(make sure that you have selected "assign ip automatically" in computer)...
to open command prompt type "cmd" and hit enter in run box...
then you can check ip address by typing "ipconfig" in command prompt...
make a note of IP adress or ipV4 address found under the heading "ethernet adapter local area connection"
it might be 192.168.X.X
now connect only the belkinrouter and check for the ip address using the same steps above...
it might be 192.168.2.X
make a note of that...
now compare both the ip addresses if they both have the same value in first three places...that is
192.168.2.... or something like 192.168.1.... or 192.168.0.... then you are facing with double NAT issue...
all that you need to do for that is to change the ip address of belkin router...
if it is 192.168.2.1 change into something like 192.168.15.1...the issue will get resolved....if not you can reset the belkin
router by pressing and holding the reset button for 30 seconds using a toothpick when the power is turned on...
Posted on Apr 03, 2010
Testimonial: "Hey there. It took me ages to get around to trying your solution. I was prompted by my old modem dying. Your solutions was perfect."
My iPad is asking for password for NetGear 95 I don't know it
Is the Netgear 95 your wifi router? If it is go to settings/wifi click in the Netgear 95 then click the little "i" on the right for more options. If you have an option to "forget this" click it. Do a hard reboot of your iPad (holding down home and lock button) till it restarts. Once it powers up go back to setting/wifi and try again to connect. That's how I got it to work on my iPhone and iPad when encountering the issue.
If that doesn't work restart your router. Last resort is to change the password but again I've never had to do that. The steps above usually did the trick.
May 18, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Got a Netgear wifi extender but my current password won't work to access the new_ext network.......don't know what to do!
You need a new password to access the new wi-fi extender, you cannot use the existing router password.
Oct 20, 2013 | NetGear Universal WiFi Range Extender...
I have a MiniDell Inspiron Netbook that will connect to the internet through a neighbor's WiFi, but will not connect through my own Netgear router. The router is working fine for 2 other connections. How...
You may want to do a reset on the router by holding down the reset button on the back of your router. That will reset and MAC address filtering or any other security that you might have turned on.
Mar 08, 2011 | NetGear WGT624 Wireless Router
Netgear password for wi-fi , for xbox live and ipod
Wifi password can be obtain by accessing the Netgear WPN824 router using a computer connected to it.
How to access the router
Go to http://www.routerlogin.net
username: admin
password: password
-Click wireless settings
- security encryption options would display the WIFI password.
- its the KEY1
Jan 01, 2011 | NetGear RangeMax WPN824 Router
I don't know how to connect my second laptop to the netgear router to get internet service.
Go to the first pc that is already connected. Right click your connection and note the status/advanced information, find the gateway IP address. Open a web browser and login to your netgear router. NetGear default is admin and password.
Now go to the wireless setup, note the ssid or name of your wifi network, also note the security encryption and phrase you are using. If you don't remember you can set it again there and save but then you will need to reconnect to it, if all else fails use a data cable and plug directly up to the router to manage it.
Once you know your wifi name and security key you setup, go to pc 2 and use the wireless utility scan or refresh you should see the name of your wifi network, click join to connect, it will challange you for the password. It if doesn't then all of your neighbors can use your internet and access your computers. Need to be sure to secure your wifi signal by managing it via the web management using your web browser.
Aug 29, 2010 | NetGear WGR614 Wireless Router
How to set a password for my wifi netgear wireless-G Router?
try 1234 as the password. failing that go to this page for instructions on how to reset the password. http://kb.netgear.com/app/answers/detail/a_id/9665
there is even a video on how to do it but be aware that this will reset your rounter to factory (default) settings.
robert
May 11, 2010 | NetGear WGR614 Wireless Router
Unlock wifi dublin ireland
Most of the NETGEAR devices, except ReadyNAS products and Fully Managed switches, have the following default username and password:
  • Username = admin
  • Password = password
    • For older devices, password = 1234
Feb 12, 2010 | NetGear WGR614 Wireless Router
Forgot my password on netgear wifi
Feb 06, 2009 | NetGear WGR614 Wireless Router
Computers & Internet Logo
16 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
