Unlock region codes philips dvp 2850/79 - Televison & Video
rizla
  • 1463 Answers
SOURCE: DVD PLayer Region Unlock
hello mushkil
you could try the following
1. Turn on the unit
2. Open the loading tray
3. Press the "Setup" button on the remote
4. Navigate to the "Preferences" page using the right arrow key
5. Enter 138931
6. You will now see the current region code displayed
7. Use the Up/Down arrow keys to select the region required or "0" for all
regions
8. Press the "Play" button on the remote
this should unlock it to all regions .
riz.
Posted on Aug 16, 2008
jaffa012001
  • 376 Answers
SOURCE: Philips DVD Player DVP 3026 set for Region 5 - Unlock code
1) Open the tray
2) Press SETUP on the remote.
3) Navigate to PREFERENCE menu
4) Go to PBC
5) Get in inside PBC menu so that ON is highlighted with yellow color
6) Key in 138931 and a menu will appear asking you to select region code.
7) Select REGION 0.
Posted on Sep 09, 2008
futureloginn
  • 734 Answers
SOURCE: Unlock regional code for Sony DVP-NS575P
1) Turn your DVD off. 2) Use the remote control and press:
- Display
- Top Menu
- Clear
- Power
This should power the device into Service Mode.
3) Choose option 2 and then choose option 4.
4) There should be two fields: Input Code and Current Code, each one with 5 chars long.
Type: 12450
Then push zero on all the 5 places of the first and the second field.
Push ENTER.
5) There should be a zero on the device display, meaning that all regions are free.
6) Press POWER to turn it off and you're done.
Let me know if it works!
Posted on Dec 14, 2008
  • 8 Answers
SOURCE: Unlock region code for Philips DVP 3256
Region code hack for PHILIPS 3256 x/94
1. Go to Setup. [from remote]
2. Select the Preference Page.
3. Press 1, 3, 8, 9, 3, 1 on the Philips DVD Player remote.
--> It will show current region code [ for example 5 ]
4. Now Press the up/down key to select "0" which makes it region free.
5. Press ok and exit setup.
Probably the same would be applicable for 3258, 3268, 3986.
Good Luck!
Posted on Jan 07, 2009
nicknkell
  • 41 Answers
SOURCE: philips DVP3350
hello mate here are the instructions. First you have to download "ZORAN.ZIP" and extract to desktop you will now have a
file which name is "LG36868.IMG"
2. Then You have to burn this file to cd>
3. Insert the CD into player after burning the CD.
4. Then the region management menu will be shown.
5 If you input '0' and press 'pause key' by
Remote Con. Then Code free is done.
Download the ZORAN.ZIP
http://www.divx.pri.ee/index.php?name=Forums&file=viewtopic&p=387#387
please leave rating if you find this usefull thanx
Posted on Jan 27, 2009
Philips dvp 2850/79
It is not possible to unlock region codes. Most DVD (blue ray players) allow you to change the region code you can play, once. You can't even switch back to the original code it was set when you bought it.
If you really want to play disks, the only way to get around this, to rip the disc on a computer, and burn it on the computer, region free. For that you need special program m's, but in some countries you can get these programs for free.
Or buy several players, each set to a different region.
Sep 16, 2014 | Televison & Video
Unlocking region code Philips DVP-3886
1. Power ON the DVD player with no disc inside
2. Goto SETUP and go to Preferences
3. With preferences highlighted, Press NEXT CHAPTER>', PREVIOUS CHAPTER '<, NEXT CHAPTER>',
PREVIOUS CHAPTER '<
4. The OSD will show the current Region Code
5. Press the Navigation Up or Navigation Down buttons to
select your desired region, or 0 for region free
6. Press OK to confirm your region selection
May 21, 2012 | Televison & Video
I bought some DVDs at amazon.com, but I live outside the region code area witch the DVDs are supposed to work. I live in code area 4. I need someone to find a code to region 1. I have a Phillips home...
This player is relatively easy to change to region free. Please complete all of the steps below to unlock your DVD player.
Please note: Unlocking any DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
Unlock sequence for the Philips DVP 3020:
1. Switch on your TV and DVD player;
2. Make sure the TV is set to the correct input for the DVD player;
3. Remove any disc from the DVD player and close the disc tray;
4. Press the "SETUP" button on the DVD player remote control;
5. Use the LEFT/RIGHT arrow keys to highlight "PREFERENCE";
6. Enter 1 3 8 9 3 1 using the numerical keys on the Philips DVD remote control;
A pop-up menu will appear on the TV screen.
7. Use the UP/DOWN arrow key and choose "0" for all regions;
That's it. You should now be able to watch DVDs from all regions on your player. It is also a good idea to switch the player to standby and then switch it back on before trying any discs.
This is a verified unlock sequence for the Philips DVP 3020. If it doesn't work the first time, switch the power off and start again at step 1. If it still doesn't work, it is likely that you have updated your Firmware to a new version and this unlock sequence does not work with your firmware version
If you need further assistance, please reply to me from within this page and let me know which firmware version you have installed in your DVD player.
Regards,
BElectric.
Jan 28, 2011 | Philips Televison & Video
Good Luck!
Jan 02, 2009 | Philips DVD625 DVD Player
DVD dvp 3120 is currently zone 4. Would like to make it multi zone
1) Go to Setup page
2) Preference page
3) Press 138931
4) Press up/down key to select region code
Sep 13, 2008 | Philips DVP5140 DVD Player
Unlock region code
Keep Tray in eject position
Press Setup from remot
Go to preference page
Press"138931"
Using Navigation Key chane region code to "0"
Press "OK"
OR
open tray
press 98790
Jun 25, 2008 | Philips DVP3040 DVD Player
Wrong Region message
DVD player must be made region free by unlocking it.. after that you can play all the discs you want.. for ubnlocking it you can try google//
Jan 19, 2008 | Philips DVP-3005 DVD Player
Region Free Code: Philips DVP 5980
this worked perfectly, thank you!
Dec 19, 2007 | Televison & Video
Region codes
Philips DVP 3015K / DVP 3020 / DVP 3040 / DVP 3040K / DVP 5140 / DVP 5960
  1. Method 1:
  2. Open the disc tray
  3. Press SETUP
  4. Navigate to the preferences page
  5. Enter 138931
  6. Select the region using UP/DOWN
  7. Press PLAY
  1. Method 2:
  2. Open tray
  3. Press 9, 9, 9, 9, 0
REGARDING UNLOCKING OF DVP 3028 REGION CODE C1
1st: Start the DVD player, make sure there is no CD/DVD inside.
2nd: Bring up the System Menu.
3rd: Go to Preferences, press 138931.
4th: Use the Up/Down arrow keys to select the region 0 .
5th: Exit the screen.
You can now play DVDs of any region. Enjoy!
Dec 01, 2007 | Samsung Blackjack SGH-I607 Smartphone
Televison & Video Logo
969 people viewed this question
Top Televison & Video Experts
Electro Med Services...
