0xc00000eg the computer is gevin me 0x00000eg
Classifications of computer
types of Computer According to Operation.
There are three basic types of computer according to their operation:
1. Analog Computers.
2. Digital Computers.
3. Hybrid Computers.
1. Analog Computers:
"Those computers which are used for measuring of physical quantities are calledAnalog Computers". Analog means variable and physical quantity always changes.
"Those computers which measured analog type of data are called Analog Computers"
These computers accept input in analog form and provide an analog output of information. It represents physical quantities like distance, velocity, acceleration and temperature. It measures continues changes in physical quantities. e.g. speedometer of a care, temperature, needle's watch for measuring the time, volt meter for measuring voltage. Now a day analog computers are using for Engineering and Scientific works. In Oil Refinery measures flow and temperature of oil. They are also used in Paper making and Chemical Industry. Out put of the analog computer is generally in the form of readings. These computers are dial in situation where data can be measure directly from measuring instrument without having to convert into numbers or codes. Now a day Analog Computers are proceed to Digital Computers. For example: Analog watch to Digital Watch, Analog Balance to Digital Balance and Analog Thermometer to Digital Thermometer etc.
2. Digital Computers:
"Those Computers which accept digital input and provides information in digital form are called Digital Computers".
"Those Computers which measure in term of digital quantity are called Digital Computers".
These computers works on the base of binary digits i.e. (0 & 1).
The results of the Digital Computers are more accurate, precise and reliable then the result of Analog Computers. Digital Computers are faster then Analog Computers. Analog Computers lack memory while Digital Computers store information.
Accounting machine and Calculator are the common example of Digital Computer.
Now a day Analog Computers are proceed to Digital Computers. For example: Analog watch to Digital Watch, Analog Balance to Digital Balance and Analog Thermometer to Digital Thermometer.
3. Hybrid Computers:
"Those Computers which accept digital inputs and provides outputs in the form of analog and vice versa".
Hybrid Computers have the characteristics of both Analog & Digital Computers. It is the computer which measures both the analog and digital quantities. It combines the both features of analog and digital computer. Hybrid Computer has process with the speed of analog and accuracy of digital computer. They are used for special purpose. These are designed to perform special task. For example ECG machine. Hybrid Computers are also used in Air Defense System. Data Communication and Transmission and in different laboratory for medicines.
Basically computer has two types according to their function.
1. Special Purpose Computers:
2. General Purpose Computers:
1. Special purpose Computers:
"Types of computers which are manufactured for specific task are called Special purpose Computers".
These computers are also known as "Dedicated Computers" because these are designed for special jobs. In other words they are designed to handle specific problems. e.g. they are used in Computer Games, Control of Traffic Lights and in Defense System. A set of instruction permanent program feed to them. As they have to perform only one job so they are very fast.
"Types of Computers which can perform all types of jobs and can run all types of programs are called General Purpose Computers".
Those computers are performing variety of jobs and use for General Purpose. For example with a personal computer a user can perform typing, can play games, can make graphics and can do arithmetic operations. General Purpose Computers are versatile but they are slow in processing and less efficient as compare to Dedicated Computers.
Classifications of Computer Classifications of Computer
Computers are classified into different categories according to their physical size, cost and speed. We can general classified them into 05 categories. (Classifications of Computer)
1. Very Small (Micro Controllers)
2. Small (Micro Computers)
3. Medium (Mini Computers)
4. Large (Mainframe)
5. Very Large (Supper Computer)
Jul 12, 2011 | Computers & Internet
Tip
Connect your home computer from Remote location.
Using the Remote Desktop feature, you can connect your home computer (host) from any other remote computer (client) and can access all computer resources (installed programs, data and any network resources).
You can run any computer application on the remote computer as you were running actually sitting in front of home computer.
Follow the given steps to configure your computer to connect remote computer: To use this feature, you will need to be logged into your computer with administrative rights.
-To perform this task, first make sure your both computers are connected to the internet.
-First you have to configure the host computer that allows the users to connect it remotely. On the host computer, right click on "My computer" and click on Properties option.Under the Remote tab, select the option "Allow users to connect remotely to this computer" and click Ok button.
-Now get the IP address of host computer (type the "ipconfig /all" on the command prompt of host computer to find IP address).
-Now make a connection on remote or client computer, click on Start button, go to All Programs> Accessories, and Communications, then click on Remote Desktop Connection, option. A Remote Desktop Connection, dialog box will appear.Click on Options button for detail configuration, under the General tab, type the IP address of host computer in the Computer box and also type username and password of host computer then click on Connect button to make a connection to remote computer.
-If your username and password is correct then a remote desktop windows will appear.
Good luck.
on Apr 15, 2010 | Computers & Internet
Tip
How Often should i clean my pc?
Where is computer located? In a home environment In a clean office environment In construction / industry environment In school environment Computer environment Have cat / dog in same building as computer Smoke in same building as computer Smoke next to computer Computer is on floor Room that the computer is in has carpet Eat and/or drink by computer Who uses it? Adult (18 and older) Young adults (ages 10-18) use computer Pre-teen (younger than 10) use computer More than one person uses computer
Based off what has been checked above you should be cleaning your computer every months.
on Mar 13, 2010 | Computers & Internet
Have a acer aspire one and i got this file\boot\bcd status; 0xc00000eg info : an unexpected i/o error has occurred
If you have backup disks with your data on and a recovery disk, now is the time to use it, otherwise, press F8 as it boots and select Safe Mode. Run CHKDSK/F and hope that it can repair the errors. If it does, close the computer down and re boot as normal.
Hope that helps.
Dec 30, 2010 | Acer Aspire 3680 Laptop
Tip
Computer Care
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How to Save Money with Preventive Computer Care
The most important activity that you as a computer user can do is to keep your computer as clean as possible. Your system's user guide is the best source to find specific information about how to clean your system's outer components; but here are some basic tips you should always follow.
Computers are an everyday part of life in the modern world. However, computers require special attention and care in order for them to function properly and to operate safely. Here are some basic guidelines to help you maintain your computer equipment and to keep your equipment functioning for a long time. After all, keeping your equipment running will save you money.
Prevention to be taken on your computer
  • Keep computer equipment away from direct sunlight to prevent overheating.
  • Keep computer equipment away from direct exposure to water or humidity to prevent damage.
  • Keep computer equipment in a clean and dust free area.
  • Always use surge protectors to prevent electrical surge damage to your system.
  • Place an anti-static mat in the area where you are operating your computer to eliminate or prevent anti-static damage to your system.
  • Have your system's interior cleaned at least once every year to keep it running smoothly and to protect your investment.
Things to be cautioned about while operating your computer.
  1. NEVER eat or drink while operating your computer. Food crumbs can easily damage your computer.
  2. NEVER place an open container containing water on or near your computer to avoid electrical shock.
  3. NEVER use your computer's keyboard with dirty or sticky hands.
  4. NEVER allow your pets near your computer. Dust and hairballs can accumulate inside the computer's case and cause your system to overheat.
  5. YOU SHOULD NEVER spray any type of cleaner into your computer's air vents or you could damage your system.
Computer maintenance
Basic computer maintenance should be part of your regular routine. Keeping your computer dust and dirt free, will guarantee that your computer will last and will give you years of reliable performance. Please consult your user's guide for more specific maintenance practices and intervals.
How to clean your computer system
Computer systems require cleaning of internal parts especially when used outside of a clean environment. However, only an authorized technician should open the computer case and clean sensitive electronic components. Consult your user guide to determine the best interval for internal cleaning and take your computer to a certified technician.
Monitor screen
Your computer monitor is likely to be the component that will require the most attention, because computer monitors tend to get dirty from regular use and from dust. To clean your computer monitor or LCD, you can use special chemicals design to clean computer monitors without damaging them.
To clean your computer's screen you can use OPTECH CTR Screen Care. This special cleaner is an anti-static cleaner and coating which safely removes fingerprints and smudges from computer display screens. This cleaner also leaves the surface treated with an invisible dust repellent film, which contains an optical ingredient which fills-in minute scratches eliminating surface distortion and reducing eye fatigue.
How to apply a computer screen cleaner
First, NEVER spray the cleaner directly onto your computer. Instead, spray a lint-free cloth lightly with the computer screen cleaner, and then clean your screen. Be sure to hold the cloth away from your computer when spraying the cleaner to the cloth.
Keyboard maintenance
Dirt and other debris can fall or accumulate between the keys and cause damage or prevent the keys from functioning properly. To clean your computer's keyboard you must use either canned air/gas or a small computer-specific vacuum cleaner. NEVER apply any cleaner or liquid directly to your keyboard. If the keys are dirty, use a lint-free cloth that has been sprayed with computer cleaner to lightly and carefully clean your computer's keyboard. DO NOT clean your computer while the computer is operating, and avoid using your computer till the cleaner has dissipated to avoid possible damage to your equipment. Consult your user's guide for precise instructions on your particular machine.
Case/Tower maintenance
Your computer case will require maintenance. You should remove dust and grime from your computer's air vents and your computer's case. ALWAYS use canned air/gas to clean your computer's vents or air intakes. Canned air/gas cleaners are idea for cleaning air vents, keyboards, disk drives and computer case crevices. The exterior of your computer's case can be cleaned with a lint-free cloth sprayed with an anti-static computer cleaner. When in doubt about how to clean your computer system, ALWAYS consult your user manual or call your system's technical support department.
Safe and clean computing will save you money!
Following these basic computer care guidelines should help you to take good care of your computer system, and keep it running for years. Preventive maintenance will keep your system from having problems and will save you money in the long run. For specific questions about your particular system, you should ALWAYS check your user guide or contact technical support.
on Feb 27, 2010 | Computers & Internet
Tip
How to connect your home computer from Remote location?
Using the Remote Desktop feature, you can connect your home computer (host) from any other remote computer (client) and can access all computer resources (installed programs, data and any network resources). You can run any computer application on the remote computer as you were running actually sitting in front of home computer.
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
my_computer_properties.jpg Under the Remote tab, select the option "Allow users to connect remotely to this computer" and click Ok button.
remote_desktop.gif Now get the IP address of host computer (type the "ipconfig /all" on the command prompt of host computer to find IP address).
remote_dialogbox.jpg Click on Options button for detail configuration, under the General tab, type the IP address of host computer in the Computer box and also type username and password of host computer then click on Connect button to make a connection to remote computer.
remote_desktop_connection.jpg If your username and password is correct then a remote desktop windows will appear.
on Dec 03, 2009 | Computers & Internet
How would you save a story on micro word with a memory stick
Hi Friend,
Please follow the gevin instructions-
1-Insurt the memory stick in USB port of the CPU (USB port available in front and backside of the system)
Note-mainly system detect memort stick automaticaly,some time not detect at that condition go to tme my computer maange option(after right click of the my computer you will be able to see the manage option and go to the device maange and update the USB driver)
2- Copy the data (micro word)
3-Past the data into pen drive (memory stick)
4-disconnect the memory stick
Thanks,
Mar 10, 2010 | Computers & Internet
HARDWEARE+SOFTWEAR
im having acer aspire 3680 laptop and my USB port is not working .....i need help
Jul 09, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
