Question about Kenmore 15129 Built-in Dishwasher
Kenmore dishwasher - soap not dispensing
I used one of those detergent tabs....but when the dishes are finished washing, the tab is still in the dispenser.  I tried it a second time, and the tab is at the bottom of the dishwasher undissolved.  Any suggestions?  Thanks.
  • 33 Answers
That sounds crazy but hears some suggestions you must have real hard water for that tab- not to dissolve hear is a crazy question is the water coming in to the d/w hot enough or even hot at all i had cases where i found that the d/w was hooked up to cold water
Posted on Dec 30, 2007
Hi. My problem is with my dishwasher detergent dispenser. It does open (at least it is open at completion of cleaning cycle), appears to deliver soap to dishes (as they appear clean), however, from the...
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
heatman101
Feb 14, 2011 | Maytag MDBH985AWB / MDBH985AWS 24 in....
Kenmore Elite dishwasher will not dissolve soap or wash well.
Temperature should be 140F. and the units heater should energize during fill to achieve this.
May 19, 2010 | Kenmore 24 in. 15173 Stainless Steel...
Dishwasher doesn't wash dishes right
The solenoid that opens the detergent door may have had water leak into it. Remove the inner panel from the main door, remove the solenoid mechanism and it's core. With the core out, clean the solenoid interior and the core surface with hot water. The core should fall out of the solenoid by gravity if it is clean. DO NOT OIL THE CORE OR SOLENOID. If there are signs of water entry to the solenoid, check the detergent dispenser seal for damage. Try using a tab type of detergent rather than liquid or powder. Make sure the release mechanism is clean as well. Hope this repairs your problem!
Dec 29, 2009 | Frigidaire FDB1050REM Dishwasher
Detergent Fill Dispenser
It may be gummed up inside with old detergent that has caked on . Try rinsing out the despencer until it opens and closes easy. DFD
Apr 22, 2009 | Dishwashers
Kenmore Elite soap door problem
Dispenser may be bad. Push the hi-temp button , air -dry, hi-temp, air-dry in that order. All lights will lite up and this will do test cycle of all components. If soap disp opens then soap tab may be the issue. I have had intermittent dispenser issues and they are often hard to solve as other components may be at fault.
Nov 28, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Nov 07, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
I have a DW12-PFE2-2 the dishwasher tablet does not dissolve,it is still in the dishwasher detergent dispenser after wash has finished?
HI Accumulated detergent from prior washings can cause problems with the soap dispenser. Buildup can get into the soap dispenser and interfere with the spring that triggers the flip-out tray, or it can slow down the pivot action of the tray. If the dispenser is not opening, first make sure you aren't loading the machine so dishes or pots and pans are touching the dispenser, and that dish racks aren't blocking the dispenser. Also check to make sure the dispenser tray isn't cracked. If leftover detergent in the tray is almost liquid, rather than just damp, the tray may be damaged.
If you can't solve the problem easily, replace the entire dispenser unit. This is usually easier than trying to disassemble it and replace separate parts. Use a new dispenser made for the dishwasher. The screws holding the dispenser in place may be on the front of the unit, or you may have to remove the front door panel to get to the screws and make the replacement. Remove the old dispenser and secure the new one, connecting it in the same way the old unit was attached.
THANK U,,,,,,,,,,,,,,,,,,
Sep 12, 2008 | Haier Dishwashers
Dishwasher does not clean. soap door does not open every time.
Well the 2nd part of your question is probably the the reason it doesn't clean. If the soap door doesn't open then the dishes will probably not be cleaned. So.. I would focus on why the door doesn't open first.. is it sticking from old soap residue? If so, clean the dispenser with white vinegar and cycle it a few times without detergent and use the hottest/sanitary setting.. Then make sure you are using an approved dishwashing detergent for yuour wash cycle. Add some detergent to the dispenser and try cycling it without any dishes .. does the door open? If no, then you need to resolve that first.. If it does open, try running a cycle with about 1/2 the normal dish load and see if the door opened and the dishes came out clean.. Routinely, check and clean the drain filter so you aren't redistributing the food sediment from the previous load all over the next load of dishes.. Hope that helps..
Sep 06, 2008 | Kenmore 24 in. 16009 Built-in Dishwasher
Detergent remains after wash cycle
You should start using Electrol liguid dishwasher deterget, which comes in a container that dissolves when ittouches water. i've been using it for about a year, and it doesn't leave anything and my dishes look better than ever!
Apr 16, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwasher not cleaning well
clean the dispensor assy around the spring door hinge witha vinegar water solution . liquid detergent has a tendency to not fully break if your water is not hot enough, causes doors to stick, reccomend running hot water before starting d/w, and using a quailty powder( not tabs) detergent
Feb 20, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kenmore 15129 Built-in Dishwasher Logo
479 people viewed this question
Top Kenmore Dishwashers Experts
vince
D. E. Hev
gbob59
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
