P-Touch Model PT-65 won't turn on when pushing On Off Button
Brother P-Touch Home & Hobby PT-65 / BRTPT65
(PTouch, P Touch, PT65, PT 65, BRTPT65)
Answer from
Posted by Tiffany Marsh on Jan 20, 2013
http://www.fixya.com/support/t16011345-p_touch_model_pt_65_won_39_t_turn_when
Replace the "Toner Sensor PCB Assy" model # LJ9935001. It is located in the left side panel which is easily removed
(2 screws).
"I have solved my own problem, I have a second identical printer that
just developed the same problem, so this seems like a common problem.
The solution was to replace the "toner sensor pcb assy" model #
lj9935001. It is located in the left side panel which is easily removed
(2 screws), I had it replaced in half an hour and that was the first
time. It clips in ,the wire needs threading a little then then connector
. if you take your time and think it through it is easy then turn it on
and presto nothing but green status light. costs $18.50 with shipping
ground. Contact Brother 901-379-1000, get customer service and ask for
parts dept. Best of luck."
I found the the Toner Sensor PCB Assy" model # LJ9935001 for $9.89 just by searching through Google and Amazon, so shop around, $18.50 is expensive when you can buy a gently used PT-65 on ebay for $10 - $25.
