Question about Garden
Greenfield mower chain tension
The chain drive on my greenfield mower is very slack. how do i tension it?
    Problem Solver:
  • 29 Answers
Take chain off -- lay on floor --pull taught end to end push together --if it flexes more that one quarter of a inch --chain is worn --replace chain--also see how deep chain sits on sproket--- if sits too deep sprokets are wore and need replacing
Posted on May 01, 2014
5 Suggested Answers
mickey813
  • 472 Answers
SOURCE: Clutch function provided by idler wheel tensioning
is this a troy bilt and have you just replaced the front drive belt if so if the belt is a pix belt then you need to take it back you need a belt that is oem onley i know this for a fact i have tore up some ones hood if you havent done any of this then ck the pulley were the front and back belt goes on thats called a varspeed pulley i have had them lock up some times thay go out or the bearings on them go out and you can bearings them let me know if you need any thing mowershop@live.com ill help you
Posted on Mar 08, 2010
  • 146 Answers
SOURCE: Replaced Mower Deck Drive Belt.
Yes, there is an idler arm with a pulley that presses either inward or outward against the belt to tension it. In some JD mowers, the arm is tensioned by pulling on a long metal rod that latches near the edge of the mower deck, but without the model number I can't be more precise about that. Just look for that extra pulley and arm it's mounted on -- you'll see a tension spring, and you should also see a way to pull the arm away from the spring to place it under tension. Good luck!
Posted on Aug 15, 2010
SOURCE: i am trying to remove the cutter drive pulley from
Hello Mate, I know its been awhile since you posted but the deck pulley has a left hand thread. hope this helps.
Posted on Aug 30, 2010
vincob
  • 718 Answers
SOURCE: I need a diagrahm of a belt drive greenfield ride
Go to this website, upper right hand corner and do a parts look up. Search for your model and that good stuff they ask of you and then choose mower housing should be there, browse the site it's really cool and has a lot of info.
http://www.jackssmallengines.com
I did a sample search for generic riding mower deck and found great diagram of belt routing. Give it a try you will find same results Good Luck! Don't forget the thumbs!
Posted on Nov 10, 2010
Greenfield Ride on Mower need to increase tension on drive belts
As a rule there is 2 ways.
1 is a spring loaded idler pulley and the other is to loosen the motor and pull it back.
Depends on the age.
May 14, 2017 | Garden
My Greenfield 12-30 mower constantly drops the Drive Belt. How do I correct this?
First make sure that you have the correct size belt.
Then make sure the belt you are using is not stretched or worn out. Check all pulleys and make sure they are not worn and that they are in alignment. Finally make sure that all the idler springs are in place. It is wither an alignment issue or a belt tension issue
Feb 02, 2015 | Garden
Do the drive chains on Greenfield Ride on's have a removable link?
If not. Grind rivet head off on a link. Replace with a removal one.
Dec 20, 2014 | Garden
HOW TO ADJUST DRIVE CHAIN ON WEED EATER ONE
There is a tension adjustment on the body.. flip your mower over and you can see it better.. do not over-tighten it though because it needs slack to let the 1-2-3 to change on the fly.
Aug 18, 2014 | Weed Eater WE-ONE 26-Inch 190cc Briggs &...
Steering on a greenfield sit-on
adjust it why ??? they normally aren't adjustable
Jun 17, 2014 | Garden
Drive chain slack how do you tension
what kind of mower ???
Dec 27, 2013 | Garden
replace chain -- if it streches length way on floor more than a one quarter of a inch --chain is wore and needs replacing
Ratcheting noise on startup
Yes the tensioner is what keeps pressure on the chain or belt to keep it tight.If the chain or belt gets too much slack it could jump a tooth or two or worse it could come off while you are driving,causing severe engine damage.
May 07, 2012 | 2006 Hyundai Sonata
How do I reattach chain after it slipped off
Normal 0 This will be the basic instruction for most common saws. Check that the chain brake is in disengaged position by moving the front hand guard towards the front handle if the saw is equipped with a chain brake on the handle. Loosen the bar nuts on the clutch cover. Loosen tension screw or other adjuster (thumbscrew) to allow the bar to be moved toward the engine. Some saws have this tension adjustment built into the bar. This will provide enough slack in the chain to able to reinstall it. It may be necessary to remove the side cover to gain access to the clutch/gear assembly on the side of the engine if the chain also jumped the gear here. Remove the cover, inspect for any debris or other obstructions in this area. If none, replace the chain back over the drive gear and in the bar groove all the way around the bar. It may be necessary to turn the bar adjuster screw more to provide enough slack in the chain to do this. Once the chain is in place reinstall the cover and bar lock nuts. Snug up the nuts but do not tighten these. Turn the bar/chain adjuster screw to tighten the chain on the bar (take up slack). I usually tighten to a point where there is no slack between the chain and the bottom of the bar and I can still turn the chain easily around the bar by hand. With experience you will get the feel for this chain tension. Once the chain is properly tensioned, tighten the bar lock bolts/ nuts on the side cover. I hope this helps you out.
Jun 25, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chain will not move on chainsaw
Some Poulan Pros have an adjuster screw on the front of the engine case right beside the bar, some have a tool less adjuster on the clutch cover, and some have a slot in the bar for adjusting the chain tension.
May 15, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
805 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
