Question about Hitachi 42PD7800 42 in. HD-Ready Plasma Television
Hitachi 42PD8700 U
Everytime we turn out telly on we have to press AV2 on the remote control and when we try to watch DVD no picture comes out. We wanted to Configure it but there's no Configuration on the menu list and we tried to reset it but still nothing happened. Can you help us please? Thanks.
Switch on the dvd player so it's playing, then do a new master tune. press the dtt/tv button so you are watching the internal freeview system, then press menu, then go to installation, and re-install all channels. the tv will then detect your dvd player in the intial set up/tune mode.
hope this helps..
Posted on Nov 24, 2007
Need the code for rca DVD RTD315 SYSTEM FOR DirecTV REMOTE RC66X
Direct TV press menu scroll down to settings& help select settings scroll down to remote control select program remote AV2 select select DVD scroll down to RCA move switch to av2 codes press mute and select until light flashes twice enter code press powerare 20522,20571 ect more codes are abailbe by selecting more codes if code work move switch back TV
Jul 24, 2015 | RCA Televison & Video
I have had my sanyo flat screen tv for 1 year. The picture on 4 different stations is "snowy", the rest of the channels are fine. On my Sony DVD player I get audio but no picture. It is also 1...
These units are close enough to the warranty end period that I would suggest that you contact Sanyo and Sony requesting warranty service. Talk to a supervisor and be persistant. It may take a few calls.
Keep us posted.
Dan
Apr 18, 2008 | Televison & Video
I need remote codes to program my directv control to my bd p-1500 blu ray dvd
hi,
Try any one of the following code.
20490, 20573, 20820, 21075, 20899
Progarmminig procedure
The AV1 and AV2 switch position can be used to program a
VCR, DVD, STEREO, 2nd DIRECTV Receiver or 2nd TV with
the following instructions.
1. Turn on the component (e.g. DVD Player) you wish to
program.
3. Move the slide switch under the AV1 (or AV2) icon.
4. Press and hold the MUTE and SELECT keys at the same
time until the green light under AV1 (or AV2) flashes
twice and then release both keys.
5. Using the number keys enter the 5-digit code for your
brand of component being programmed. If performed
correctly the green light under TV will flash twice.
6. Aim the remote at your component and press the power
key once. The component should turn off. If it does not
turn off, repeat steps 3 and 4 trying each code for your
brand until you find the correct code.
7. Repeat steps 1 through 6 to program a new component
under AV2 (or AV1).
ok
Feb 21, 2011 | Samsung BD-P1200 Blu-Ray Disc Player
My hitachi CLE 978 remote control will not change the tv settings. When selecting DT/TV, AV1,AV2 etc the DVD light flashes and not the TV. Any suggestions on how to re-set the remote would be much...
You have to press that button to the right of where the TV and DVD light that flashes are so that TV light lights up. Then you should be able to select the tv settings.
Feb 05, 2011 | Hitachi Televison & Video
On which channel on tv set can i see the wii image the remote control switches the console on & off but we can't do anythying further despite of our connecting it correctly
hi, once you have plugged the wii into a socket on the back of the telly you then switch the wii on and then get your telly remote then depending on how you have it plugged in would depend on what button to press, if its the rectangle scart lead fitting type then you need to press one of these buttons.
av
source
input
or a picture of a rectangle with an arrow facing to the right
so find these buttons on your remote and press it now depending on how many inputs the telly has would depend on how many times you press the button you may need to press it up to 5 times so bare this in mind, if it is scart lead then if you look on the back of the telly where you plug the lead in it should tell you if its av1 or av2 or av3 if it tells you this then thats how many times you need to press the button.
if your using the 3 color leads then these will be under one of these buttons.
source
input
or the rectangle with the arrow
or video button
or button that says ext
once you have found these buttons give it a press until you see the picture.
then to get back to your tv you keep pressing the button till you get the tv picture or press a button that says tv.
let me know if you have any problems ok
Jul 10, 2010 | Nintendo Wii Console
Have ps3 that was working fine, unhooked it from one tv to another and proceeded with holding the power button 5 seconds til it beeped twice and still have blank screen
hi, if the ps3 was working fine on the other tv and you have not dropped it or anything like that then this would point towards their being a fault with the lead of the connection in the back of the telly.
what you should do is unplug it all again and refit all the leads in the back of the ps3 making sure they are pushed in far enough then plug the lead into the back of the telly making sure you push it in far enough, then switch the telly on and then switch the ps3 on if the telly dont change to the correct channel as soon as the ps3 comes on then you need to get the telly control and put the tv on the correct channel.
now depending on how many inputs the telly has would depend on how many times you press the button on the control, the button you need to press is going to be on of the following its either av, input,source,ext,aux, or a picture of a rectangle with an arrow running from left to right, now once you have found this button make sure your ps3 is on with a game in then press the button on the tv remote then wait couple of seconds it may say something like av1 on the telly if this dont show the ps3 then press it again it should then go to av2 and keep going until you see the game on the ps3 you need to keep going until your telly is on the right input channel.
once you have done this your ps3 should be working again.
let me know how you get on or if you need further assistance ok
May 25, 2010 | Sony Playstation 3 (PS3) Console
Lost the remote
that one is easy just press menu the channel button up till you get to av1 or av2 then press the volume to change it.
Dec 12, 2008 | XO Vision GX1042 10.4 in. Car Monitor
Green symbol AV2 won't go away! Sony Trinitron KD-28DL11U
You need to have original Sony TV remote and press Display button on it, on-screen display will disappear.
Nov 25, 2008 | Sony FD Trinitron WEGA KD-36FS130 36" TV
37PF7320A 37 problem hooking up dvd
Connect the DVD to the back of the set on AV2 red white and yellow rca cable . Then to the other end to the DVD red white and yellow. Turn the DVD on and press play. On the tv remote below the number 7 there is an AV button. Press that button and put the tv to AV2. Your DVD picture should be there.
Jul 04, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
BLANK TV
hi, what you need to do is find the source button or av button on your remote control as it sounds like its changed source this causing your problem. As you probably know your telly has many inputs for dvd vcr cable or sky but these plug into one of the inputs in the back of telly. Usually the problem is just that your on the wrong input channel like av1 instead of av2 or rgb their are many inputs so you might need to press this button 2 or 3 times till you get the right channel, i dont mean 1 to 9 channels i mean input channel like rf input or av input. This depends on what your getting the signal from if its cable and its plugged in via scart lead then it will be an av input but you might have av1 av2 av3 av4 this depends on your telly.
If your still having problems then give me a shout back ok best to check all the leads are in the telly correct as this will cause the problem your having ok.
Let me know how you get on ok or if you need further help
May 14, 2008 | Philips 32PFL5322D Television
Hitachi 42PD7800 42 in. HD-Ready Plasma Television Logo
221 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
