Question about Kenmore Dryers
Motor runs but drum doesnt spin
Motor is running but drum on kenmore 70 series dryer doesnt spin
  • Anonymous Mar 16, 2014
    Drum won't turn
    President:
  • 1,865 Answers
The belt may have broken, you must open the dryer case and check the belt. If broken, you'll see it laying on the bottom
Posted on May 18, 2009
Kenmore 11062612101
From your description, the dryer belt could be in need of replacement. The burning smell could come from the motor pulley spinning and trying get a grip to turn the drum.
Dec 20, 2013 | Kenmore series 70 80 90 Dryer Motor...
Kenmore 70 series dryer hums but doesnt spin
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 06, 2011 | Kenmore Dryers
Spinner will not spin
have kenmore 70 series washer model: 110.7015626w that will agitate but sluggishly and will not spin but the belt is getting hot (drum is not spinning but the motor is running).
Dec 17, 2009 | Kenmore 22422 Top Load Washer
My washer does not spin or move during wash cycle the moter runs but nothing is moving.
Hi, this motor has faulty windings, causing it to lock up and not rotate the drum/basket. replace this motor asap if possible.
May 29, 2009 | Kenmore Washing Machines
Kenmore Electric 70 series dryer making noise
can spin motor w/ hand ,,if so pull side by side if no noise ,, inspect rollers,and idler
Dec 28, 2008 | Kenmore 65942 Electric Dryer
Kenmore Series 70 Dryer cuts off after a few minutes
The bearings in the motor have probably worn out. Disconnect the motor and take it out of the dryer. See if it turns roughly or not at all by hand. Also try and move the post left to right and up and down and see if there is play in it. It should move very little if at all in those directions and should spin freely if it's good.
Dec 17, 2008 | Kenmore 72982 Gas Dryer
Makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Nov 16, 2008 | Kenmore 67082 Electric Dryer
Dryers Logo
266 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
