Question about Plumbing
I have a 3/4 hp jet pump that takes water from a pond and I connect it to a hose to water my lawn. It runs for a while and then shuts down. I wait a little while and plug it back in and it starts up and runs again a little while and shuts down. Any help?
    Problem Solver:
  • 11 Answers
Sounds like the high limit switch. It probably is getting too hot.
Maybe the internals are gummed up with algae or something else that is making the pump work harder than it should, you could also check the impeller to see if you have any broken pieces that prevent it from running at 100%
hope this helps
hope this helps.
Posted on Jun 06, 2009
Pumps water for a minute then shuts off.
Probably the pump has a water pressure protection switch. So it will not run dry and burn up. How is it that you are losing water pressure? On the delivery end or receiving. Restrictions on a pump always are placed output
Jun 01, 2015 | Craftsman Professional 3/4 hp Hydro-Glass...
Why would my 1 hp pump only maintain 45 psi running 1 garden hose?
Without knowing all your variables with well it is hard to say. Bladder tank needs to have 30 psi with no water pressure. It is possible that the screen down the well is restricted and you are only getting that much water. Or you may have clogged impeller in pump.
Sep 04, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Runs but will not pump water from a sand point.
You have a air lock. shut pump down refill with water and start, may have to do this a few times.
Sep 18, 2013 | Sta Rite Industries Shallow Well Jet...
My water pump kicks on every 30 min or so even if there is no water used
When a pump goes on and off there is a water leak somewhere.
There should be a gauge. Let the pump build up pressure and watch the gauge.
The pressure will probably be dropping. This means that water is going somewhere. The leak could be anywhere that you use water, sprinklers, sinks, hose lines. If there is a valve above or near the pump, shut that valve and see if the pressure stops dropping. If the pressure stays up and the pump stops cycling on and off, the leak in in the pressure piping somewhere, you must locate it and repair it.
If the pressure continues to drop even with the discharge valve shut, the water must be leaking back into the well. There is a check valve somewhere on your line between the well and the pump. If this check valve is leaking, pressure will drop and the pump will come on to restore it.
If it is possible to shut off the discharge of the pump, shut that valve and watch the pressure gauge to see if it is dropping.
Dec 12, 2010 | RTO Wayne 1/2 Hp Shallow Well Jet Pump
How do I backwash my sanddollar pool filter
Shut the pump off, then push down on the backwash (BW) handel turn it clockwise 180 degrees to BW and start pump again. Run pump till water coming from BW pipe runs from cloudy to clear. Shut the pump off and pushing down on the BW handel again turn it 180 degrees to filter and start pump again.
Oct 27, 2010 | Pentair Sand Dollar 19" Filter with 1 Hp...
My Flotec pump runs 5 seconds shuts off for 30
fully submerse pump in bucket of water, tilt to get all air bubles out,(keep hose off) plug in and it should work fine
Dec 02, 2009 | Flotec 1/6 Hp 1260 Gph Utility Submersible...
How do I prime my outside of the pond waterfall pump?
I would take the intake hose off the pump and fill it with water and with the pump running I would hokk upthe intake hose.
I also would if possible have the pump lower than the pond.
Mar 28, 2009 | Max Flo Waterfall Pump 2900 Gph
Plumbing Logo
176 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
